RE: Christen Eagle - Building, Alterations and Modifications    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Christen Eagle - Building, Alterations and Modifications
Page: <<   < prev  20 21 22 23 24 25 [26] 27 28 29   next >   >>
Login
RE: Christen Eagle - Building, Alterations and Modifica... - 3/7/2007 9:48 PM
Claselva31
Score: 100
Last Login: 9/18/2011
Status: offline
Airbourne, I had a buddy CNC a set of cabanes from .084" inch sheet steel. They are not the problem anymore it's my 90* upper wing mounts. I had Great Planes sent the new set and the first flight the left one broke again. Hope these pics help.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Claselva31 -- 3/7/2007 9:52 PM >
Hide Signatures
(in reply to airborneSGT)
       Post #: 626
RE: Christen Eagle - Building, Alterations and Modifica... - 3/7/2007 10:56 PM
airborneSGT
Score: 105
Last Login: 1/18/2013
Status: offline
If you can have him CNC you a single piece out of a tri - stock that is what I would recommend. I ended up using a similar setup when I fixed my cabane mounts. Honestly this kit has many problems that the everyday flyer will discover. My other bipes I could get away with flying MUCH harder and yet have no problems.
I think maybe half way through this thread there is a person who made the CNC cabane mounts. To my knowledge they are still holding up just fine. Like I said they looked to be made out of tri stock.
Another option is using the Stab mounting tabs used on 35-40% Cardens. These are very strong and I doubt would give. The other problem I had is that the upper wing itself does not have much for your cabane mounts to bite into. The real solution would be to mount the top wing like my Wild Hare Ultimate had or even the Sky Shark Eagle.
_____________________________
PAU Sponsored Pilot
Hide Signatures
(in reply to Claselva31)
       Post #: 627
RE: Christen Eagle - Building, Alterations and Modifica... - 3/7/2007 11:00 PM
Claselva31
Score: 100
Status: offline
were can I find some of these stab mounting stabs? Do you have any pics of what it looks like? Thanks
Hide Signatures
       Post #: 628
RE: Christen Eagle - Building, Alterations and Modifica... - 3/7/2007 11:03 PM
airborneSGT
Score: 105
Status: offline
Here is a picture of what caused this planes down fall. I eventually got bummed about it and just put all my gear in my WH ultimate which flew 150% better! The control horns did not tough at all on the ground, but the flexing in the air caused them to get intangled in flight! I had to land my poor eagle upside down!
Click for fullsize
PAU Sponsored Pilot
Hide Signatures
(in reply to sportflyer-RCU)
       Post #: 629
RE: Christen Eagle - Building, Alterations and Modifica... - 3/7/2007 11:08 PM
airborneSGT
Score: 105
Status: offline
Check it out here: http://www.****/forums/fg100/12300-aluminum-carden-bracket.html
Wow it blocks it out!! Its on (www.F L Y I N G G I A N T S.COM) Search aluminum stab bracket.
< Message edited by airborneSGT -- 3/7/2007 11:10 PM >
PAU Sponsored Pilot
Hide Signatures
       Post #: 630
RE: Christen Eagle - Building, Alterations and Modific... - 3/13/2007 12:03 AM
GaryKingsbury
Score: 100
Last Login: 4/8/2008
Status: offline
Hello Everyone,
I've made the decision to purchase the GP CE as my first gasser. I have a Zenoah G45 that I ploan on using. I would like to install a smoke system also. Do you think the G45 will be a good match for this plane? I've read some of the other threads concerning a problem with the cabane struts breaking and problems with the screw holes after assemblying and disassemblying the plane to take it back and forth to the field. It seems that GP has designed their 1/3 scale planes around the Fuji engines. However, I already thave the G45 and would like to use it. Any helpful suggestions are greatly appreciated.
