YNOT
Joined: 11/29/2001 From: Lake Jackson, TX, USA Status: offline
AFR blew my mind for a while too. Still not too sure if I am using it for what it is designed for. I use AFR to set up the exact same amount travel on ailerons and elevators when dual servos are used in two seperate channels. You want them both to move the same amount, in relation to the stick. Not the point of 100 % stick, that is ATV, but at 50% or 30% stick, do you have equal amounts of thown on the surface? It should help make the plane roll at the same speed, left or right. It may only be needed in this type of application. I donno. I can't remeber how sub-trims effects the AFR. (Dual elevator servos, that took many many hours to work out, drove me freakn nuts!) ATV is the travel limit. I set up in this order. ATV, AFR, Flaps/Spoilers, D/R, Expo. Or is there a better sequence? I still need help with conditions. I screwed up an entire model on mine, never did figure it out. Just one model that could not be used. Question: Anything special to know about a CAMPAC? Or is just plug and play?
_____________________________
YNOT, Snap, Flip & Hover, Tony D
