RE: Multiplex Easy Star, construction, flight report
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric Training >> RE: Multiplex Easy Star, construction, flight report
Page: <<   < prev  1 2 3 4 [5]
Login
RE: Multiplex Easy Star, construction, flight report - 12/15/2007 1:07:08 AM
calvino
Status: offline
quote:
ORIGINAL: java2d
I have read most of the posts in this thread regarding batteries. I am going to purchase the EZ in an ARF version and want to purchase a lithium battery and charger for it. Can anyone recommend a battery and charger and a vendor? I thought this would be easy, but the choices are too many.
Try Commonsense RC, my friend runs their lipos in his hyperflea, NO PROBS, the prices are AWESOME, they also have a balencer that you can plug into a lipo charger to BALLENCE the cells, not just stop at the first cell that fills up
_____________________________
RC18T, RC10Goldpan 1980, Radio Shack (?), Slow Stick (BL)
(in reply to java2d)
       Post #: 101
RE: Multiplex Easy Star, construction, flight report - 12/15/2007 11:45:31 AM
java2d
Status: offline
I have found a Lipo battery at common sense rc (7.4 volt - 2000mAh 10C Li-Poly Pack #2S2000-10) with dimensions of 18mm x 33mm x 84mm. That is about 24 mm longer than the stock battery that comes with the RTF version. Can someone tell me if it will fit?
(in reply to calvino)
       Post #: 102
RE: Multiplex Easy Star, construction, flight report - 12/15/2007 5:31:21 PM
java2d
Status: offline
In inches the LxWxH is 3.3"x1.3"x.7" for the LiPo from common sense, whereas the stock battery is 2.4"x1.34"x1.25". The only thing I need to know is whether the plane will take the extra length of .9 inches.
       Post #: 103
RE: Multiplex Easy Star, construction, flight report - 12/31/2007 3:39:14 PM
evadeom
Status: offline
Wishing all a Happy New Year! I'll soon be using the Optic 6 with my new Easy Star. Mode II is more commonly used within the US, which is elevator on right stick and throttle & rudder on the left stick. I find it easier to fly with the rudder & elevator on the right. This is the case with learning to fly the Easy Star in FMS. Does anyone see any problems or disadvantages with this? I imagine that either set up is a matter of personal preference but there must be reasons for Mode II that I'm not seeing right now as a beginner. I appreciate any advice. Thanks in advance.
       Post #: 104
RE: Multiplex Easy Star, construction, flight report - 1/1/2008 12:32:34 AM
landing-gear
Status: offline
Hi Evadeom
Happy NY from Oz
Here down under most of our radio's are Mode 1 ie throtle/rudder right stick but because alot of hobby shops here bring in RTF planes from the USA and some can only be used in mode 2 and the problem comes when you move on to bigger and better planes and join clubs because they all fly in mode 1 (in Oz) and will train you in mode 1.
So back to your question if in the US if mode 2 is mostly used then set up the FMS as mode 2 and get practicing
Cheers Lawrence
"Oh bugger who put the earth there!"
"This is gunna hurt"
(in reply to evadeom)
       Post #: 105
RE: Multiplex Easy Star, construction, flight report - 1/2/2008 1:44:15 AM
evadeom
Status: offline
Lawrence,
Happy New Year to you too. I'll stick with Mode II and practice more with it. Makes sense to learn it right at the get go. Thanks again.
