RE: KMP 337 Skymaster On The Way
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: KMP 337 Skymaster On The Way
Page: <<   < prev  1 [2] 3 4 5 6   next >   >>
Login
RE: KMP 337 Skymaster On The Way - 1/7/2004 12:38:32 AM
Roll On 60
Status: offline
The fiberglass booms are very good but the body is somewhat thin but I feel it will be OK.
(in reply to helokid)
       Post #: 26
RE: KMP 337 Skymaster On The Way - 1/7/2004 12:43:17 AM
Roll On 60
Status: offline
Helokid: Sorry I forgot about the price.
This plane is only worth the price if the buyer is aware BEFORE purchase of the large amount of work required above what is normal.
The seam problem really bothers me. I have never seen anything like. It is because the only paint on the booms and body is the stripes. The remainder is unpainted gel coat white.
There is no excuse for the short nose gear.
These companies need an experienced model airplane builder at the point of manufacture and these type problems would be a thing of the past.
(in reply to Roll On 60)
       Post #: 27
RE: KMP 337 Skymaster On The Way - 1/7/2004 11:09:07 PM
Roll On 60
Status: offline
Am still waiting for the Tru Turn spinners, one muffler and a couple other items from my LHS. Other then that, I am ready to go but it has to warm up a lot to venture out.
Got the pics taken today and hope to have them posted tomorrow or as soon as my friend can get to it.
       Post #: 28
RE: KMP 337 Skymaster On The Way - 1/8/2004 7:08:45 PM
Roll On 60
Status: offline
Here are the pictures of the mods I made.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 29
RE: KMP 337 Skymaster On The Way - 1/8/2004 7:11:16 PM
Roll On 60
Status: offline
Here's a couple more.
Click for fullsize
Click for fullsize
< Message edited by Roll On 60 -- 1/8/2004 2:15:01 PM >
       Post #: 30
RE: KMP 337 Skymaster On The Way - 1/9/2004 4:28:46 PM
helokid
Status: offline
Thanks for the pic's roll on 60.
       Post #: 31
RE: KMP 337 Skymaster On The Way - 1/9/2004 5:36:52 PM
Roll On 60
Status: offline
Your're welcome.
Looks like it will be a while before I get to fly it. It is just tooooo cold.
Haven't balanced it yet but will let you know what it takes.
Forget to tell you about the wire from the elevator servo. I ran it thru the horizontal stab, cut a hole in the H-stab where it connects to the boom and ran the wire up the boom into the center section of the wing.
       Post #: 32
RE: KMP 337 Skymaster On The Way - 1/10/2004 4:24:42 AM
helokid
Status: offline
hello roll on 60
I do hope the frist fligth is a good one for you. I will look forward to hear where it balances. Thanks for all the info.
       Post #: 33
RE: KMP 337 Skymaster On The Way - 1/10/2004 9:52:38 PM
Roll On 60
Status: offline
The 337 balanced with 24 ounces of weight placed on top of the front engine mount. May be able to take some off after the first flight. Will let you know. Think I may try to fly tomorrow since it is warming up some.
       Post #: 34
RE: KMP 337 Skymaster On The Way - 1/11/2004 2:21:35 AM
SAPropbuster
Status: offline
A little explanation for posts 29 & 30's pictures would be nice...
Don't know exactly what your trying to show...
So how did it fly??
TIA
--bob
_____________________________
Bob Severance
       Post #: 35
RE: KMP 337 Skymaster On The Way - 1/11/2004 2:39:43 AM
Roll On 60
Status: offline
Please see post #21. That should explain the mods.
Haven't flown it yet but hope to do so tomorrow.
       Post #: 36
RE: KMP 337 Skymaster On The Way - 1/11/2004 9:18:09 PM
Roll On 60
Status: offline
The Cessna Skymaster has flown, not well but it did fly. Analyzed the sensitive elevator and believe it will require3-6 ounces more weight. The 2 OS-61 FX's were more than enough power and it looks really good in the air. Has a long glide slope, much more than expected, and that was a surprise.
       Post #: 37
RE: KMP 337 Skymaster On The Way - 1/12/2004 12:38:07 AM
helokid
Status: offline
Hello roll on 60
Glad to hear you have flown your sky master today. Will you have to add the weight on the rear or front of the plane. What servo do they recommend on the plane. Do you think the plane will fly on one 61-fx. Can you send some pic's of the plane in full. Hope your next flight go will roll on 60. Thanks. Helokid
       Post #: 38
RE: KMP 337 Skymaster On The Way - 1/12/2004 1:33:42 AM
Roll On 60
Status: offline
The weight will be added to the nose. I now have 24 ounces and will add another 3-6. The elevator servo is a Futaba 3010 and is faster than I am used to. The plane weights in at 15 pounds with the 24 ounces of weight in the nose.
       Post #: 39
RE: KMP 337 Skymaster On The Way - 1/13/2004 8:41:18 PM
Roll On 60
Status: offline
Prior to the second flight, I added another 5 ounces of weight for a total of 29 ounces. (The plane was balanced as prescribed in the instruction manual on the first flight)
In addition, I changed the elevator hook up to a ball joint so I could get about a 45 degree angle from the servo to the control horn rod top. This allowed me to move the control point from the center of the control rod to the top, thus much less sensitive operation.
The second flight went off with out a hitch and the plane flew like a plane instead of a wounded duck. (re first flight) Was very pleased with this flight and the way the plane performed. The plane generated a lot of questions by members at the field. Had decals made to include a plane number for the wing and tail, Cessna logo and Cessna 337 for the wheel pants.
One last thing. The outer wings halves do not fit very tight on the wing tubes, so had to add some tape around the tube to get a better fit. (Andrew if you are listening, this should be fixed.)
Would I buy again, the plane is a real looker and I like good looking planes. Probably would (now that I know how to fix all the problems)but I think the importer should know about each plane imported and the problems that one would encounter and state up front these problems. One could then make an informed decision prior to purchase.
       Post #: 40