Hide Signatures
(in reply to hilleyja)
       Post #: 631
RE: Christen Eagle - Building, Alterations and Modific... - 3/13/2007 1:41 AM
GreaTOne_65
Score: 100
Last Login: 4/2/2013
Status: offline
Gary, if I were you, I wouldn't buy a Christen Eagle for your first gasser. Let me explain why, first of all you don't say how much experience you have. Secondly, the Eagle is not a very forgiving airplane, it takes a lot of concentration. Thirdly, the first gasser will be intimidating, because of the size, I would start with something more along the trainer type to familiarize yourself with the gasser planes. Fourthly, I don't want you to get discouraged with gas airplanes, I love my gas planes, I just want you to too. So this post is not meant to disway you from trying, just trying to give you a heads up, and a fighting chance at finding success.
Dale
Hide Signatures
(in reply to GaryKingsbury)
       Post #: 632
RE: Christen Eagle - Building, Alterations and Modifica... - 3/13/2007 1:52 AM
Tired Old Man
Score: 662
Last Login: 1/16/2012
Status: offline
You would be far better off obtaining the new W/H Edge and putting that G-45 in it. Reasons; The Eagle/Pitts are for pretty experienced flyers. Those that have to ability and talent to be quick and accurate on the rudder and that can handle a plane that lands fast. The Edge will do everything the Eagle/Pitts will and more. It will fly casually or aggressively. It's easy to land at a very slow speed. It's quite forgiving for the operator. It's VERY difficult to stall it in a manner that would cause a loss of control, where with the Eagle/Pitts that's a very easy thing to do.
Will you have all the power you need with the G-45 to do all that you may want to do? Probably not, but you will have enough power to do about 95% of what you may want to do, and you'll have a plane at the end of the day. One that was designed for a gas engine, one that has a support forum that helps the first time gas flyer through all the hoops that they need to learn, with a plane that's extremely easy to set up, a plane that costs almost exactly the same amount that the Eagle/Pitts does, with a plane that will carry you forward in building experience and confidence. Once your wet feet have dried out you can go to a larger engine and do all that you'll ever be able to do.
If you're dead set on a biplane, and there's nothing wrong in that, the G/P 1.60 Ultimate would be a far better choice, offering a much greater range of flying styles and easy landing. It would also handle your engine.
< Message edited by Silversurfer -- 3/13/2007 3:42 AM >
Never lie, and never minimize or gloss. Tell it like it is and let the pieces fall where they may. The truth always wins.
Hide Signatures
(in reply to GreaTOne_65)
       Post #: 633
RE: Christen Eagle - Building, Alterations and Modifica... - 3/13/2007 3:28 AM
airborneSGT
Score: 105
Status: offline
Yeah the Eagle will not be much fun for your first gas plane. A lot can go wrong which may sour your first gas experience. Go with something along the lines of an Extra or Edge. May great brands to be had and all enjoyable. I would also recommend the Ultimate over the Eagle on any given day. Bipes fly much different than mono wing planes so be warned; a dead stick or too slow of an approach may equal a bag of balsa. Bipes stall fairly quickly and dont glide that well. Point the nose at the ground and flare at the last minute!
PAU Sponsored Pilot
Hide Signatures
(in reply to Tired Old Man)
       Post #: 634
RE: Christen Eagle - Building, Alterations and Modifica... - 3/13/2007 3:53 PM
GaryKingsbury
Score: 100
Status: offline
Thank you for the input gentlemen. As I continued my research yesterday, I came to realize that the Pitts and CE would be a handful based on all the posts I've read. I have about 10 years experience in the hobby but it's all been with nitro except for my boats which have the Zenoah marine engines. I'm a cabinetmaker/woodworker by trade and feel very comfortable with the building/modification(s) side of the hobby. I've just reached the point where I'm tired of cleaning up the nitro mess as the end of the flying day and I love the sound of the gas engines. I'll check out the W/H Edge that was recommended. But you guys know that some planes are just hard to resist. I'm still leaning towards a biplane and the GP Ultimate had been the one I was considering all winter (live in Maine). I was just concerned that the G45, because of it's weight wouldn't be a good match for the Ultimate. Thanks again for the input.
