RE: "DON SMITH " B-17'S?
Tower Hobbies
Logged in as Guest
  Printable Version
Top Flite P-51D Mustang - 1/5 RTC - ARF
Seller:  chase67
Details:   $750.00   |  11/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: "DON SMITH " B-17'S?
Page: <<   < prev  1 2 3 4 5 6 [7] 8   next >   >>
Login
RE: "DON SMITH " B-17'S? - 6/3/2004 4:04:13 AM
b17mik
Status: offline
here is another shot of the stab...boring but that is all I got for now to keep updated...You could also go to www.daydreambeliever.us for some great construction on a DS b17 ...Flyfort..are you still out there working on yours??Michael
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
[b] Vonnie Gal[/b]
B-17G-5 DL
(in reply to flydoc)
       Post #: 151
RE: "DON SMITH " B-17'S? - 6/7/2004 1:36:18 AM
BadBart
Status: offline
Had a question regarding builing surfaces for this size project. Seems that many use a door. Are you able to walk completely around the table you use? Meaning, will I be able to use my workbench which is against the wall?
Patrick
       Post #: 152
RE: "DON SMITH " B-17'S? - 6/7/2004 4:27:34 AM
b17mik
Status: offline
Hey there Bad bart...what ever size of bench you use,try to make it as big as possible because no matter what size you use,it simple wont be big enuf..and that is the truth!!My bench is 4feet by 12 feet and as you can see I am a bit of a slob when it comes to building,but I wish it was bigger..but that was all I could fit..With a single door being used that is about 36inches by 80 inches..just big enuf to get one side of the wing on it..that all..The fuse is 9 feet long!!! so that wont fit at all...Think big here because its big!! dont give up !!! Michael in California
Click for fullsize
[b] Vonnie Gal[/b]
B-17G-5 DL
(in reply to BadBart)
       Post #: 153
RE: "DON SMITH " B-17'S? - 6/18/2004 5:51:17 AM
b17mik
Status: offline
Hey Flydoc...In regards to the elevator skin...What did you do here??did you skin with some type of fabric for a scale look or what..How is the project going??I am working on the stab and elevator right now..Can you say slooooooow...?? Michael
Click for fullsize
[b] Vonnie Gal[/b]
B-17G-5 DL
(in reply to b17mik)
       Post #: 154
RE: "DON SMITH " B-17'S? - 6/18/2004 6:03:07 AM
Mechanos
Status: offline
quote:
ORIGINAL: P-47 D PILOT
wanting to see any and all don smith b-17's in any stage of being built, come on guys lets see those big birds....
Check out Day Dream Believer
(in reply to p-47 razorback pilot)
       Post #: 155
RE: "DON SMITH " B-17'S? - 6/18/2004 2:47:47 PM
flydoc
Status: offline
Hi Mike,
Yes, I built up the elevator with scale rib spacing and trim tab, and covered it with Solartex, which is a fabric iron-on covering. As far as my b-17 goes, it is structurally complete, fully glassed, and mostly primed. I'n just about to start with surface detail and pannel line application. So much sanding! Anyway, I'm making good progress towards completion. I've got several other things to do in the shop involving maintainence of some of my other planes, so my full workshop time and attention is not devoted solely to the B-17
Howard Kahn
Fairfax Station, VA
       Post #: 156
RE: "DON SMITH " B-17'S? - 6/27/2004 1:20:51 AM
b17mik
Status: offline
I am still working on it..Here is construction of the elevators...Michael
Click for fullsize
Click for fullsize
[b] Vonnie Gal[/b]
B-17G-5 DL
       Post #: 157
RE: "DON SMITH " B-17'S? - 7/18/2004 11:35:45 PM
BadBart
Status: offline
Howdy, quick question regarding the construction of the DS B-17. I'm just starting mine today (will post pictures ASAP) and have a question. Is there supposed to be an upper nose crutch? There is a lower nose crutch supplied but no upper and I can't seem to make the stock balsa crutch pieces make that sharp bend. This is the piece that forms the upper portion of the "nose" of the B-17.
Pat
(in reply to DownSideUp)
       Post #: 158
RE: "DON SMITH " B-17'S? - 7/19/2004 12:17:09 AM
b17mik
Status: offline
Did you get a kit from a kit cutter or are you cutting your own parts? Show a picture of the piece you are talking about...Mike
[b] Vonnie Gal[/b]
B-17G-5 DL
       Post #: 159
RE: "DON SMITH " B-17'S? - 7/19/2004 12:05:32 PM
Heavy Date
Status: offline
Upper nose crutch should be cut from sheet balsa, you will never be able to bend that part from a stick.
If you had a kit cut it should be in there. If not just cut one from 1/4" balsa sheet.
Hans
       Post #: 160
RE: "DON SMITH " B-17'S? - 7/19/2004 1:21:09 PM
BadBart
Status: offline
Yes, I had it cut by Precision Cuts and figured there was one supposed to be in there but couldn't locate it. I contacted PC and Larry is checking into it. If all else fails, I will simply take your advice and cut it myself using 1/4 balsa.
Thanks!
Pat
(in reply to Heavy Date)
       Post #: 161
RE: "DON SMITH " B-17'S? - 7/21/2004 1:54:02 PM
Fly Fort
Status: offline
Hello guys,
sorry that I didn't reply to all off your questions, but i received my landinggear yesterday and my "spare" wheels from Dubro.
I don't know when i can continue but if I have some questions, i shall asked them
Happy building
Greetz
       Post #: 162
RE: "DON SMITH " B-17'S? - 7/29/2004 12:17:48 AM
BadBart
Status: offline
Two quick questions for an in-experienced builder building a Don Smith B-17...
1. Why build the fin after both sides of the fuse are complete and not while one side is pinned to the building surface?
2. What are the dimensions (if there are any) for the balsa strips used for planking the fuselage?
Thanks and much appreciated!
Pat
(in reply to Fly Fort)
       Post #: 163
RE: "DON SMITH " B-17'S? - 8/8/2004 8:25:30 PM
Fly Fort
Status: offline
Hello Michael,
Found some time today to start the installation of the landinggear.
But found directly some problems and errors on the drawings.
As you can see on the image this is the drawing of part n°5 for the inboardnacelle with landinggear
This is an other drawing and the same page with details to mount the landinggear
And this is that piece (see first image) again with the allignment with image 2
So, if you look carefully, that piece n°5 isn't drawn right on that particular sheet, it's too small
Did you faced the same problem also Michael???
I think the whole nacelle must be redrawed to adjust all the mistakes in the nacelle, because I found more mistakes on that sheet.
< Message edited by Fly Fort -- 8/15/2004 12:46:41 PM >
Greetz
       Post #: 164
RE: "DON SMITH " B-17'S? - 8/10/2004 6:21:20 PM
Heavy Date
Status: offline
Fly Fort,
I don't think anything is wrong at all. That former goes behind the landing gear and behind the spars. I had no trouble with mine at all. What you may be seeing is the widest part of the nacelle drawn in a front view, which would be N4 if I am not mistaken.
Look at the side view of the nacelle on the same sheet and you will see what I mean.
Hope that helps.
Hans
