thickness of the aeroplane body
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> thickness of the aeroplane body
Page: [1]
Login
thickness of the aeroplane body - 12/12/2003 7:26:36 PM
yak52
Status: offline
My mold of yak52 is ready. The scale is 3.8. I would like to know your opinion what kind of glassfibres would you use for front / back parts. The weight might be 10 kg ( 22 pounds ). Suitable engine in cowling might be Fuji B2 80.
Thanks a lot for answers
Hannu Kunttu
       Post #: 1
RE: thickness of the aeroplane body - 12/13/2003 12:36:23 AM
Mike James
Status: offline
The answer partially depends on how your internal structures are made, but...
With the Yak 52, most of your load-bearing structures can be "unitized", so that just a few key formers share the loads. (the wing joint/landing gear support/firewall area) If so, then the fiberglass parts can be built rather lightly.
I recently built an 18 pound fiberglass plane, and did several experiments with cloth weight. The best combination for that particular plane was one layer of 4.5 oz. cloth, followed by a layer of 2.5 oz cloth. I think that if you plan for a total cloth weight of "8 to 10" for 2 layers. (6+4, 4+4+2, 3+3+3, etc.) you will be fine. It might be worthwhile to use a little extra cloth, or perhaps some carbon tow "bands" back in the tail section, to prevent twisting, if you plan on aggressive flying.
Cool project. Let us see some photos when you're ready. I've added a YAK 52 image, so others here can see what we're talking about.
Click to see fullsize image.
Click for fullsize
< Message edited by Mike James -- 12/12/2003 3:38:29 PM >
_____________________________
Mike James
RC Design and Building - www.nextcraft.com
(in reply to yak52)
       Post #: 2
RE: thickness of the aeroplane body - 12/13/2003 1:59:23 AM
CoosBayLumber
Status: offline
Mike:
Kind of vague here, but you have any estimates as to thickness of cloth based upon diameter of fuselage or length of empanage?
I would assume that a fiberglass fuselage of about 6 inch diamater would require an overall thicker cloth than one of about 2 inches like used in gliders.
Then too, if the portion from wing to stabilizer is 18 inches in distance, it could require a thinner cloth than one of about 36 or greater.
I have seen some awfully thin fuselages on 1/2A or small electric A/C and likewise know they would fold up if built four times larger.
I am thinking here now of unsupported, or non-plywood reinforced finished product.
What thickness of cloth should be aimed for for the different diameters or lengths?
Wm.
www.mybloo.com/coosbay/laser/laser.html
Thousands of Laser Cut parts, thousands
(in reply to Mike James)
       Post #: 3
RE: thickness of the aeroplane body - 12/13/2003 2:14:35 AM
davidfee
Status: offline
Two words: Sandwich Panel.
(in reply to CoosBayLumber)
       Post #: 4
RE: thickness of the aeroplane body - 12/13/2003 6:37:44 AM
mithrandir
Status: offline
I must agree with DAVIDFEE. I built a molded 33% scale sukhoi 26. Fuselage about 12.5" dia at firewall. 1 layer of 4 oz. "S" glass, 3/32" balsa core, and 1.8 oz. Kevlar were primary lamination schedule. Add to this uni longerons top and bottom, left and right and that was it. I of course added buildups around fire wall, wing spar pass thru, and stab. I also added about .5" x .020: carbon uni to each side of rudderpost to give vertical good strength/stiffness. ALL of the bidirectional cloth was at a "Plus'n'Minus" 45 degree orientation. Carbon uni took the bending load, bidirectional took the torsion load and shear load. This fuselage is over 6 feet long, qualified to take all out aerobatic loads, and weighs about 4 pounds. I had only a fire wall, and partial bulkheads where the "Cross your Heart" spars were pinned. Get a vacuum pump and vacuum bag a sandwich structure!!! And spray primer in the mold!!! this will reduce/eliminate pinholes!!
(in reply to davidfee)
       Post #: 5
RE: thickness of the aeroplane body - 12/13/2003 3:31:26 PM
yak52
Status: offline
Thanks everyone for help.
Here are several main dimensions. Diameter of the cowling is about 11 inches. Wingspan is about 100 inches and length of fuselage is 82 inches.
As Mike James told how to handle loads ( the wing joint / landing gear support / firewall area ), I am thinking that I will use that way. I use the pipe which connects wings and landing gears. Only the firewall is made differently, there is a box which goes inside the cowling.
Hannu Kunttu
(in reply to mithrandir)
       Post #: 6
RE: thickness of the aeroplane body - 12/13/2003 5:24:45 PM
yak52
Status: offline
One question more Mike what unit you use this "I think that if you plan for a total cloth weight of "8 to 10" for 2 layers." Our gountry we use square meter and kilograms. Is it square inch and pound?
Hannu Kunttu
< Message edited by yak52 -- 12/13/2003 5:25:34 PM >
(in reply to yak52)
       Post #: 7
RE: thickness of the aeroplane body - 12/13/2003 8:35:35 PM
davidfee
Status: offline
Hannu,
Here in the US we use those crazy English/imperial units... so we use ounces/square foot.
Approximate conversions:
oz/ft^2, g/m^2
2, 65
3, 100
4, 135
5, 170
6, 200
8, 270
10, 340
< Message edited by davidfee -- 12/13/2003 8:36:25 PM >
(in reply to yak52)
       Post #: 8
RE: thickness of the aeroplane body - 12/13/2003 11:35:36 PM
Mike James
Status: offline
Hi everybody,
This is an interesting conversation.
