Friend's Evader ST
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> Friend's Evader ST
Page: [1]
Login
Friend's Evader ST - 12/23/2003 9:41:39 PM
z style
Status: offline
My friend just got into the rc nitro world and got a evader st. i was wondering since its 2wd would it be possile or is there any kits to make it 4wd? can you chagne it from 1 speed to 2speed or would you have to custome make that? is there anything he should upgrade right away? i.e. the stock pipe is bad soemthing like that
thnx
       Post #: 1
RE: Friend's Evader ST - 12/24/2003 2:10:13 PM
sdarviavgeer1521
Status: offline
i have an evader st and i think its fine how it comes unless he really really wants to do some hopups to it. it is pretty fast as it is so i dont think he would need a 2 speed if they make one for an evader. the only thing i would recommend getting is some better tires if he hasnt already. if he is going to be driving a lot offroad then proline masher 2000 or dirt hawgs would be great for that. the mashers are a lot bigger but it doesnt slow the car down very much at all with the DTX .18 engine so it is all preference when it comes to that.
(in reply to z style)
       Post #: 2
RE: Friend's Evader ST - 12/26/2003 1:13:21 AM
ninjaspeed
Status: offline
hey, maybe you guys can help me with nitro my evader st. i recently broke in the engine, and now it doesnt want to start. the glow plug is fine, the batt is fine, it something to do with the tuning. i tried to adjust the low speed needle, (i know, stupid thing to do) and now it wont idle correctly. and some times it wont start at all! when i do get it started, as soon as i give it some gas it stalls. i looked in the manual and it doesnt say how many turns out the low speed needle should be. please help!
_____________________________
Ninjas are alright I guess.
(in reply to sdarviavgeer1521)
       Post #: 3
RE: Friend's Evader ST - 12/26/2003 1:26:46 AM
CaNaDiAnRaCeR
Status: offline
Wow, you really screwed yourself .....Naw I'm joking. There is a
simple way of adjusting the low-speed needle correctly called the
“pinch test.” With the engine at idle, pinch the fuel line and listen to
how the engine speeds up or slows down. If the engine increases
its speed for about 3 or 4 seconds and then loses speed, the
needle is set correctly. If the engine loses RPM quickly, it is set too
lean and the low-speed needle needs to be opened
(counterclockwise) to richen the mixture. Pinch again to check the
mixture. If the engine takes longer than 5 seconds to slow down,
lean (clockwise) the low-speed needle and then pinch again to check the mixture.
(in reply to ninjaspeed)
       Post #: 4
RE: Friend's Evader ST - 12/27/2003 11:37:23 PM
insported
Status: offline
i had the same prob with mine but what i did was i loosened my glow plug and stuck the ingniter on and if it started than i knew i had the lean the mixture cause there was to much gas and not enough air hope you get my point
(in reply to CaNaDiAnRaCeR)
       Post #: 5
RE: Friend's Evader ST - 12/31/2003 3:53:48 AM
Medictool
Status: offline
A number of things.........and yes you should adjust the low speed settings. 1-1/2 screw out its the minimum for the high speed, my low is at 1-1/4 out... it all depends on altitude, but this will get you back to a normal realm. If you are using Dts glow ignitor..toss it. Very poor and short lived. I use A3 plugs from OS. Also, a starter box is great to use.
(in reply to insported)
       Post #: 6
RE: Friend's Evader ST - 12/31/2003 4:39:29 AM
nitroguy123
Status: offline
i dont think u will find a kit to make it 4wd. just not a practical(and money wise) thing to do. As for the 2 speed you might be able to fit the one from other duratrax vehicles but you would have to modify it to fit. There arent any bad parts on this truck that needs to be upgraded that ive come across. Stock it has some great hop ups already on it.
(in reply to Medictool)
       Post #: 7
RE: Friend's Evader ST - 12/31/2003 11:42:13 PM
Old Bill
Status: offline
I've been running a Nitro Evader for about 7 months now. A few things come to mind. First, have your friend get an inline fuel filter, second, use an O.S. A8 glow plug, and third, if your doing some hard running, or racing, that involves jumps and hard turns, get a high torque, metal gear steering servo. The other posts gave you advice on setting your carb, but also check your compression to make sure it was broken in correctly. If you can turn the flywheel easily by hand, then you may have engine damage. This can also cause hard starting and bad idling. Good luck.
Bill
(in reply to nitroguy123)
       Post #: 8
RE: Friend's Evader ST - 1/2/2004 12:43:48 AM
ComBatMan2k3
Status: offline
i have had my evader st for well since june i think ive bought almost al lthe blue aluminum upgrades for it, i added a wing to the rear just for looks, changed the tires around using dirt hawg 2s on the back and front, im using a different tuned pipe but icant remember who makes it, i have the golden horizens blue cooling head, inline fuel filter, a larger spur gear originally for the rc10gt for more torque, but i had to cut a little outta the rear arm with my dremal to make it fit, have hard anodized shox on the rear and normal ones on the fron with hard springs all way round i have 2 main set ups for the truck off road and street, for street i put the front shox on the rear and i have a set of front hard anodized shox for the front again using hard shox, i have a set of striker 2s on the front and road hawgs on the rear the ground clearence for the street if almost next to nothing so i have to be careful where i drive it oh and i use a spur gear out of a evader bx for the street and the bigger one for the dirt..custom made a front bumper out of aluminum cuz i didnt like the little plastic one...i have about a couple of hundred $$ invested in it is a sweet truck just too bad there isnt a 2 speeder in it..for the street i think it does about 50mph my freidn clocked it on the radar last wknd at around 49mph..just a whizzen along and for the off-road set up i can get the front end up for wheelies..any way i suggest gettin all the hop ups u can find and be the envy of other rcers oiut there
(in reply to Old Bill)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.906RCU3
