RE: Multiplex Easy Star, construction, flight report (Full Version)
All Forums >> [Electric Aircraft Universe] >> Electric Training
Message
landing-gear -> RE: Multiplex Easy Star, construction, flight report (11/30/2007 6:32:23 AM)
Good aye all
The ES is my third plane and my most relaxing plane to fly, a club we visited some weeks ago had more ES's than all the other planes combined so when I asked why? They all said the same thing 1/ easy to build,fly,repair
So I decided to try one out and it's the best plane in my fleet - I love it, anyway will post some flight reports and pic's soon.
Cheers for now Lawrence
Andrew86 -> RE: Multiplex Easy Star, construction, flight report (11/30/2007 8:11:30 AM)
This was my second plane and I wish it was my first, it would have saved me some money! It's the perfect plane to just throw up and fly, it's rock solid in the air and will glide forever. The Elapor foam that multiplex uses it simple to repair as it can be glued back together in seconds with every day household superglue.
One point of advice would be to install a brushless power system from the word go. When building this plane, two halves of the fuselage are glued together with the motor in between the halves, once a motor is installed it is very difficult to change or upgrade. A brushless motor gives this plane enough power to easily get through even strong winds and also gives you more than enough power to get out of a bad situation. It also means that you can take off from the ground (without landing gear!) which is fun.
My set up:
- Himax (Himark if you're in Australia) 2815-2000 (2000kv) inrunner: http://www.maxxprod.com/pdf/HB2815-xx00.pdf
[This motor is a drop in perfect fit, and mirrors the dimensions of the brushed 400 motor it came with.
- E-watts 25A brushless ESC
- 2 x Hitec HS81 Servos
- 3S 2170mah 11.1V LiPo
- APC 6x4E prop
This plane is perfect for ANYONE who wants to learn to fly quickly, and the brushless motor upgrade makes this plane complete, it will float around the sky at a little over walking pace or scream along thanks the the extra power.
Just thought i'd add to what Lawrence had to say, this plane has a big following!
landing-gear -> RE: Multiplex Easy Star, construction, flight report (12/3/2007 2:20:59 AM)
Cheers Andrew
I glued both halves except around the area near the motor and used heat proof double sided tape to put the motor in and tape the area with reinforced tape. One trick I have picked up on was the prop they supplied is to big for my prop adaptor (slightly) to get around this I used a piece of heat shrink on the PR and perfect fit. I thought the Himark would fit, Peter Pines web site states it's a straight swap, but if I join this club I want to fly in their 400 speed comp and "No brushless allowed" so it's a wait and see.
Your right about "wish it was my first" me too, the amount of money I've spend repairing planes that really weren't "beginners" but we live and lear....crash!!
I have a few different props coming so I can test her performance out, but i love how it glides and where I fly there are heaps of thermals so I can stay up all day - well till the neck gets sore.
For all you "seasoned flyers" who think this plane is for the kids - well I thought that too - that is till I flew one and if I never buy another plane again I'm happy flying the Easystar.
Cheers lawrence
landing-gear -> RE: Multiplex Easy Star, construction, flight report (12/5/2007 5:16:50 AM)
I found "thermal alley" and the ES loves the place, not once did l flatten a battery every flight was 15 - 20min and when my neck start to hurt l would land and have a break, we started flying at 6-30am and finished 11-30am and l must have put 10+ batteries thru the ES.
When ever the plane was to high l would pull out of the thermal and put her into a dive throw a loop in and glide back over to the start area - some full throtle to get height and start hunting the next one [:D][:D]
Cheers Lawrence
ecase -> RE: Multiplex Easy Star, construction, flight report (12/6/2007 10:11:45 PM)
Do you have 10 batteries, or just a quick charger? How long does it take to charge a battery? Do you let them cool before you charge them?
Evan
landing-gear -> RE: Multiplex Easy Star, construction, flight report (12/7/2007 11:32:51 AM)
quote:
ORIGINAL: ecase
Evan
Hi Evan
No I have 3 x 8.4V 1200Mah Nims which are slow charged (0.3A) the day before, then on the day I fast charge at 1.2A, the trick is not to totally flatten the batteries. So whats happens is I load the first battery and fly for 15 -20 min's (lots of gliding/thermaling) I still have 2 batteries that are fully charged from the day before so the flight battery goes into a small esky/cooler with an ice brick in it, I might have a quick coffee or drink etc then in goes the second battery.... go flying etc then the first battery is removed from the cooler and put on quick charge, second battery goes into esky/cooler, third battery is in plane another break/breather then off for another flight now the first battery will take 15 - 20 min to peak and as soon as it does my flying mates will remove it and place the one in the cooler on charge for me, l land the plane third battery goes into cooler and it all starts again.
The trick is simple instead of using 2 batteries and totally flating them which mean it will take approx 45 - 60min to recharge each battery - I use 3 batteries and try to only use 50-75% of there power so the recharge time is shorter. My mate uses 4 batteries and 2 chargers and he can fly non stop all day but if you are using the motor full time you will get approx 13-15min flights and totally flat batteries.
One thing as well I am only running the standard 400 motor in the ES as well - it has plenty of power.
Cheers lawrence
ecase -> RE: Multiplex Easy Star, construction, flight report (12/7/2007 3:02:25 PM)
I have four lipos, 3 cell. I should be able to fly all day too. It is fun to see the EZ up there but its even more fun to see a clean safe landing, I have had plenty that weren't.
Thanks again,
Evan
landing-gear -> RE: Multiplex Easy Star, construction, flight report (12/8/2007 12:14:42 AM)
quote:
ORIGINAL: ecase
Thanks again,
Evan
Hi Evan
The trick to have good landing is first go over your COG by test glide/landing - with all controls at neutral throw your plane firmly but not hard and watch what it does, try to do all this on a calm morning, if it is turning one way or the other adjust the rudder as needed.
If the plane flies level,loses speed and then nose dives in the COG is slightly toward the tail so add a small amount of modelling clay up in the nose and test again, lets say you put a heap of clay in and the plane is now slightly nose heavy it may during the test after release glider towards the ground quickly and land more towards it's nose plus in lands within 15 feet of you when the COG is spot on the plane floats for 20+ feet from a hand launch and lands along on it belly. It take time to setup correctly but the benfits are a ES that glides so easily and with a small adjustment of up elevator (using your trim) it thermals for hours.
So the next time you have an hour to kill grab your plane and batteries and carry out some test glides and have some fun.
Cheers lawrence
PS all my landing are done "dead stick" = no power no matter how the battery holding
ecase -> RE: Multiplex Easy Star, construction, flight report (12/10/2007 3:07:24 PM)
I have a COG balancer and I am pretty sure the COG is correct. Most of my bad landings were a year ago when I was learning. I had one early this past summer, due to pilot error, that destroyed a nice EZ. I have a new one now.
Evan
evadeom -> RE: Multiplex Easy Star, construction, flight report (12/12/2007 3:30:17 PM)
Hi, I've enjoyed reading the above posts. I'll be putting the Easy Star together right after Christmas but in the mean time have been reading the instructions. I'd appreciate if someone can explain the last sentence on page 16, "The distance to the fulcrum from the servo motor lever should be approx 10mm." I think I know what a fulcrum is but can't really see it in Fig 13. Thanks in advance and happy holidays.
El CID -> RE: Multiplex Easy Star, construction, flight report (12/12/2007 7:47:43 PM)
For those with The Phoenix Simulator the latest aircraft to be added is the 'Easystar'
landing-gear -> RE: Multiplex Easy Star, construction, flight report (12/12/2007 11:04:10 PM)
quote:
ORIGINAL: evadeom
Hi
Before fitting the servo's in place and with the control horn screwed in place measure from the screw out along the control horn 10mm and mark the nearest hole with a black felt pen, then sit the servo into fuse - no glue yet - and see were the mark on the control horn sits, it should be level with where the the control linkage/wire is going to run along the side of the fuse.
Cheers Lawrence
evadeom -> RE: Multiplex Easy Star, construction, flight report (12/13/2007 12:43:53 AM)
Thank you Lawrence, that makes sense to me now. I'll be using the HS-81. If I find that the HS-81 doesn't sit all the way in the nest to achieve the 10mm, I suppose I can add some thickness with couple layers of shrink wrap or tape. Thanks again.
landing-gear -> RE: Multiplex Easy Star, construction, flight report (12/13/2007 12:57:08 AM)
quote:
ORIGINAL: evadeom
Hi
A good way to "thicken" the servo that I've used in the past is hot glue a piece of balsa to the side of the servo ie 3mm and then place your shrink wrap around the servo so later if you need to use it in something else slice it out of the wrap and cut away the balsa and hot glue
Cheers lawrence
evadeom -> RE: Multiplex Easy Star, construction, flight report (12/13/2007 1:55:35 AM)
Great idea Lawrence. Do you then use hot glue or CA to attach the servo to the Elapor? Sounds like hot glue removes easier if I should ever need to remove the servo. Thanks again.
calvino -> RE: Multiplex Easy Star, construction, flight report (12/13/2007 2:00:25 AM)
I am currious if anyone has tried it out with like a GWS EPS-400C geared motor, I wonder if that would help with the power issue, looks like an AWESOME plane[8D]
landing-gear -> RE: Multiplex Easy Star, construction, flight report (12/13/2007 2:38:18 AM)
Hi
I used CA on the shrinked wraped servo, what i really wanted was a servo holder that some planes have on there wings but there not available here in Oz.
Calvino
I'm using the stock 400 motor with no problems at all, I can launch at full throtle in calm conditions and it will climb out without me touching the Tx [:-]look no hands[X(] some guy's are just using lipo's which is giving them more power with the stock motor.
Remember to carry out the wing mod before cutting loose with a more powerful motor.
Cheers lawrence
calvino -> RE: Multiplex Easy Star, construction, flight report (12/13/2007 2:58:29 AM)
quote:
ORIGINAL: landing-gear
Hi
Calvino
Cheers lawrence
just currious what the "wing mod is"
landing-gear -> RE: Multiplex Easy Star, construction, flight report (12/13/2007 4:11:12 AM)
Hi
This site has heaps of mods but this is the link to the wing mod
EZ Wing Mods
Cheers Lawrence
calvino -> RE: Multiplex Easy Star, construction, flight report (12/13/2007 6:25:45 AM)
Hi
EZ Wing Mods
Cheers Lawrence
WOW, great site, I showed it to my dad who liked it a TON more than the SS, just currous about the flight charaistics, considering i am a newbe[:D], any clue what size prop to run.... plan to get the kit, since i have 2 HS-55 servos, a Berg 4L reciever, and hopefully a 3s lipo[:D][:D][:D], so, anything i am missing, the control surfaces looked prety darn tiny, any way to make them a little bigger, so, let us say, you are flying in a tight suitiation, you can control it better.... just curriuos, thanks alot, calivn[8D]
evadeom -> RE: Multiplex Easy Star, construction, flight report (12/13/2007 3:17:00 PM)
Yeah, the rudder control surface does seem small. What I've seen done to increase that are a couple of business cards taped on each side. I'll plan to give it a go as it is and try the business cards later.
ecase -> RE: Multiplex Easy Star, construction, flight report (12/13/2007 3:20:43 PM)
I made a new, larger rudder out of the elevator of an old EZ. It work great.
Evan
landing-gear -> RE: Multiplex Easy Star, construction, flight report (12/13/2007 9:29:31 PM)
Hi Calvino
Sorry mate I'm running the standard motor and prop but I read that with the stock 400 motor you can using a prop adaptor put a 6x4 on it. In the instructions it states to glue the prop on - I recommend to fit a prop adaptor and clamp the prop on.
As for it handling....it takes off from launch like an old WW2 bomber, it lumbers out there and slowly gains alt, it will turn either way with any breeze so trimming can be a bit hard if there's a breeze around. I'm using the stock rudder and have had a couple of dog fights with my mates electrafun and the trick with turning quick is you must have power on. it glides around great, thermals very easily and can loop, barrel round as well.
Landing, well I come in dead stick no power so any breeze pushes it around a bit but alittle power will keep her straight, I have to give down elevator as our landing area is short with a tree at the start and the EZ will glide along for 100's of meters if there's a breeze.
Cheers Lawrence
calvino -> RE: Multiplex Easy Star, construction, flight report (12/13/2007 11:52:34 PM)
Hi Calvino
Cheers Lawrence
ok, thanks, it is this kindof info that is helpful[:D]
java2d -> RE: Multiplex Easy Star, construction, flight report (12/14/2007 11:22:57 PM)
I have read most of the posts in this thread regarding batteries. I am going to purchase the EZ in an ARF version and want to purchase a lithium battery and charger for it. Can anyone recommend a battery and charger and a vendor? I thought this would be easy, but the choices are too many.
Page: <<   < prev  1 2 3 [4] 5   next >   >>
Valid CSS!
SITE MAP!   : :   FORUM RULES
0.359375
