RE: "DON SMITH " B-17'S?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: "DON SMITH " B-17'S?
Page: <<   < prev  1 2 3 [4] 5 6 7 8   next >   >>
Login
RE: "DON SMITH " B-17'S? - 4/9/2004 6:21:00 PM
p-47 razorback pilot
Status: offline
thought i sold you my smith 17 stuff?
(in reply to flydoc)
       Post #: 76
RE: "DON SMITH " B-17'S? - 4/10/2004 1:26:08 AM
b17mik
Status: offline
Fly fort...GOOD ONE! put the triangle piece in as one piece..Do not cut it up in pieces..As you can see I did both ways and the one piece was much easier to do...Consider this also..splice your wing spars together at the center first before you biuld the ribs up..Reason for this it is much easier to do with out all the weight of the wing of each side..I built the left side completly and then the right and then tryed to put them together then...What a hassel that was....But if you just make the connection in the center first with the 4 sticks in the front spar and also the rear spar..all the weight of the completed wing isnt there..Then buld each side with the ribs..after you do one side finished,then prop it up so the other side is down on the plans and finish it...Michael
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
[b] Vonnie Gal[/b]
B-17G-5 DL
(in reply to p-47 razorback pilot)
       Post #: 77
RE: "DON SMITH " B-17'S? - 4/10/2004 1:35:28 PM
Fly Fort
Status: offline
Thanks Michael,
for the response and the pictures.
BTW my first name is also Michael
Do you know what for fuel tanks you're gonna use???
Greetz
(in reply to b17mik)
       Post #: 78
RE: "DON SMITH " B-17'S? - 4/10/2004 2:08:28 PM
flydoc
Status: offline
P-47,
Nope, I didn't buy them. I've had mine for six months.
Howard Kahn
Fairfax Station, VA
(in reply to Fly Fort)
       Post #: 79
RE: "DON SMITH " B-17'S? - 4/10/2004 5:50:57 PM
b17mik
Status: offline
I was thinking of using about a 12 or 14 ounce tank at each naccelle and then a good size feeder tank in the middle of the fuse to feed the engine tanks..I am using OS91 fs with the pump for engines and so the plumbing for all the tanks wont be so hard..You would disconect the fuel lines feeding the engines at refueling time and then fill up the large tank in the fuse and when it is full..it would then start filling up the nac tanks untill all those would be full..so with a 30 ounce tank in the fuse feeding 14 ounce tanks in the nacs that would give you a long flight...What do you think?? Michael in California
[b] Vonnie Gal[/b]
B-17G-5 DL
       Post #: 80
RE: "DON SMITH " B-17'S? - 4/10/2004 6:05:51 PM
Fly Fort
Status: offline
Hi Michael,
Not a bad idea.
Keep me informed when you commence to that stage.
Thanks in advance
Greetz
       Post #: 81
RE: "DON SMITH " B-17'S? - 4/10/2004 9:19:51 PM
b17mik
Status: offline
I finally decieded on what aircraft of the 8th airforce I am to base my DS b17 on.... Based in Kimbolton with the 527thBS of the 379th BG her name was Vonnie Gal..More research needs to be done but on a raid to liepzig just after bomb release she was hit by flak and pilot 2lt William F. Moore decieded to fly to Switzerland where he and his crew were interned..Michael
Click for fullsize
[b] Vonnie Gal[/b]
B-17G-5 DL
       Post #: 82
RE: "DON SMITH " B-17'S? - 4/10/2004 9:47:19 PM
Mustang51
Status: offline
K.I.S.S.
Sounds like trouble. The more complicated a system, the more things can go wrong. Just my c2
Mustang51
       Post #: 83
RE: "DON SMITH " B-17'S? - 4/10/2004 10:52:32 PM
b17mik
Status: offline
hey Mustang..Take a look at my construction photos..I dont do anything simple...With the feeder tank you are preventing a air bubble from forming in the tank that feeds the engine...with a air bubble ,you run the risk of a flame out..after spending the money that I have on this and the time building it,I want to be sure nothing goes wrong..The feeder tank idea was taken from the helicopter guys as they all have a feeder tank because they must never have a flame out...Michael
[b] Vonnie Gal[/b]
B-17G-5 DL
(in reply to Mustang51)
       Post #: 84
RE: "DON SMITH " B-17'S? - 4/10/2004 11:14:38 PM
Mustang51
Status: offline
Differancs is... they're only feeding one header tank, not four. You're also talking about all that plumbing betwen tanks, along with the disconnects(one tank in fuselage, four in wings) associated with running a system like that. You do what you want... I've just been in this hobby a long time, that's all(not that you haven't).
