New HOW TO Posted: How to Install Robart Hinge Points
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> New HOW TO Posted: How to Install Robart Hinge Points
Page: [1] 2 3   next >   >>
Login
New HOW TO Posted: How to Install Robart Hinge Points - 12/26/2003 8:08:43 PM
Larry Eddy
Status: offline
Click here to read the review!
_____________________________
Larry Eddy
RCU Magazine Flunkie
"General RCU Flunkie"
RCUniverse.com | Wattflyer.com | RCUvideos.com | Kaango.com
       Post #: 1
RE: New HOW TO Posted: How to Install Robart Hinge Points - 1/1/2004 1:45:20 AM
Fighterpilot
Status: offline
I have found that the urathane glue continues to seep out of the hole and you have to baby sit the stuff for about and hour. Once it starts to harden, water will not remove it. I use the same method but use Formula 560 canopy glue. It cleans up with water and holds very aggresively to the plastic hinges. If you doubt the strength, make up a test hinge and try to pull it apart. I also am sure to insert the hinge in the movable surface (either the aileron or elevator) all the way to the end of the knuckle. This puts the hinge pin approximately 1/16th into the elevator or aileron and places the rotation point behind the leading edge of the control surface. This eliminates binding when full deflection is desired.
I've used this method on 100" warbirds with 4.2 gas engines in the nose and have never had a hinge pull out. It's a lot easier than the urathane glue.
(in reply to Larry Eddy)
       Post #: 2
RE: New HOW TO Posted: How to Install Robart Hinge Points - 1/15/2004 7:14:58 PM
k_sonn
Status: offline
Zap Hinge Glue is designed for glueing Robart hinges. You do not have to baby sit it and it the hinges can be handled in about 30 minutes. Once it is dry, you cannot pull the hinge out. If you drill the holes for your hinges properly there is no benefit to using glue that foams. It just makes a mess and you have to baby sit it. If you did not drill the holes properly, you should use an appropriate size brass tube to drill out the area and glue in a balsa dowel and then start over. Although foaming glue may fill the hole, there is no substitute for a correctly drilled, tight fitting hole.
(in reply to Fighterpilot)
       Post #: 3
RE: New HOW TO Posted: How to Install Robart Hinge Points - 1/22/2004 9:37:31 AM
rajul
Status: offline
The width of the robart hinges is wider near the hinge point. After drilling a hole, I follow with "countersinking" with a small dremel cone shaped grinding stone. This makes a cleaner looking installation, and it has worked well for me. I was wondering how you guys do it ?
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
(in reply to k_sonn)
       Post #: 4
RE: New HOW TO Posted: How to Install Robart Hinge Points - 1/22/2004 5:23:38 PM
Scoubidou
Status: offline
Can 30 minutes epoxy replace the Gorilla glue?
(in reply to rajul)
       Post #: 5
RE: New HOW TO Posted: How to Install Robart Hinge Points - 1/23/2004 1:08:29 AM
rajul
Status: offline
I use 60-min epoxy with no problems. Gives me more time to think and clean all residue and much higher strength.
Mike Marks
RCU Moderator
(in reply to Scoubidou)
       Post #: 6
RE: New HOW TO Posted: How to Install Robart Hinge Points - 2/19/2004 7:17:48 AM
Patriot
Status: offline
I agree, I have always felt 60 min epoxy is the way to go with hinges.
Patriot
A man who learns from his own mistakes is very smart, but a man who learns from the mistakes of others, is truly wise. Adm.
(in reply to rajul)
       Post #: 7
RE: New HOW TO Posted: How to Install Robart Hinge Points - 2/19/2004 7:20:29 AM
4*60
Status: offline
I use yellow wood glue. Works for me.
(in reply to Patriot)
       Post #: 8
RE: New HOW TO Posted: How to Install Robart Hinge Points - 2/19/2004 3:35:15 PM
Ugo Ferrari
Status: offline
I use the yellow wood glue too ! Plenty of time, easy water cleanup and plenty strong !
Ugo
Ugo Ferrari
Fort Walton Beach,
(in reply to 4*60)
       Post #: 9
RE: New HOW TO Posted: How to Install Robart Hinge Points - 2/29/2004 1:16:24 PM
GeraldRosebery
Status: offline
Why not use Pacer "Hinge Glue" purpose designed for the job and water clean-up. It you use epoxy, remember it does NOT stick to the hinge material at all. It creates only a physical "socket" around the hinge. It works, but I prefer a simple clean-up material that sticks to the hinge.
Gerry Rosebery
Niagara-on-the-Lake, Ontario
(in reply to Ugo Ferrari )
       Post #: 10
RE: New HOW TO Posted: How to Install Robart Hinge Points - 3/4/2004 1:06:11 PM
qcrcbill
Status: offline
How about SigBond Aliphatic Resin wood glue for the Robart hinge points? Thank you. Bill
(in reply to GeraldRosebery)
       Post #: 11
RE: New HOW TO Posted: How to Install Robart Hinge Points - 3/21/2004 5:14:24 AM
Barry_G
Status: offline
I'm certainly no expert chemist, however, I have used both the yellow wood glue and the Pacer hinge glue and can tell absolutely NO difference in how they work, look, smell, feel, set up, and (probably), taste! http://utopia.rcuniverse.com/micons/m15.gif
Alky or Gas, it's all a blast!
(in reply to qcrcbill)
       Post #: 12
RE: New HOW TO Posted: How to Install Robart Hinge Points - 4/2/2004 7:29:50 PM
Chris-_-Memphis
Status: offline
is this a good alternative to CA hinges on 60size arfS?
(in reply to Barry_G)
       Post #: 13
RE: New HOW TO Posted: How to Install Robart Hinge Points - 4/2/2004 8:14:01 PM
C_Watkins
Status: offline
If you don't like the CA hinges, these hinges are always a good alternative.
You'll probably want the "medium" size, for that plane.
I've never had a failure using them.
(On the other hand, I never had a failure with Klett style or CA hinges, either)
(in reply to Chris-_-Memphis)
       Post #: 14
RE: New HOW TO Posted: How to Install Robart Hinge Points - 4/3/2004 10:34:04 AM
Barry_G
Status: offline
I use them exclusively. I've had CA hinges fail.
Good luck, Barry
(in reply to C_Watkins)
       Post #: 15
RE: New HOW TO Posted: How to Install Robart Hinge Points - 5/3/2004 9:06:42 PM
jroy
Status: offline
I use my own formula, spit, white out, bubble gum, and tree bark.. LOL naww just joking... Great video, thanks a lot, doing hinges right now on a new plane and it really helped... great job RCU!! Oh and I have a bunch of homemade glue I can sell ya cheap.. LOL
       Post #: 16
