help on a Nelson engine
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> QM-40 Racing >> help on a Nelson engine
Page: [1]
Login
help on a Nelson engine - 12/25/2003 3:13:40 AM
SSGSPEEDMAN
Status: offline
Hi I have a "FAI NELSON" "HIGH NIRTO VERSON".
ITS only been test once befor i got it.
an what prop should I use to breakin the engine?
this is a link.. its the 8th engine down
http://www.mh-aerotools.de/airfoils/pylon_engines.htm
if yall can give me more info thanks in advance
speedman
       Post #: 1
RE: help on a Nelson engine - 12/25/2003 3:46:56 PM
Ed Smith
Status: offline
Could you be a bit more specific. The FAI Nelson is meant for use with a tuned pipe and FAI fuel, 20% castor and 80% alcohol, no Nitro.
Is this a rear exhaust, rear intake or front intake.?
Ed S
(in reply to SSGSPEEDMAN)
       Post #: 2
RE: help on a Nelson engine - 12/25/2003 8:36:48 PM
Ed Smith
Status: offline
I checked the website you mentioned. This engine was intended for use in Formula one racing. To break it in you will need fuel with at least 60% Nitro. An average prop for racing use was 8 1/2 x 7. This size was not carved in stone, there was a lot of personal choice, black magic, folklore and down right BS when it came to carving propelers. Engines would be reving at about 24k. For breaking in I used an everyday 9 x 6 cut down to about 6 x 6 and balanced. This prop with 60% fuel would get the engine up to operating rpm and temperature two stroking with a rich needle setting. Run a half dozen tanks through with this setting, letting the engine cool completely between runs and you will be all set.
Ed S
(in reply to Ed Smith)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.250RCU1
