YS 91 leaking fuel from the Carb
Tower Hobbies
Logged in as Guest
  Printable Version
90 Degree Muffler Adapter
Seller:  RC Specialties
Details:   $17.95   |  10/31/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> YS 91 leaking fuel from the Carb
Page: [1]
Login
YS 91 leaking fuel from the Carb - 4/25/2002 10:49:44 AM
jack01
Status: offline
Is it dripping out of the carb mouth where the throttle barrel is, or somewhere else? Did you leave the tank pressureized after you flew it?
       Post #: 1
YS - 4/26/2002 1:25:44 AM
FIVESQUARE
Status: offline
My money is on the regulator....Listen to what y8 has to say on disassembly and putting it back again. I could have bet it was the check valve...if you are holding pressure it is not a factor..... If it isn't the reg dirty....You have a leak or you check valve is dirty and by-passing and dirty. DOC
(in reply to jack01)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.250RCU2
