nothinglasts -> RE: Multiplex Easy Star, construction, flight report (2/19/2006 4:41:12 AM)
Hi, I don't have ARF instructions as I bought the RTF package but a couple of things which could help are: Use three capacitors on the motor, 2 go from each motor terminal to the body of the motor which are usually 0.1 micro farads (104 is written on the capacitor) and one between the terminals 0.047 micro farads (labelled 473). You can also install a 3A or 5A schottky diode between the terminals (must have the banded side to the +ve terminal) part no SB540. Different speed controllers might have their own noise supression built in but it doesn't hurt to be safe and install the whole lot. How do I know this? I made the mistake of modifying my beautifully flying Easystar with a high powered Cobalt motor and have so far been through 2 motors, 2 speed controllers, 3 props, 7 capacitors, 3 diodes, tape, glue, 12+ hours of labor trying to get it flying right. My plane looks like sh*t from glitches causing many crashes and I wish I had left it the way it was. Yes the motor only uses two wires, the RTF kit motor wires were run in the foam above the wing then down to the cockpit which is good to separate them from the receiver antenna which exits the cockpit under the receiver and travels to the back under the fuselage in the pipe provided. Don't need to use glue, use double sided tape for assembling the whole plane including the motor. It's not too hard to remove the motor later by sliding a knife between the motor and foam. The RTF kit is assembled using tape and I have removed my motor and reinstalled it at least 10 times. I have also stripped the plane down completely to repair it and then reassembles using double sided tape. Just make sure the tail is stuck on good as mine came off mid-air and caused the worst crash so far. Hope this helps, Josh.
