Soldering a battery lead to a battery?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Soldering a battery lead to a battery?
Page: [1]
Login
Soldering a battery lead to a battery? - 5/13/2002 1:11:55 AM
Matt.B
Status: offline
Last night I accidentally created a short on my battery, and it was on long enough to melt the connector. I will need to solder a new lead onto it so I have a few questions:
1) What is a good site that has step by step instructions on how to do this?
2) If my cycler shows the battery to be in good condition does that mean that I didn't damage it?
3) Would splicing a new wire onto the old wire work as well as just soldering a whole new lead onto the battery? I would like it to work as well as it did before.
Thanks!
       Post #: 1
Soldering a battery lead to a battery? - 5/13/2002 2:05:17 AM
Red Scholefield
Status: offline
Is this a receiver or transmitter pack or one for electric flight? Is the original wire soldered directly to the cell or to a solder tab?
_____________________________
Red S.
AMA 951 Leader Member
(in reply to Matt.B)
       Post #: 2
RX Pack - 5/13/2002 10:22:16 AM
Matt.B
Status: offline
It's a Futaba 4 cell RX pack. The wire seems to be soldered to a tab. Above that tab, running across the entire top of the pack is a white strip.
       Post #: 3
Soldering a battery lead to a battery? - 5/13/2002 4:49:21 PM
Red Scholefield
Status: offline
Then unsolder from the tabs (both at the plus and minus) and resolder a new lead/connector.
Red S.
       Post #: 4
Soldering a battery lead to a battery? - 5/14/2002 11:32:46 AM
Matt.B
Status: offline
Thanks for the response! Is there anything extra I should know about soldering leads to the tab before I do it? And how can I tell if I damaged my battery? The wires were shorted together long enough to melt away most of the connector( a few seconds ).
Thanks!
       Post #: 5
Soldering a battery lead to a battery? - 5/14/2002 3:47:24 PM
Red Scholefield
Status: offline
Cycle the pack a few times to see if you get near rated capacity.
Red S.
       Post #: 6
Soldering a battery lead to a battery? - 5/15/2002 5:17:51 AM
Matt.B
Status: offline
My local hobby store only has servo leads with the extra white wire on it. Will these work just as well?
       Post #: 7
Soldering a battery lead to a battery? - 5/15/2002 5:44:34 AM
majortom-RCU
Status: offline
No problem with the extra lead--either clip it off to avoid confusion, or leave it on and ignore it. It has no electrical effect until it's hooked up to something at both ends.
       Post #: 8
Soldering a battery lead to a battery? - 5/16/2002 10:16:46 AM
Matt.B
Status: offline
I bought the servo lead and soldered it onto the battery. One thing that I noticed was that the wires on the new lead are smaller than the ones on the old lead. Could this possibly cause a problem?
Thanks!
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.531RCU1