Evadeom
(in reply to landing-gear)
       Post #: 106
RE: Multiplex Easy Star, construction, flight report - 1/2/2008 3:53:37 AM
Black Arrow
Status: offline
Add another vote for the Easy Star. Motor in back where it's safe in a crash. Super durable. Comes with everything you need for around $180 from Tower Hobby. Very gentle flyer that can be flown very slowly if there's not much wind. It's big so you can really see it. You can get 10 minute flights easily with a little throttle management. I love to get mine up high, shut the motor completely off and look for some lift. Will fly in winds up to about 8 mph on my Davis Windmeter without any real anxiety and will fly in a bit more wind if the pilot has the skills. If you need parts a whole kit that has ALL the parts less electronics is only around $60. You can get all the help you want with this plane becasue there are so many people flying them (gee, ya think there's a reason for that?). There's even an Easy Star web site where guys from all over the world talk about what they've done with their E.S. http://www.mpx-easystar.de/ and there's the never ending E.S. thread over on Ezone. The main downside to the ES that comes to mind is that it really glides well and so you need a decent sized open area to land in especially in the beginning. The required area gets smaller as you get some experience.
I guess you could say I like my plane! I also like my combat Wings XE2 and my Whisper 2 flying wings . Never would have gotten to those wings without the ES but that's another story for another time.
(in reply to badius)
       Post #: 107
RE: Multiplex Easy Star, construction, flight report - 1/22/2008 1:55:42 AM
evadeom
Status: offline
Hi everyone. I'm just about finished building the Easystar. Should the wing be fairly easy to take apart? I made sure that the spar connector was not glued to the wing. I know that because prior to inserting the wing into the fuselage, I was able to connect the wing and disconnect. I did this a couple of time before connecting it to the fuselage. Now the wing is connected to the fuselage and I'm having a heck of a time separating it. Is there a secret or tip to detach the wings from the fuselage? I've been pulling quite hard but at the same time feel that any harder I might break something. Do I start separating the wings from the leading edge? Any advice is greatly appreciated. Thank you.
(in reply to Black Arrow)
       Post #: 108
RE: Multiplex Easy Star, construction, flight report - 1/25/2008 8:38:50 AM
landing-gear
Status: offline
quote:
ORIGINAL: evadeom
Hi
It sounds like you may have accidently glued the wings and fuse together because they pull off very easy thats why some of us put magnets in the ends so to keep them together while flying. I grab the fuse and pull the left hand wing (nose of plane facing you)and it pops out quite easily then the other side slides out with the spar in it, remove spar and throw into car
Simple
Cheers Lawrence
       Post #: 109
RE: Multiplex Easy Star, construction, flight report - 1/25/2008 3:14:58 PM
evadeom
Status: offline
Thanks Lawrence. I probably put too much CA in the wings and should have waited for it to dry before inserting the spar connector. I'm pulling harder than it seems necessary and still it isn't budging. Guess I'll just have to make room when during transport. I was tempting to cut out the spar connector but I might get myself into bigger mess. I'll see how it goes. I appreciate your help.
       Post #: 110
RE: Multiplex Easy Star, construction, flight report - 1/25/2008 3:19:38 PM
ecase
Status: offline
There are many guys who glue the wings in to prevent an in-flight accident. It shouldn't be a big problem.
       Post #: 111
RE: Multiplex Easy Star, construction, flight report - 1/25/2008 6:07:37 PM
evadeom
Status: offline
Yeah, that's probably the route I'll take. Thanks.
(in reply to ecase)
       Post #: 112
RE: Multiplex Easy Star, construction, flight report - 1/30/2008 3:37:58 AM
landing-gear
Status: offline
Here is a first
Well for me anyhow Forget about birds chasing your RC planes because today I had a grey kangaroo chasing mine and not once but twice
The first time was when coming in to land the ES and gliding in from approx 150 m out as the plane got down to about 1m from the ground a grey roo that was 25m away to the right started hopping up behind the ES and as it came into land (near our table) the roo turned away and hopped back down to the long grass.
3 flights later and running down my last battery the roo's had moved out onto the short grass and while practicing some low level flying "Skippy" decided that thing in the sky had to go and chased the ES (running approx 15% throtle)backwards and fowards in front of us, I was laughing so hard I nearly landed but up'ed the throtle and the roo got within feet of the ES but when I brought it in towards our table he gave up and headed off around the next hill.
Cheers Lawrence
       Post #: 113
Jump to:
