Bipe Flyer -> RE: Printing Tiled Plans (3/12/2006 9:18:25 AM)
Well, It's all working in XP.[:D] I just finished it, so I need to do some more testing, especially on other operating systems. 1. Click on the scan button to scan the image. I scanned at 300 dpi in grayscale. 2. Select "Rotate Arbitrary..." to fix the crooked scan. It took a couple of guesses, but I added an undo so you can take more than one crack at it. This one ended up being 2.6 degrees clockwise. 3. Draw a box with the crop tool and select crop from the menu. 4. Adjust the brightness and contrast. For old mags somewhere around 50% for each works well. 5. Rotate 90 degrees clockwise and save. Whew! Lots of work, but I no longer need any other programs to scan and clean up plans before printing. YAY!
