RE: Printing Tiled Plans
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> RE: Printing Tiled Plans Page: <<   < prev  1 2 3 [4] 5 6 7   next >   >>
Login
RE: Printing Tiled Plans - 2/14/2006 6:58:51 AM
Bipe Flyer
Status: offline
OK, how's this? I printed one up for myself and put it in my bookcase with some of my other prized posessions.
You can download it from http://www.blackflight.com/tileprint/Tile_Print_CD_Cover.jpg Open it in Tile Print and set the width of the top image to 4.75".
Click to see fullsize image.
Click for fullsize
_____________________________
1/2A all the way!
Club Saito #151
(in reply to build light)
       Post #: 76
RE: Printing Tiled Plans - 3/5/2006 1:49:41 AM
Bipe Flyer
Status: offline
I'm looking into adding scanning, so you can scan or capture directly into Tile Print from a scanner or webcam. Worthwhile?
1/2A all the way!
Club Saito #151
(in reply to Bipe Flyer)
       Post #: 77
RE: Printing Tiled Plans - 3/5/2006 2:22:26 AM
ptulmer
Status: offline
It would make dealing with magazine plans a very easy process. No more importing. Sounds worthwhile!
HomeMachinist.net!
Ulmer-RC.com
       Post #: 78
RE: Printing Tiled Plans - 3/5/2006 2:24:26 AM
Raymond LeFlyr
Status: offline
I guess it would eliminate a step. Would you price it as an add-on, separately?
"I am NOT an animal!!!"
       Post #: 79
RE: Printing Tiled Plans - 3/5/2006 2:26:29 AM
build light
Status: offline
I would answer a big yes!
Robert
Keep'er light, and she will treat you right!
       Post #: 80
RE: Printing Tiled Plans - 3/5/2006 2:59:06 AM
flybug
Status: offline
Can't wait to download that update
My grandfather always said that living is like licking honey off a thorn. - Louis Adamic
       Post #: 81
RE: Printing Tiled Plans - 3/5/2006 3:26:50 AM
Bipe Flyer
Status: offline
No extra money. I'll add it then.
1/2A all the way!
Club Saito #151
(in reply to flybug)
       Post #: 82
RE: Printing Tiled Plans - 3/8/2006 12:16:18 AM
Bipe Flyer
Status: offline
I got the scanning figured out. Of course that means that I had to add arbitrary rotating and brightness/contrast. The rotating was the hardest part. You know how back in high school you never thought you'd need trigonometry? Now I have to figure out how to make it all work on Windows 98. !@#$% different operating systems.
1/2A all the way!
Club Saito #151
       Post #: 83
RE: Printing Tiled Plans - 3/8/2006 12:47:02 AM
build light
Status: offline
I have ended up using all manner of junk education! Turns out it wasn't really junk after all!
Little did we know...
Robert
       Post #: 84
RE: Printing Tiled Plans - 3/12/2006 9:18:25 AM
Bipe Flyer
Status: offline
Well, It's all working in XP. I just finished it, so I need to do some more testing, especially on other operating systems.
1. Click on the scan button to scan the image. I scanned at 300 dpi in grayscale.
2. Select "Rotate Arbitrary..." to fix the crooked scan. It took a couple of guesses, but I added an undo so you can take more than one crack at it. This one ended up being 2.6 degrees clockwise.
3. Draw a box with the crop tool and select crop from the menu.
4. Adjust the brightness and contrast. For old mags somewhere around 50% for each works well.
5. Rotate 90 degrees clockwise and save.
Whew! Lots of work, but I no longer need any other programs to scan and clean up plans before printing. YAY!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Bipe Flyer -- 3/12/2006 9:34:48 AM >
1/2A all the way!
Club Saito #151
       Post #: 85
RE: Printing Tiled Plans - 3/12/2006 11:13:09 AM
DICKEYBIRD
Status: offline
Wow that's awesome Andrew! Reckon it'll work in Win 2000?
"He who dies with the most good Cox engines wins!"
       Post #: 86
RE: Printing Tiled Plans - 3/12/2006 11:40:06 AM
Bipe Flyer
Status: offline
To do some of the image manipulation functions it uses GDI+, which comes with Windows XP. For other versions of Windows, you just need gdiplus.dll installed.
Here's the info from Microsoft:
Redistributable files for GDI+.
System Requirements
Supported Operating Systems: Windows 2000; Windows 98; Windows ME; Windows NT; Windows XP
So the short answer is yes, it should.
< Message edited by Bipe Flyer -- 3/12/2006 11:41:18 AM >
1/2A all the way!
Club Saito #151
(in reply to DICKEYBIRD)
       Post #: 87
RE: Printing Tiled Plans - 3/12/2006 1:00:22 PM
g-rock
Status: offline
Bipe Flyer
I do most of my scans in black and white (monochrome). I am wondering why you chose grayscale as an example.
Gene
       Post #: 88
RE: Printing Tiled Plans - 3/12/2006 2:54:09 PM
build light
Status: offline
I too do most of my scans in the black and white. Previews are much faster and oft times the yellowing of old paperor sometimes the lighter colored backgrounds found in some plans just plain does not show up thus making clean up not at all or at the least much easier.
Robert
(in reply to g-rock)
       Post #: 89
RE: Printing Tiled Plans - 3/12/2006 6:09:20 PM
