Who's building the Sig 1/5 scale Cub?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> Who's building the Sig 1/5 scale Cub? Page: [1] 2 3 4   next >   >>
Login
Who's building the Sig 1/5 scale Cub? - 12/25/2003 9:57:14 PM
Steve
Status: offline
I've just about finished up my winter prodject. It's a Sig 1/5 scale Cub that I put a Saito 130 twin in and modified the tail for servos. It's been a very fun prodject to build and it has a lot of scale potential for contests.
Click to see fullsize image.
Click for fullsize
< Message edited by Steve -- 12/29/2003 6:13:50 PM >
_____________________________
AKA,, "The Spleen"
If you want to see my Super Power,,, pull my finger.
       Post #: 1
RE: Who's building the Sig 1/5 scale Cub? - 12/25/2003 10:29:48 PM
Steve
Status: offline
Here is a couple more.
Click for fullsize
Click for fullsize
< Message edited by Steve -- 12/25/2003 10:33:03 PM >
(in reply to Steve)
       Post #: 2
RE: Who's building the Sig 1/5 scale Cub? - 12/25/2003 11:44:46 PM
Live Wire
Status: offline
Shoulds be able to hover with 130, I am using a Mag 52 fs on wine , a guy with a 100 said that it was to much power. Plane built great and flies the same. Wing loading is low so the glide forever! Have fun but it is not a trainer!!!!
(in reply to Steve)
       Post #: 3
RE: Who's building the Sig 1/5 scale Cub? - 12/25/2003 11:49:57 PM
Boss248
Status: offline
Ha Steve...that is one damn good looking Cub...I really like the double latch for the door. I built that Cub many years ago...had it on floats for a few years. Seeing yours makes me want one real bad. Excellent job Steve...to bad it's under powered tho...
(in reply to Live Wire)
       Post #: 4
RE: Who's building the Sig 1/5 scale Cub? - 12/26/2003 4:39:15 PM
GarySS
Status: offline
Lets see more photos.......with the cowl on......and wing on, etc.!
What did you use for covering?
Did you use the kit's main landing gear?
(in reply to Boss248)
       Post #: 5
RE: Who's building the Sig 1/5 scale Cub? - 12/26/2003 8:50:37 PM
Steve
Status: offline
I am using Monokote for the covering to save weight due to the heavier motor. I have not yet finished the cowl because I am doing a two piece cowl and I have never tried this before. I am building the clipped wing version, I like it the best, to do better aerobatics. I only need to finish up the servo hatches and glue in the hinges. Cubs do nice loops, knife edge, knife edge slips, flat spins, and I may be able to do a torque roll or two with this one. Most of my flying will be done at 1/4 to half throtle. Here is a pic of the wing. I did use the stock landing gear because the Robart gear is a different size. I already had the fuse built when I thought about getting the Robart gear and after doing some reserch, I would have had to move the landing gear blocks to use it. The wing strut mount should be moved too.
Click for fullsize
< Message edited by Steve -- 12/26/2003 8:53:19 PM >
(in reply to GarySS)
       Post #: 6
RE: Who's building the Sig 1/5 scale Cub? - 12/26/2003 9:56:39 PM
Boss248
Status: offline
They look sorta out of place next to the monster on the right
(in reply to Steve)
       Post #: 7
RE: Who's building the Sig 1/5 scale Cub? - 12/26/2003 10:54:10 PM
Steve
Status: offline
Thats my Lanier Staudacher. I have trouble getting that one out of the house.
       Post #: 8
RE: Who's building the Sig 1/5 scale Cub? - 12/31/2003 5:09:30 AM
tailskid
Status: offline
Flying mine with a .48 four stroker and it pulls it around just fine.....can't wait to see you trying to land with that engine - even at idle it should be pulling <g>
Jerry
# 93 in Club Saito
(in reply to Steve)
       Post #: 9
RE: Who's building the Sig 1/5 scale Cub? - 12/31/2003 10:59:48 PM
Steve
Status: offline
I know I will have to play with props to get the right speed. With the heavier motor and added weight for ballance and the clipped wing, I think it will settle on the ground very nicely. Here are a few more pics.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to tailskid)
       Post #: 10
RE: Who's building the Sig 1/5 scale Cub? - 1/1/2004 2:57:04 AM
GarySS
Status: offline
Nice!!
(in reply to Steve)
       Post #: 11
RE: Who's building the Sig 1/5 scale Cub? - 1/1/2004 9:58:33 PM
Steve
Status: offline
Finally got the jury struts built.
Click for fullsize
Click for fullsize
< Message edited by Steve -- 1/7/2004 10:28:07 PM >
       Post #: 12
RE: Who's building the Sig 1/5 scale Cub? - 1/2/2004 1:03:41 AM
tailskid
Status: offline
One of my struts broke during my move....so I haven't flown it since June.....or was that July? Anyway, guess I ought to remake a set.....
Jerry
# 93 in Club Saito
(in reply to Steve)
       Post #: 13
RE: Who's building the Sig 1/5 scale Cub? - 1/2/2004 3:20:19 AM
Steve
Status: offline
It would be nice to get a longer piece of tubing and make it all one piece instead of putting three pieces together.
       Post #: 14
RE: Who's building the Sig 1/5 scale Cub? - 1/3/2004 10:42:19 PM
tailskid
Status: offline
Good idea...
Jerry
# 93 in Club Saito
(in reply to Steve)
       Post #: 15
RE: Who's building the Sig 1/5 scale Cub? - 1/5/2004 11:48:28 PM
Steve
