RE: Let's see your work shop!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> RE: Let's see your work shop!
Page: <<   < prev  18 19 [20] 21 22 23 24 25 26 27   next >   >>
Login
RE: Let's see your work shop! - 5/10/2007 1:26:27 AM
dicknadine
Status: offline
painted peg board hung from the header/ceiling works super. no need for holes in the wall. dick
_____________________________
dick/rcflyer
(in reply to rcfury)
       Post #: 476
RE: Let's see your work shop! - 5/15/2007 1:39:39 PM
l0417935544
Status: offline
Great pictures of your workshops. Hopefully post pictures of mine when I get it going in a few months. This thread has got some good ideas.
(in reply to dicknadine)
       Post #: 477
RE: Let's see your work shop! - 5/16/2007 5:38:30 AM
Teachu2
Status: offline
Well, we're standing up the framework tomorrow!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Trent Combs
Fly 'em until the last piece stops!
(in reply to l0417935544)
       Post #: 478
RE: Let's see your work shop! - 5/16/2007 11:10:43 PM
KingCobra2
Status: offline
Awsome!!!!!!!! Just about as big as your back yard. Keep us informed and up dated. Scott
quote:
ORIGINAL: Teachu2
If it flys, Fly it! If it don't, fix it. :D
(in reply to Teachu2)
       Post #: 479
RE: Let's see your work shop! - 5/17/2007 4:35:29 AM
Teachu2
Status: offline
Actually, it leaves a 10' wide pad at one end and a 20' wide at the other. It sits at the back of out lot, behind the cross fence, in MAN COUNTRY.....where it won't bother my better half! One of these photos shows the back patio, another is the back lawn from the back patio - and the shop will be behind the redwoods and fence there.
Click for fullsize
Click for fullsize
Click for fullsize
Trent Combs
(in reply to KingCobra2)
       Post #: 480
RE: Let's see your work shop! - 5/17/2007 11:18:36 AM
l0417935544
Status: offline
These are my aircraft and all I have at the moment is a spare bedroom to keep them in. I've attached pictures of the way I keep them off the ground. This has got to be the best way to keep model planes off the floor so they won't get broken and take up the whole room.
Click for fullsize
Click for fullsize
       Post #: 481
RE: Let's see your work shop! - 5/17/2007 4:34:34 PM
Teachu2
Status: offline
I do the same 'cept I use 1/2" EMT metal conduit instead of wood dowel.
Trent Combs
       Post #: 482
RE: Let's see your work shop! - 5/18/2007 3:46:50 AM
l0417935544
Status: offline
That shed your building is awesome. My plans for my shed will be going to the council in about a months time. It's only 20 x 10 feet. Not as big as yours. I also reckon Ill get rid of the wood and make the model racks out of steel.
       Post #: 483
RE: Let's see your work shop! - 5/18/2007 3:51:58 AM
Teachu2
Status: offline
Getting closer! I'll probably be moving into it the end of next week.
Click for fullsize
Click for fullsize
Click for fullsize
Trent Combs
       Post #: 484
RE: Let's see your work shop! - 5/18/2007 3:58:21 AM
Teachu2
Status: offline
20' wide 27' deep pad on one end
Click for fullsize
Trent Combs
       Post #: 485
RE: Let's see your work shop! - 5/18/2007 3:59:38 AM
Teachu2
Status: offline
11' wide x 27' deep pad on the other
Click for fullsize
Trent Combs
       Post #: 486
RE: Let's see your work shop! - 5/18/2007 4:00:59 AM
Teachu2
Status: offline
Standing on the 11' pad, looking toward the house.
Click for fullsize
Trent Combs
       Post #: 487
RE: Let's see your work shop! - 5/18/2007 7:02:01 PM
cjet
Status: offline
Here's what I use for racking models on the wall.
Shelf standards from the local building supply. Add a little pipe wrap and you are good to go. Brackets can be from 6" to maybe 16" It depends on your store stock.
Mine are 12" and 14".
Click for fullsize
Click for fullsize
       Post #: 488
RE: Let's see your work shop! - 5/30/2007 6:22:54 AM
Teachu2
