RE: Triton, Super Brain 969 for Li-Poly    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> E-Flight Power Sources >> RE: Triton, Super Brain 969 for Li-Poly Page: <<   < prev  1 [2]
Login
RE: Triton, Super Brain 969 for Li-Poly - 2/18/2004 8:30 PM
blademan7065
Score: 100
Last Login: 7/25/2010
Status: offline
The only reason that I could think is to accurately measure the mah that you are putting into the battery when you start to charge before using. If you are stating to charge the battery with a half a charge you would not be able to determine a false peak.
_____________________________
Experience is found at the bottom of every gallon of fuel. You gotta burn it to learn it.
Hide Signatures
(in reply to BasinBum)
       Post #: 26
RE: Triton, Super Brain 969 for Li-Poly - 2/18/2004 8:46 PM
Clark L
Score: 100
Last Login: 4/15/2013
Status: offline
I think the charge>discharge cycle is used for storage purposes. This setting cycles the battery and leaves it discharged. If you dont intend to put it to use right away, Its best not to leave a Nicd fully or partially charged... At least this is what I've heard.
Hide Signatures
(in reply to blademan7065)
       Post #: 27
RE: Triton, Super Brain 969 for Li-Poly - 2/18/2004 11:19 PM
BasinBum
Score: 1145
Last Login: 7/27/2012
Status: offline
G-Wiz,
That is exactly the opposite of what I have read, you want to store batteries with a full charge. Additionally Blademan, while I understand what your saying about C>D mode knowing the amount of MAH you put into the battery is not nearly as useful as knowing what it discharged under a given load. As far as false peaking from a half charge I don't know if that's an accurate statement as I think the technology allows the charger to peak detect from any point in the charge cycle, it just looks for the drop and rise that happens at the end of a battery being topped off. Maybe we should go over to the battery forum and ask these questions there.
Hide Signatures
(in reply to Clark L)
       Post #: 28
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.219RCU1
