New HOW TO Posted: Install Robart Retracts
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> New HOW TO Posted: Install Robart Retracts Page: [1]
Login
New HOW TO Posted: Install Robart Retracts - 12/26/2003 8:10:19 PM
Larry Eddy
Status: offline
New HOW TO Posted: How to Install Install Robart Retracts
Click here to read the review!
_____________________________
Larry Eddy
RCU Magazine Flunkie
"General RCU Flunkie"
RCUniverse.com | Wattflyer.com | RCUvideos.com | Kaango.com
       Post #: 1
RE: New HOW TO Posted: Install Robart Retracts - 1/21/2004 3:42:47 PM
Wabbit
Status: offline
That seems preety easy. I just got a supersportster40 mk II. I now want to put retracts on it. Has anyone ever seen a SuperSportster with retracts? I've heavd that it makes a world of difference.
Ain't no shame in a worn out airframe!
(in reply to Larry Eddy)
       Post #: 2
RE: New HOW TO Posted: Install Robart Retracts - 2/10/2004 6:11:53 PM
Kmot
Status: offline
What an excellent video tutorial!
DRILL BABY DRILL!!!
(in reply to Wabbit)
       Post #: 3
RE: New HOW TO Posted: Install Robart Retracts - 2/18/2004 5:10:34 PM
tommy s
Status: offline
I like the looks of a plane flying with retracts but in reality flat tapered
landing gear with pants over the tires have less drag than retracted gear.
The pattern guys have known this for several years now.
Retracts on your plane will probably not make any difference except in looks.
tommy s
       Post #: 4
RE: New HOW TO Posted: Install Robart Retracts - 2/25/2004 4:15:05 PM
Stew99
Status: offline
It's hard for me to believe that anything in the airstream can produce less drag than nothing in the airstream. I think the movement away from retracts in pattern has more to do with the fact that given the weight and complexity of retracts, they are simply not necessary for the slower, constant speed manuevers that are popular today. A draggy plane is actually an advantage in this type of aerobatics as it helps control the speed in the downlines.
(in reply to Kmot)
       Post #: 5
RE: New HOW TO Posted: Install Robart Retracts - 3/7/2004 7:04:55 AM
Richard L.
Status: offline
quote:
ORIGINAL: tommy s
in reality flat tapered landing gear with pants over the tires have less drag than retracted gear.
Yeah right. You are telling me that a plane with wheel pants flying at twice the speed of sound has less drag than the same plane with wheels retracted?
Wheel pants only help reduce frontal drag and smoothing out the air flowing past the wheels, much like an aero bicycle helmet used in a time trial or a wind deflector on top of an 18-wheeler to deflect air over the blunt trailer. Since wheel pants have area, they will still have form drag in addition to some frontal drag. Since drag is proportional to the square of velocity, doubling the speed will quadruple the amount of drag. Therefore, anything sticking out of the plane will hurt you greatly.
(in reply to tommy s)
       Post #: 6
RE: New HOW TO Posted: Install Robart Retracts - 3/31/2004 12:10:46 AM
Scott Smith
Status: offline
quote:
ORIGINAL: Richard L.
As will the wheel well cut-outs in the underside of the wing!
(in reply to Richard L.)
       Post #: 7
RE: New HOW TO Posted: Install Robart Retracts - 4/2/2004 3:54:01 AM
Bumstead
Status: offline
Sheesh! Lighten up guys.
I think about Air Conditioning vs having the windows rolled down.
We beleive all kinds of stuff when it makes us feel good.
Faaggetahbautit!
(in reply to Scott Smith)
       Post #: 8
RE: New HOW TO Posted: Install Robart Retracts - 5/3/2004 2:41:10 AM
Jackjet
Status: offline
quote:
ORIGINAL: tommy s
tommy s
Hi Tommy,
I can SURE tell the speed difference when my gear is down or up on the F-4 - and it has inner and outer gear doors.
Jackjet
Click to see fullsize image.
Click for fullsize
Jack Jet Williams
Hesperia,Ca
       Post #: 9
RE: New HOW TO Posted: Install Robart Retracts - 6/19/2004 3:07:03 PM
LDM
Status: offline
In a scratch built kit or home built kit , attention to the mounting rails is critical . Good gear can bind after attachment based on slight differance in the rails. I add plastic balsa over the rails, then saran wrap while the PL Balsa is still wet , then press the gear in place over the saran wrap . Wait 24 hours , remove gear and wrap and presto you have a perfact fit custom moulded bases for the rail to fit into to .remember the plastic balsa is only added spareningly , just a little to make a nice base over the rails .Its a flawless finishe and the gear always moves freely
(in reply to Jackjet)
       Post #: 10
RE: New HOW TO Posted: Install Robart Retracts - 9/29/2004 3:54:58 AM
Guardian
Status: offline
Plastic balsa ? explain please...........
-Mike
______________________________
(in reply to LDM)
       Post #: 11
RE: New HOW TO Posted: Install Robart Retracts - 9/29/2004 10:40:53 AM
LDM
Status: offline
Plastic balsa is a simple wood filler , you can also use Elmers -Wood filler . My very first attempt with Robart was on my original red box P40 . I did know how to fly a warbird but always consider myself a good builder .
All was well until I tried to cycle the retracts .They were fine before I tightened the screws into the rails . So I unscrewed the gear and they moved fine . IN-tern when tight I assumed the gear was flexing to conform to the uneven rails .
So I added the balsa filler to the top of the rails , put donw saran wrap and pressed the gear in , wait 24 hours and the redrilled my holes and re-mounted the gear . They worked great . Now remember if the rails are perfact to begin with your gear should not bind but my rails were off just a bit . The addition of the rails was a "Bash" to the desing and in-tern I was off in my angle . Best part was - I sold the plane becuase at that time I could not fly WW2 , over $800 on ebay but it was a very nice plane !!!!
(in reply to Guardian)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