Just playing devils advocate.
Besides, do you really need over an hour of flight time?
That's what in scale time???? Three missions to Remagen and back with only "pitting" for bombs?
-Mustang51
       Post #: 85
RE: "DON SMITH " B-17'S? - 4/10/2004 11:43:03 PM
b17mik
Status: offline
This system is simpler than you think..I am using OS 91 fs with the pump..There is no need for a presure tap..So the feeder tank with the use of tees is feeding the header tank and that is it.. as the feeder take is filled on the ground ,it fills completly and then it fills the header tanks...at each engine all you do is open a vent tap and the fuel flows out to get rid of the air in the tank..anyway once it is installed into the airplane ,I'll take pics to show it all set up...Time in the air? I dont care about that..For me the worse case is to blow the landing approch and need to go around on low tanks and then with all the air in the tanks causing a flame out...needing power to go around and then only 3 engine going isnt for me ..Michael
[b] Vonnie Gal[/b]
B-17G-5 DL
       Post #: 86
RE: "DON SMITH " B-17'S? - 4/11/2004 8:59:20 AM
Fly Fort
Status: offline
Wooow,
"Heavy" discussion here.
Michael, are you going to use also a glow system with your engines?
I'm building also a Bronco, and I'm going to experiment with the system (with 2 OS FS70)
Here you can find additional info about the system that I'm gonna use in my Bronco http://smservicesuk.co.uk/acatalog/ --> On Borad Units --> SM20 Glo Switch
Bye
Greetz
       Post #: 87
RE: "DON SMITH " B-17'S? - 4/11/2004 6:59:32 PM
b17mik
Status: offline
Fly fort..in regards to glow system..I have to use a glow system because of the location of the glow plug on the engine makes it impossible to get to when the cowl is on...Besides...The fear of the flame out is on my mind all the time when building this plane...I had a flame out on a twin trainer that I designed and it happened on a go around ..giving the fuel the left engine quit..the quarter of a second that your mind needs to see the happenings and it was over!..The right engine just spin it to the left and smash! all this happened at about 6 feet off the ground...So there wasnt any time to react...YOU DO NOT WANT A FLAME OUT!! it is as "simple" as that...Michael in California
[b] Vonnie Gal[/b]
B-17G-5 DL
       Post #: 88
RE: "DON SMITH " B-17'S? - 4/12/2004 2:24:33 AM
MEMPHISBELLE
Status: offline
I have a Smith B-17 with saito .91's. I also have 90 flights on it. I also have made 90 landings with all four engines running. I did buy a glow driver because every one said " Lose an engine and lose the plane" WHAT A CROCK. R ememder you have four engines. I paid 250 for a glow driver set up from Mcdaniels and used it three times. I hade trouble with battery interfearance wwhen the drive was not on. Sounds wierd but bob mcdaniel couldn't even figure it out. I sold the whole set up for 20.00 at an auction. I am currently building a Smith B-24 and will be powering it with saito .91's and will not be using a glow driver system.
Wes
       Post #: 89
RE: "DON SMITH " B-17'S? - 4/12/2004 5:56:59 AM
b17mik
Status: offline
In the end everyone just has to make up thier own mind on how to do stuff...How do you set up your servos?? I do it this way ..he does it a diffrent way... how many tanks do you use?..what size? where are they located? do you use a glow driver or not? the list can go on and on..But in the end...just make up your own mind! We have multiple flyers with with multiple cylinder and engines out at our field and they all say they wouldn't be without a glow driver..The conveince and the ease of idle and I have never heard of interferance to the radio..Is mcdaniels still in business?..If you had trouble from the get go why didnt you get your money back? and as for your 90 take offs and landings,keep counting, because it is like riding a motorcycle.either you have layed it down on the pavement or you will soon...Either way it is going to happen..Michael
[b] Vonnie Gal[/b]
B-17G-5 DL
(in reply to MEMPHISBELLE)
