Cant keep savage running.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> HPI Monster Truck Forum >> Cant keep savage running.
Page: [1]
Login
Cant keep savage running. - 12/23/2003 12:35:06 AM
Crash90
Status: offline
I cant keep my savage 25 running. I get it started. Sometimes it shuts right off, other times it will just shut off at mid RPMs. Sometimes it shuts off when I goose the throttle and sometimes when I let off the throttle. Please help.
       Post #: 1
RE: Cant keep savage running. - 12/23/2003 12:48:34 AM
SavageRCRacer
Status: offline
Put a new plug in it. If its not that then your way off tune.
(in reply to Crash90)
       Post #: 2
RE: Cant keep savage running. - 12/23/2003 12:51:23 AM
Crash90
Status: offline
Thanks. Can anybody give me detailed instructions on how to set the needles back to the factory settings? On the low end. Do I need to open the throttle to screw the low end all the way in?
(in reply to SavageRCRacer)
       Post #: 3
RE: Cant keep savage running. - 12/23/2003 3:33:12 AM
Dr.ArmoMaxx
Status: offline
it should be in the manual, how to set and etc.
_____________________________
Full throttle or go home.
       Post #: 4
RE: Cant keep savage running. - 12/23/2003 4:31:28 AM
rcmtdriver2000
Status: offline
Put an o.s. #8 plug in it unless it's REALLY cold by you then get one slightly warmer like an o.s.A3 plug. Make sure you keep it indoors til it's time to start it. If changing the plug doesn't work consult the manual before you tweek on those needles. If it's too cold out then you'll want to run it slightly (and I mean slightly) hotter than in the spring.
Epicmaxx
There are alot of hobby shops able to help break the 2.5 habit
(in reply to Dr.ArmoMaxx)
       Post #: 5
RE: Cant keep savage running. - 12/23/2003 11:43:26 AM
smitty70
Status: offline
I've noticed that if I flood the engine a little it is hard to start like that. The best way to get it going is to either pull out the plug and spin the engine or if you can get it to idle slowly give it throttle until it is cleaned out.
(in reply to rcmtdriver2000)
       Post #: 6
RE: Cant keep savage running. - 12/23/2003 12:34:28 PM
SH ByA
Status: offline
I would put a new plug in it, and take all your settings back to factory and start over. I know its a pain, but its prob the best thing to do at this time.
(in reply to smitty70)
       Post #: 7
RE: Cant keep savage running. - 12/24/2003 8:21:06 PM
speeddemon-RCU
Status: offline
look at the fuel line some times it can get caught between the tank and frame
(in reply to SH ByA)
       Post #: 8
RE: Cant keep savage running. - 12/25/2003 4:07:41 AM
Crash90
Status: offline
Thanks guys. Replaced the glow plug and all is well.
(in reply to speeddemon-RCU)
       Post #: 9
RE: Cant keep savage running. - 12/28/2003 4:13:28 AM
supernova803
Status: offline
That happened to me today after i messed with the settings. Turn the high speed needle 3 and a 1/2 turns out from closed, and the low speed between 2 1/2 to 3 turns out. Also since the tank is pressurized push the gas tank lid down tight.
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.969RCU3