Hide Signatures
       Post #: 635
RE: Christen Eagle - Building, Alterations and Modifica... - 3/13/2007 4:04 PM
GaryKingsbury
Score: 100
Status: offline
Hello...thanks for the information. I just checked out the W/H Edge based on your recommendation. So you think the G45 will be alright in this plane for my first gas experience? In the write up a G62 is recommended so I thought I'd write you back and ask.
Gary
Hide Signatures
       Post #: 636
RE: Christen Eagle - Building, Alterations and Modifica... - 3/13/2007 7:18 PM
Tired Old Man
Score: 662
Status: offline
Gary,
The G45 will work fine for most things. The 62 is at the top end of the size scale. The 45 will fly the plane in most aerobatics but will be a bit short for all out 3D. You'll probably want to go a larger engine later if you want to fly 3D, depending on your disposable cash situation. It's too easy to change to another engine as you already know with your wood working background.
The Zenoahs are a little heavier than most of the purpose built 50cc engines, but locating the rudder servo in the tail takes care of the weight offset. The mounting holes are already there for those that desire to do than.
Hide Signatures
       Post #: 637
RE: Christen Eagle - Building, Alterations and Modifica... - 3/14/2007 2:22 AM
GaryKingsbury
Score: 100
Status: offline
Thanks again for all your advice. I ordered my GP Ultimate this afternoon from my LHS. Should be in Friday. My hobby shop guy suggested looking into an electronic ignition for the G45. He said he thought the expense was worth the weight saved. But, he wasn't sure just how much weight it saved. Is this something I might consider versusuntil I make a decision on installing another engine? I plan on leaving any 3D flying to to my "cheap" foamies. There'll be no tears shed if/when one of those crash. One other question, will I be pushing the weight issue if I wanted to install a smoke system? All I'm looking for from this plane is something fun to fly, looks good and is a gasser. I'll leave the 3D stuff to the guys with more nimble fingers. Again, appreciate all the help.
Gary
Hide Signatures
       Post #: 638
RE: Christen Eagle - Building, Alterations and Modifica... - 3/14/2007 3:05 AM
Tired Old Man
Score: 662
Status: offline
Send a PM to Ralph Cunningham. RCU handle is RCIGN1. He's the one that does the Zenoah ignition conversions. Also does a lot of weight saving work. He'll know exactly what the weights will be, and guarantees his ignitions (CH) for life.
There would be a substantial weight penalty for with the addition of smoke. Smoke oil does not go very far, so a smoke tank equal in size to the gas tank is near standard. Then you have the space and fit issues. It's up to you of course but I wouldn't do it again unless it was a really large plane, say 35% or better. It's not worth the effort from my perspective in smaller planes.
As for rudder servo placement in the Ultimate, I was referring to the Egde when I made that note and don't know what the Ultimate provides in the rear. Congratulations on your new plane. You made what I believe to be an excellent choice. You love the way it flies.
Hide Signatures
       Post #: 639
RE: Christen Eagle - Building, Alterations and Modifica... - 4/14/2007 10:28 AM
mulligan
Score: 102
Last Login: 6/23/2009
Status: offline
Deleted
< Message edited by mulligan -- 5/5/2007 7:37 PM >
George Mulligan
www.sanfordaeromodelers.com
Hide Signatures
       Post #: 640
RE: Christen Eagle - Building, Alterations and Modifica... - 8/9/2007 4:03 AM
GAS4ever
Score: 100
Last Login: 5/21/2013
Status: offline
Hello, after my bad experience with mi Eagle
http://www.rcuniverse.com/forum/m_6183410/tm.htm
i decided to buy a new one and install this gasser http://cgi.ebay.com/HH50T-50cc-TWIN-Gas-Engine-FOR-AIRPLANE-NEW-IN-BOX_W0QQitemZ300136848843QQihZ020QQcategoryZ34055QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
the guy said me that the distance From plug cap to plug cap is 9-5/8". Cylinder head to cylinder head (with out spark plug) is 8".
