RE: <span class=
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: <span class= Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: <span class= - 12/16/2003 1:02:31 AM
Geistware
Status: offline
Is anyone trying to remove the two logos on the wing ends.
The rabbit and the Edge decals? If so, how?
_____________________________
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
(in reply to splais)
       Post #: 26
RE: <span class= - 12/16/2003 1:04:53 AM
Abraxxas
Status: offline
splais - It is a Global Freestyle 3D (awesome plane)
It will be a while before I do much on this Edge, have to order all the gear for it now that I actually have it the plane, but all in due time
Brian
"Hey, everybody land for a minute and shut your planes off, I have to call in sick..."
It must be 8am at the
(in reply to ShawnM)
       Post #: 27
RE: <span class= - 12/16/2003 4:57:25 AM
Fixed Wing
Status: offline
I'm going to try to remove the Wild Hare decals from the main wing also but haven't tried it yet. I did lift an edge of the rabbit up with an exacto knife just to test how hard it will be. I think it will come off OK but it may be tedious. I did this same thing when I removed the Hangar 9 decals from their 33% Sukhoi and it worked fine. After the decals came off I used WD40 on a rag to remove the faint images left where the edges of the letters were. BTW, this is my 4th WH product - 35% Giles, red & white 35% Extra, red & yellow 35% Extra, and now the 28% Edge 540. Needless to say I've been very impressed with the quality, service, and flight capabilities of Tom's kits.
"You can never have too much horsepower"
(in reply to Geistware)
       Post #: 28
RE: <span class= - 12/16/2003 2:43:34 PM
Geistware
Status: offline
Fixed Wing, let me know how it goes. I will try mine this weekend.
(in reply to Fixed Wing)
       Post #: 29
RE: <span class= - 12/16/2003 2:44:19 PM
jetfreak
Status: offline
well guys this afternoon I should be able to post pics of the DA50 and slimline smoke muffler. I got the cowl cut and put on also. This is about as far as i can go with out having christmas a lil early. Alot of this years presents are based around this plane. I had to beg like a sad dog to get the spinner out of her hands long enough to get the motor and cowl mounted.
DA50 users. Be prepared to make some kind of spacer. Even with using the stand offs you are about 1" short of making it to the cowl face. I made some hardwoord spacers that I will show in the pictures.
With the PITTS style smoke muffler I was faced with two option. 1 cut the pipes back about 3/4" or 2 slot the hole on the cowl so you can get the cowl on and off. If you cut the pipes, it puts them that much closer to the plane. With smoke I don't want to have an oil bucket after every flight. So i choose to slot the holes a lil and leave the pipes the regular length.
Will post pics at lunch time.
       Post #: 30
RE: <span class= - 12/16/2003 6:39:36 PM
jetfreak
Status: offline
motor mount pics
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to jetfreak)
       Post #: 31
RE: <span class= - 12/16/2003 6:40:28 PM
JohnVH
Status: offline
Hey, can someone get the the dimensions of the wings? Length, chord at root and tip?
Thanks!
---AIR VH---*FURY FLYER* www.3DFoamy.com
       Post #: 32
RE: <span class= - 12/16/2003 11:01:02 PM
Geistware
Status: offline
OK, I am gettting ready to eat dinner so lunch is over, where are those pictures!!!
quote:
ORIGINAL: jetfreak
       Post #: 33
RE: <span class= - 12/17/2003 12:15:13 AM
krayzc-RCU
Status: offline
i am drooling hard here!!!!
smooth as silk!
       Post #: 34
RE: <span class= - 12/17/2003 2:31:07 AM
Abraxxas
Status: offline
Jetfreak - What length standoffs are those on your DA? Thanks
JohnVH -
Span of one wing = 38"
chord at root = 21 1/16"
chord at tip = 11 5/8" including aileron
Brian
(in reply to krayzc-RCU)
       Post #: 35
RE: <span class= - 12/17/2003 2:41:22 AM
nonstoprc
Status: offline
Hi Jetfreak,
What is the size of the standoffs you have there? Where did you get them? Thanks
       Post #: 36
RE: <span class= - 12/17/2003 2:42:11 AM
JohnVH
Status: offline
Thank you Brian.
(in reply to nonstoprc)
       Post #: 37
RE: <span class= - 12/17/2003 4:11:52 AM
jetfreak
Status: offline
They come with a DA50 as a standard. They are 2.5 inches long. There is a company on RCU that will custom make standoffs for you to your specified length. They were not to bad on pricing either. I think it was around 30-40$. I also measured my wood spacer that i built with a micrometer. they are .639 which is pretty close to 5/8 of an inch (5/8=.625)
HERE IS A PICTURE OF THERE CUSTOM STANDOFFS ON A DA50.
Here is the link to where i saw them on rcu
custom standoffs
Click for fullsize
(in reply to JohnVH)
       Post #: 38
RE: <span class= - 12/17/2003 5:27:37 AM
Abraxxas
Status: offline
Sweet, thanks jetfreak... I ordered my DA50 today and they said standards are 2.5 but they have short and long available too but nobody ever asks for them I got 3 inch ones included with my engine as a "standard issue" option, hopefully they should be very close Here are a couple more pics from a prettier angle of the new bird, this is one of my favorite pic angles of an airplane
Brian
Click for fullsize
Click for fullsize
       Post #: 39
RE: <span class= - 12/17/2003 6:15:17 PM
krayzc-RCU
Status: offline
she looks sweet!
smooth as silk!
(in reply to Abraxxas)
       Post #: 40
RE: <span class= - 12/19/2003 11:59:41 AM
Geistware