(Yes, my number examples, like "6+4" were in ounces.... i.e. 6 oz cloth + 4 oz cloth)
William:
I never really thought about this in terms of "weight vs. length", but that's one way to look at it, and you're right of course that each plane deserves it's own plan. I don't keep figures on this, because most of the fuselages I've built have been so similar in size (say, 60 to 90 inches length) that I can almost always use the same formula.
I tend to overbuild the first fuselage, as a safery concern, then determine through flight testng if I can build it lighter. Using a pretty standard flight testing plan, going from "gentle" to "aggressive", I want to know that the plane can take whatever I'm going to do with it without a failure. If the first one can, then I consider building the next one lighter, until a failure occurs. Then I'll use the previous, stronger one as the "production" version. Last year on the Berkut project, I used the "6 to 8" method. on that fuselage, which was about 12 inches in diameter and about 70 inches long, and it was fine. The plane we rung out the most in test flights ( a "3.5 + 3.5" layup ) was the lightest one, and it was plenty strong.
I think the biggest determining factor is where the loads go. Whenever possible, I try and think of a fiberglass fuselage as simply a fairing around the structure. Some loads will be transmitted to the skin of course, but since every plane is different, and the shape affects how loads get transmitted, it would be hard for me to put a precise "formula" on it. Aside from crash damage, I've never had a fiberglass fuselage fail from flight-induced stress. This includes Pattern and other aerobatic types. If you're doing a pylon racer, turbine-powered jet, or a plane designed for heavy cargo lifting, my ideas may be inappropriate. You would need more reinforcement, whether it's in the internal structure, or the composite shell itself.
One other thing...
All composite structures don't necessarily have to be super rigid. A small amount of flex at certain points in the structure can be tolerated, as long as it doesn't cause flutter or some other divergent flight problem. Some very high quality aerobatic planes I've looked at felt flimsy in my hands, but were plenty strong enough for flight loads.
Lots of trial and error in composites...
How the thing is shaped, how it's built, how the internal structure takes flight and ground loads, and how it's maintained... All have an effect, best learned through a combination of studying what everybody else does, and then creating your own experiences to prove or disprove the idea.
Mike James
       Post #: 9
RE: thickness of the aeroplane body - 12/14/2003 12:54:29 AM
davidfee
Status: offline
Why not make the fuselage shell the structure, rather than just being a fairing around the structure? Add a few minimal formers where absolutely needed. Think uni-body construction vs body-on-frame.
my 2 pennies...
-David
       Post #: 10
RE: thickness of the aeroplane body - 12/14/2003 2:28:19 AM
Mike James
Status: offline
Your method will work as well as mine, David. It just depends on the airframe. I wouldn't agree that either method is the ideal one for every project.
For example, the pusher (Berkut) that I did last year is built so that most of the load-bearing parts converge at one point... in this case, at the rear of the airplane, where the firewall, landing gear supports, and wing spar all meet. No reason to build a super-strong frontal fuselage in that case.
Another one I'm working on, a 1/6th scale Piaggio "Avanti" is very similar. The main wing spar and main landing gear, as well as support for the engines and fuel system , all converge at one point. The front of this plane will be built as lightly as possible.
But...
If you feel that your entire structure must be a load-bearing part, then by all means, add more formers and reinforcements. The way modern turbine jet kits are constructed is a lot like that, since there are both weight-carrying and thermal issues throughout much of the fuselage. I think that in that case, (and others, I'm sure) that your method would be better. That's what I'd do too.
Mike James
       Post #: 11
RE: thickness of the aeroplane body - 12/14/2003 8:15:51 AM
Darrinc
Status: offline
A single layer of 5.7 oz carbon @ +- 45° orientation with core at stress points. (simple) Or 2 layers of .005 Uni with the same orientation and core. (best)
"Make everything like your going to make the front page of NASA Tech Briefs"
Go Team Orange! Darrin R Cash
       Post #: 12
RE: thickness of the aeroplane body - 12/14/2003 9:01:38 AM
davidfee
Status: offline
Mike,
I don't think our ideas are as different as it maybe sounds at first. My suggestion of the sandwich panel is so that lighter glass can be used and still yield a part with much increased stiffness. Because the part is stiffer, fewer bulkheads (not more) are required to support things like the vertical and horizontal stabilizers. The tail will not twist. The core material does not need to be applied everywhere either. It can be localized in high stress areas.
The way I view a fuselage is that it is there to a) hold the motor, wing and tail in alignment and b) direct air smoothly over the contents.
Some structure will be required to hold the compotents in place, so an analysis of the loads is important, as you have suggested. The bigger the fuselage, the thicker the skin needs to be to maintain stiffness... hence the sandwich suggestion. mmm ... this is making me hungry.
(in reply to Darrinc)
       Post #: 13
RE: thickness of the aeroplane body - 12/14/2003 9:38:01 AM
Mike James
Status: offline
David, you've got my interest, and I think it would also be serving this thread, if you could post some info and photos showing some examples of your sandwich technique. I understand the concept, and have built sandwich structures before, (firewalls, formers, etc.) but have never built a complete fuselage that way. (Now, I'm hungry too.)
I'm always looking for better ways to do things, so why not give us a little lesson here, if you have time. We can all learn something. Have you done this technique with "ordinary" fiberglass, rather than carbon or Nomex? (less expensive) And... I assume you vacuum bag these?
Mike James
       Post #: 14
RE: thickness of the aeroplane body - 12/14/2003 7:07:51 PM
davidfee
Status: offline
I don't have any pictures of exactly what I'm talking about, but it if I steal a picture from Michael Luvara and his thread here, then it could look som
