airfoil help - PLEASE!!??
Tower Hobbies
Logged in as Guest
  Printable Version
TamJets F-16 - ARF
Seller:  greenrun
Details:   $6,000.00   |  11/9/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Aerodynamics >> airfoil help - PLEASE!!??
Page: [1]
Login
airfoil help - PLEASE!!?? - 5/17/2002 3:04:57 AM
probligo
Status: offline
I am in the process of trying to understand why one of my models ( a freeflight flying wing) works as well as it does.
To this end I have been trying to compare theoretical wing twist requirements and the actual model.
The simplest formula I have found for this uses the airfoil zero lift angle as one of the parameters.
Can someone give me a formula / website / whatever where I can get the zero lift angle.
One of the more interesting sources tried thus far is Martin Hepperle's site. Fantastic resource but quite difficult to use for an old bear like me.
Thanks in advance for the help...
p.s. BTW the airfoil I am working with is a modification of the old Jedelski B6407E. In its basic form it is B64055E
       Post #: 1
Zero Lift Angle - 5/17/2002 4:05:17 AM
Ollie
Status: offline
The Zero lift angle is generally found by measurement in the windtunnel or by an airfoil simulation program like the Eppler code or X-Foil. See
http://amber.aae.uiuc.edu/~m-selig/
for this information under Low- Speed Airfoil Data.
Martin Heperle's site has this data for his airfoils. Look for the point where the Cl vs alpha curve crosses the Cl equals zero axis to find the zero lift angle.
BTW you can download X-foil from:
http://www.charlesriverrc.org/
and apply it to any airfoil you can't find at the above sites.
< Message edited by Ollie -- May 16 2002 11:19PM >
_____________________________
Regards, Ollie
(in reply to probligo)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.422RCU4
