3 Electronics questions....
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> RC Helicopter General Discussions >> 3 Electronics questions....
Page: [1]
Login
3 Electronics questions.... - 12/17/2003 9:22:04 PM
Razmo
Status: offline
Guys,
1. If I purchase a JR Tx only, Does this mean I have to buy a JR Rx?
2. Can I use any mechanical gyro? Example: Can I use a Futaba GY240 If I'm using a Jr TX & RX?
3. Can I mix Servos? Example can I use 3 Futaba and 1 Jr if I wanted?
       Post #: 1
RE: 3 Electronics questions.... - 12/17/2003 10:01:17 PM
Charlie
Status: offline
1 No- You will have to use a Hitec Rx or a universal one
2 Yes
3 Yes- Depending on the Rx, you mite have to shave the tab off the side of the Futaba servo where it plugs in.
< Message edited by Charlie -- 12/19/2003 4:55:57 PM >
(in reply to Razmo)
       Post #: 2
RE: 3 Electronics questions.... - 12/25/2003 4:45:33 PM
ChopperMike
Status: offline
Yes, you can use a Hitec RX, just make sure it's designed to work with your JR TX. Airtronics and JR use a modulation scheme called positive shift, Futaba and Hitec use negative shift. They're not interchangeable. Some of the Hitec RX's are shift switchable, some are made for a specific TX. Just make sure you get the right one.
Servos are servos. As stated by Charlie. just trim off the tab on the Futaba servo to allow it to fit into the Hitec RX. Except for very old Airtronics servos, the wiring on all servos is the same, positive in the middle, signal and negative on the outside. If you plug them in backwards it won't hurt anything. It just won't work.
As far as type of servos it's not really critical as long as they are standard servos (40 oz + torque). It's a good idea to use the same type servo on the cyclic control. If you have a CCPM heli make sure you use 3 identical servos on the swashplate.
Hope this helps,
Mike
(in reply to Razmo)
       Post #: 3
RE: 3 Electronics questions.... - 12/26/2003 5:15:57 PM
Razmo
Status: offline
Thanks Guys
(in reply to ChopperMike)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.344RCU4
