estradajae
Joined: 11/10/2005 From: MedellinAntioquia, COLOMBIA Status: offline
Omar Yo he usado nitrobenzol en un galon de combustible que preparé hace como 6 años mas o menos, y no lo habia gastado del todo, en estos dias lo utilicé y es un excelente combustible para mí gusto, el motor funcionó perfectamente, mejorando la minima y con una maxima super mejorada en comparación con combustible sin nitro. Pero la gente en la pista ahí mismo me dijo que ahh que vea, que eso es carcinógeno que no se que...y entonces pues ya queda uno maluco para seguirlo usando, pero la berraquera en funcionamiento. Aquí en Medellín puede conseguirse muy barato un frasco de medio litro de nitrobenzol, y haciendo uno cuentas, le sale hacer 5 litros de combustible algo así como en 20 mil pesos, yo mismo me lo preparo. To Jim Tomerson: For me, nitrobenzene, the times that I've worked with this, it has been a great additive, my engine works screaming, and better reliability on the idle, no overheating... but I'm aware of the problems related to the nitrobenzene, and then I'm afraid to use it. 3d-aholic Here in COlombia, there is no production of nitromethane, it's simple unavailable at reasonable cost... it's sometimes available when some LHS import it, but you just laught at the price, a 750ml bottle would cost the equivalent of 20 to 30 dollars or more, while nitrobenzene is readily available at a chemicals store, and a 500ml bottle would cost like 2 or threebucks. If you are going to mix your own fuel here it's pretty cheap, you can mix 1 1/2 gallons with 15% of nitrobenzene for about 10 dollars, using 99.95% methanol and first press castor oil.... really cheap compared to the $20 that would cost a 5% nitro fuel gallon...thats why mix my own fuel... but I do it without any nitro (I just mixed with nitrobenzene once like 5 years ago and i left half of a gallon that i just burned last week with great results...) I couldn't hide anyway, the guys at the field noticed that.. Jorge
_____________________________
Airplanes, engines and flying become an addiction...with not enough wallet
