I want collective pitch!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> I want collective pitch!
Page: [1]
Login
I want collective pitch! - 12/17/2003 5:54:46 AM
3D-Flyer
Status: offline
I am wondering why I went with the aerohawk heli now. I have a pretty heavily modified Aerohawk now but I am disappointed that I am unable to get a Collective Pitch head for it. Anyone know if there is one available or one in the making? Helihobby.com has that nice CCPM head for all the micros except the Aerohawk. What gives? Aren't all the Micro Heli's pretty much the same thing?
Shoulda bought a Piccolo Pro is my assumption :P
Brandon
       Post #: 1
RE: I want collective pitch! - 12/17/2003 7:58:14 PM
AtomHeartMother
Status: offline
Unless it's a hornet or piccolo, you'll be modifying the airframe anyway to do a CP conversion. A buddy of mine just bought a smartech bird....probably based on the aerohawk. Anyway, I'd be willing to bet the hornet conversion posted on HH's site would work with an aerohawk. The biggest thing would be shaft length and servo mounting.
If you are considering it, go with the stock hornet CP conversion kit. It's like 75 bucks or so and will do 3D just fine by all reports. Too many problems reported with the 195 dollar red head from you know who.
You'd probably have maybe 120 bucks in a conversion that way...including the extra servo for ccpm.
_____________________________
" So there we were...25,000 feet, canvas flapping in the breeze...deadstick.."
(in reply to 3D-Flyer)
       Post #: 2
RE: I want collective pitch! - 2/20/2004 4:32:41 PM
agricus
Status: offline
I am new to the Micro Heli scene, for that mater I am new to RC helicopter. I recently purchased a Hummingbird V.II I know that Century is coming out with a CP version of the Hummingbird. I am a beginer so i didn't bother wit the CP version, my question is can I upgrade my Hummingbird V2 to have CP? Not alot of info on Century's website I thought maybe i could find the answer here.
I appreciate any help
(in reply to AtomHeartMother)
       Post #: 3
RE: I want collective pitch! - 2/20/2004 4:52:48 PM
crazhorse
Status: offline
well I've heard on the bbs's both......... there will be a conv kit and there wont be......... so who knows........
< Message edited by crazhorse -- 2/20/2004 4:53:13 PM >
(in reply to agricus)
       Post #: 4
RE: I want collective pitch! - 2/20/2004 5:03:50 PM
agricus
Status: offline
I sure hope they do...
it make this investment worth while
(in reply to crazhorse)
       Post #: 5
RE: I want collective pitch! - 2/20/2004 5:19:18 PM
helisfreak
Status: offline
quote:
ORIGINAL: AtomHeartMother
Can u explain about the hornet conversion kit? 75? Im looking into CP to, and i got an aerohawk....
       Post #: 6
RE: I want collective pitch! - 2/20/2004 6:53:11 PM
markfsanderson
Status: offline
Just keep in mind that the CP upgrade also means a radio upgrade. I believe in the case of the Hummingbird, it required that you have a Heli radio that supports eCCPM. I believe that the Picollo can work with standard 4 channel, but 3d will be nearly impossible . . .
Mark F. Sanderson
(in reply to helisfreak)
       Post #: 7
RE: I want collective pitch! - 2/20/2004 7:01:44 PM
agricus
Status: offline
so how many channel would you actually need? 6?
(in reply to markfsanderson)
       Post #: 8
RE: I want collective pitch! - 2/20/2004 7:11:15 PM
markfsanderson
Status: offline
The absolute minimum would be 5 channels. This would not allow you to remotely adjust your Gyro gain, but that's not a big loss - just buy a GY240 or similar and keep it in HH mode. The Collective is a special mix between the pitch and throttle. This relationhip is expressed by throttle and pitch curves. These throttle and pitch curves are only available on heli radios . . but I imagine that you could convince an A/C only radio to do them . . but I wouldn't even try. The JR 6102 is the probably the best low end radio available today. Graphic display, 5 point curves, and eCCPM support. I believe that you can purchase TX only on the channel that the Aerohawk is on (as they use positive shift rx as well - I believe - but not sure). You would also have to by seperate components for CP, because the Aerohawk rx is only 4 channels. The JR 6102 will allow for remote Gyro Gain control (switch in and out of HH and standard rate). Remember, although most people pay attention to the # of channels - that is NOT what makes a better radio better. It is the feature sets, mixes, # of points on a pitch curve (the JR 10X I believe has 13(!?), and you can vary their X position as well!) and etc that distinguish radios. The 6102 has 5 point pitch curves(same as 8103 and 378) - this is exactly what is necessary. I personally believe that if you are going to fly A/C and helis - buy a heli radio.
Regards,
Mark F. Sanderson
PS: Could be wrong about # of points on the 8103 . . that might be 7?
< Message edited by markfsanderson -- 2/20/2004 1:16:07 PM >
Mark F. Sanderson
       Post #: 9
RE: I want collective pitch! - 2/21/2004 5:58:00 PM
gordongoly
Status: offline
hi, I have the Aero Hawk too..
and i was thinking of buying the piccolo CP upgrade kit.
this head is the same as the piccolo pro head
I'm just 14 so I don't want to spend $300 for a new transmitter..
so I was thinking of sharing the throttle channel with the pitch servo..
would it be possible to fly a bit 3D with this setup?
ore would it just be a bit more stable?
Thanks, Gordon
       Post #: 10
RE: I want collective pitch! - 2/22/2004 8:01:17 PM
Smithaw
Status: offline
Well one thing i was thinkin with the aerohawk to make it cp is a flybarless setup. i know they have a lot of these with the hornets but from what i have read everyone has said that you dont have to modify anything really to have a flybarless heli. That is why i put out a post earlier asking if the hornets mainshaft has the same diameter as the aerohawks because if it does you could get the flybarless head like this one http://www.helihobby.com/commonImages/flybarlessHead2.jpg. The only thing with this is you would still need a better tx and you would be wise to modify it so it had 120degree servo setup. Does this sound right to anyone or am i just completly wrong??
(in reply to gordongoly)
       Post #: 11
RE: I want collective pitch! - 2/23/2004 9:04:43 AM
katipo
Status: offline
Well I've just taken a punt and ordered the Piccolo CP Upgrade kit from Hobby-Lobby with the intention of converting my Aero-hawk. I've got some engineering friends who are also into micro Helli's and have offered to make any parts that I need to get it going. I will report back in a few weeks to let you know how we got on and what the modes where. Wish us luck, Cheers.
(in reply to Smithaw)
       Post #: 12
RE: I want collective pitch! - 2/23/2004 1:22:18 PM
gordongoly
Status: offline
katipo, are you also going to fly the piccolo head with a 4 channel transmitter?
let me know how it goes...
Gordon
(in reply to katipo)
       Post #: 13
RE: I want collective pitch! - 2/23/2004 4:28:50 PM
markfsanderson
Status: offline
Gordon,
Sorry, but it looks like you'll have to cut lawns/shovel snow/whatever to get the 6 channel transmitter. The term '3D' implies inverted flight and etc . . . To do this smoothly without 5+ channels would be next to impossible. I personally can't think of a way . . . I don't believe that you'll have to spend $300 . . I see on ebay the 6102 going for ~$180-$224.
Regards,
Mark F. Sanderson
Mark F. Sanderson
       Post #: 14
RE: I want collective pitch! - 2/23/2004 7:46:02 PM
gordongoly
Status: offline
Mark, this is what hobby-lobby says:
Convert your Piccolo with this Collective Pitch upgrade set to unlimited aerobatic flying even with a 4 channel transmitter! Upgrade includes all new rotor head parts including new swashplate, specially designed CNC-milled Rotor Blades and 10 ball bearings. Use a servo ''Y'' connector harness (HT0096) with a 4-channel radio to allow the throttle and pitch servo to share the throttle channel.
and UK flight says that it is possible to fly 3D with a 4 channel transmitter just use a ''Y'' connector harness and share throttle with the pitch servo.
by the way that 6102 looks nice for $180.. but I think it's a bit difficult for me cause I'm just 14 and I'm dutch so my English isn't so perfect..
Thanks, Gordon
Go to my Micro Heli website [link=http://www.golyzone.com]www.GolyZone.com[/link] (Dutch Language Only)
       Post #: 15
RE: I want collective pitch! - 2/24/2004 10:44:18 PM
