chasrb
Joined: 1/12/2003 From: Warrenton, VA, USA Status: offline
Cybertom, I talked with Marc at Techopower yesterday, tried to convince him to build a 1/4 scale engine for the Stearman..he said maybe if the redesigned current engines sell well and make him a good cash flow. He did reiterate what you were told, the Technopower engines just don't have the total solution for this plane. He said the 9C will get you off the ground, but it'll be just doing that and that there will be no power reserve in that engine while flying--the just in case power--that is a safety net to power out of a situation. He said if I could find a Seidel get it, or the Robart is a great choice with more power than Tim Taylor could use! I may do a "kinda" scale and use the OS or Saito until I can find a Seidel st726 or 770, which may be a while.
_____________________________
Chasman
