RE: New HOW TO Posted: How to Install Robart Hinge Points
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> RE: New HOW TO Posted: How to Install Robart Hinge Points Page: <<   < prev  1 2 [3]
Login
RE: New HOW TO Posted: How to Install Robart Hinge Points - 11/19/2007 10:28:26 PM
Frasco
Status: offline
quote:
ORIGINAL: 4*60
I use yellow wood glue. Works for me.
I use it as a Coffee Creamer ..
(in reply to 4*60)
       Post #: 51
RE: New HOW TO Posted: How to Install Robart Hinge Points - 11/20/2007 6:41:22 PM
RysiuM
Status: offline
Another plane - CoroCub (SPAD Piper J3 Cub) 86 inches wingspan. I used Robart to hinge ailerons. This time, I used Robart hinge glue. It works. On one note, this glue cures quite fast - you have no more than few minutes before you will have problem with moving a hinge in it's hole.
Pictures:
The plane.
Aileron - coroplast skin, balsa LE and blocks for robart hinges.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by RysiuM -- 11/20/2007 6:43:38 PM >
_____________________________
Mather Aerospace Modelers, Inc.
AMA Gold Leader Club, Charter #1243, Sacramento, CA
(in reply to Frasco)
       Post #: 52
RE: New HOW TO Posted: How to Install Robart Hinge Points - 7/11/2008 7:11:45 PM
jetpack
Status: offline
I'm planning a 1/2A Scale Citabria and the elevator requires an 1/8" hardwood dowel for the leading edge, which forms the radius and is also the solo part that joins each side.
I would like to consider using the 1/2A hinge points that Robart offers, but drilling through the hardwood dowel sounds like alignment trouble without even trying.
Any ideas?
Would I have to stack and drill the parts all at once, and then cut, fit and glue in assembly?
How about drilling the hardwood dowel first and using it as a drill guide for the softer balsa parts?
Are other type hinges better in this application? I'm trying to keep the hinges hidden, and want to keep the round dowel idea in its construction, or something comparable if it works better. I just dont know how well the drill would do through all that material if stacked up.
I have a Dremel table saw and a small drill press if that helps with any ideas and trying to keep it as scale as possible.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by jetpack -- 7/11/2008 7:48:29 PM >
(in reply to RysiuM)
       Post #: 53
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.547RCU1
