jkkrobbins
TX, USA Status: offline
It's true what you say about brushless. Certainly you would get greater battery efficiency with a brushless motor in the Easy Star. While there's no downside to going brushless, I still say it would be overkill. Another thing to think about is the cost of the stock motor. I bought a couple for $5 each. Recently, I ordered 5 for $12. Yes, the brushes burn out every few months with very heavy use. Replacement is no problem but brings to light the one area for improvement with the Easy Star - the way the motor is mounted. To replace the motor, you have to cut the halves apart, glue the new motor in, and resolder, etc... (Though I have seen postings where folks have built hatches and other means to make the motor even more accessible.) That said, I couldn't be happier with the Easy Star, using the stock motor and propellor with a 2 cell 4000 mAh LiPo. I will be purchasing brushless stuff at some point in the future. But I'll be putting in the Hobbico Super Star. That plane needs it much more, as the run times are low with the stock NiCD batteries and only improved slightly with NiMh. The LiPo brushless upgrade would buy me much more in that plane. Again, absolutely nothing wrong with putting brushless in the Easy Star. Only dollars. I'm saying upgrade something that needs it more. The Easy Star is such a sweet plane as it is that my humble opinion is that brushless is not required. Try it with the stock motor and a 2 cell LiPo (like I said, 4000 mAh and it should still be tail heavy). You can always upgrade. I think you'll be very impressed.
