couldbemage
The problem with the osprey is also call "power settling" and affects all helicopters. This is when an increase in collective pitch during a rapid descent with little or no forward speed cause the rotor to stall due to a ridiculously high angle of attack. On a single rotor heli, this means you pull up on the collective and you drop faster, but if that happens it is really pretty obvious what is going on. With the osprey this condition is so very deadly because of its side-by side rotor configuration, and being a tilt rotor isn't even part of the problem(all side-by-side helis have this problem, maybe that is why there aren't any.) When this sort of heli turns, it does so by in creasing pitch on one side, decreasing it on the other. This means that when the pilot pushes the stick to the right during a rapid descent, the osprey starts to roll left. Pilot then naturally cranks the stick farther to the right; left rotor loses all lift; osprey rolls violently to the left. Now it's upside down a few hundred feet off the ground. Of course, the manual clearly says not to descend that rapidly. Most other aircraft exibit clear warnings before they fall out of the sky, but they did issue a warning. ps. Pilot error is what happens when all liable parties that are still alive get together and lay blame.
