HarryC
Joined: 2/10/2002 From: private, UNITED KINGDOM Status: offline
I was so sure that the elevator on mine was going much faster than the soft phase switch that I have done a little experimant and proved it - I did it with the elevator but it applies to any control that is moved while the soft transition is in progress. The soft phase switch takes approx 1 second according to the manual. Subjectively I feel it is less than that. Anyway, if a control is moved once the phase transition has already started, that control ignores the phase transition and goes straight to the new phase, without taking part in the soft transition. This means that if you move the phase switch to 3D phase and then after that you pull full up elevator you instantly get 3D phase elevator travel (or whatever control you moved) even while all the other controls are still moving through the soft transition. For example, in normal phase put on full elevator then switch to 3D phase and then immediately put on full aileron. The elevator will travel at the transition speed because it was applied before the phase switch but the aileron will instantly go to full 3D travel even while the elevator or other controls are still in transition. If you are getting the soft transition of the elevator when switching to 3d phase it is because you are moving the elevator control fractionally before or at the same time as you move the phase switch. As long as you move the phase switch fractionally before you start to move the elevator stick you will get instant 3d phase travel without waiting for the soft transition to work through. You can prove this to your own satisfaction using the servo monitor screen. Set the flap control fixed value to Off for the normal phase and 100% for the 3D phase and assign a servo to flap. In the monitor screen you will see it travel through the soft transition time. Hold on elevator before moving the phase switch and see the elevator travel at the same reduced speed as the flap. Now move the phase switch first and then promptly move the elevator stick, the elevator servo goes straight to 100% travel at full speed, overtaking the flaps which are still going through the phase transition. You need to be quick and get your timing right to see it, but it is most distinctive and definitely there. I wouldn't call the lack of expo per phase a killer or in any way giving the Evo a functionality below an 8103, the Evo can do so much much more than an 8103, I would still choose an Evo over any Asian radio, but each to his own. H
< Message edited by HarryC -- 1/26/2004 10:55:48 PM >