Some one can help me if this engine is OK?? i want to have less vibrations (twin) go gas, but i dont now if this engine fits in the cowl without open it on the sides (sparkplug)
OK thanks to all guys
Nicolas from Chile
Hide Signatures
(in reply to mulligan)
       Post #: 641
RE: Christen Eagle - Building, Alterations and Modifica... - 7/8/2008 5:48 AM
Walt Fisher
Score: 100
Last Login: 9/9/2010
Status: offline
Does anyone have a spare set of struts Great Planes Christen Eagle II that they want to sell or get rid of laying around in their work shop? I need one strut bad but will use a pair if that is the only way you will let them go. Please email me at wlfisher@tx.rr.com.
THANKS..............Walt Fisher
Hide Signatures
(in reply to GAS4ever)
       Post #: 642
RE: Christen Eagle - Building, Alterations and Modifica... - 7/8/2008 8:54 AM
airborneSGT
Score: 105
Status: offline
I will check but I think I got rid of all my CE stuff.
PAU Sponsored Pilot
Hide Signatures
(in reply to Walt Fisher)
       Post #: 643
RE: Christen Eagle - Building, Alterations and Modifica... - 8/12/2008 5:30 AM
Walt Fisher
Score: 100
Status: offline
AirborneSGT..........did you find any struts for a CE in your rummage box? FYI, I retired as a csm in 1992, after 32 years (60-92) of service. Are you still on active duty? THANKS FOR LOOKING
Hide Signatures
       Post #: 644
RE: Christen Eagle - Building, Alterations and Modific... - 1/11/2009 11:39 PM
groran
Score: 105
Last Login: 5/24/2013
Status: offline
Anyone know where I can get instruction book PDF or send to me email,any help appreciated. gymm1000@yahoo.com thanks Randy
Hide Signatures
       Post #: 645
RE: Christen Eagle - Building, Alterations and Modific... - 1/12/2009 1:43 AM
sseward
Score: 100
Last Login: 10/29/2012
Status: offline
quote:
ORIGINAL: groran
Randy,
Still available on GP's web site. Try this link:
http://www.greatplanes.com/manuals/discontinued.html
Scroll down to the Cristen Eagle.
Steve
Hide Signatures
(in reply to groran)
       Post #: 646
RE: Christen Eagle - Building, Alterations and Modific... - 1/12/2009 2:02 AM
groran
Score: 105
Status: offline
GREAT THANKS
Hide Signatures
(in reply to sseward)
       Post #: 647
RE: Christen Eagle - Building, Alterations and Modific... - 1/31/2009 10:51 AM
roggy
Score: 100
Last Login: 11/6/2011
Status: offline
I'm installing Da50 in my plane . What is the best way to install the bolts into the back of the firewall !!
It is so tight in there to install the bolts or is it better to us blind nuts .
Hide Signatures
       Post #: 648
RE: Christen Eagle - Building, Alterations and Modifica... - 1/31/2009 2:12 PM
GAS4ever
Score: 100
Status: offline
I have enlarged the wood holes in order to let my pliers get in.
http://www.youtube.com/watch?v=tx-SBpL67OI
Some one has tested the best incidence settingss?? Up and low wing???
Hide Signatures
(in reply to roggy)
       Post #: 649
RE: Christen Eagle - Building, Alterations and Modifica... - 3/17/2009 7:54 AM
MAGICSWANSON
Score: 115
Last Login: 3/11/2013
Status: offline
It apears (I hope) that this ARF may become available again? Tower lists it as "Order Pending" (along with the 1/3 Pitts). I called Tower to ask if this was a mistake, and the woman who answered said it was available for back order...no estimated date. Price shown is $349.98. Wasn't it $399.99 before?
Doug
Why buy one when you can have two at twice the price!
Hide Signatures
       Post #: 650
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.250RCU1
