MODIFYING 40% CARDEN CAP FOR CANS
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> MODIFYING 40% CARDEN CAP FOR CANS
Page: [1]
Login
MODIFYING 40% CARDEN CAP FOR CANS - 1/2/2004 4:42:15 AM
xtra 330
Status: offline
WONDERING IF ANYBODY HAS ANY INPUT ON MODIFYING A CARDEN 40% CAP TO ACCEPT CANNISTERS.ANY PICS WOULD BE HELPFUL.THANKS IN ADVANCE.
       Post #: 1
RE: MODIFYING 40% CARDEN CAP FOR CANS - 1/2/2004 7:30:58 PM
aerobaticsdude
Status: offline
Don't have pics anymore, but the installation was pretty simple.
DA sells (used to sell?) a short Pefa can system that fits well. Need to cut 2 holes in front plate for the cans to go through. Cut out air flow exit behind landing gear block. Enclose a box with lite ply. I made a hatch in top of box so to be able to get to pipes from inside fuse. Box will end right at wing tube. Mounted the pipes to the landing gear block. You'll also have to modify the bottom cowl ring to allow the pipes through. Had many flights with this setup. Never had a problem with it. Miss that plane.
Biggest problem is finding pipes short enough.
(in reply to xtra 330)
       Post #: 2
RE: MODIFYING 40% CARDEN CAP FOR CANS - 1/2/2004 8:23:25 PM
mglavin
Status: offline
quote:
ORIGINAL: aerobaticsdude
I had contemplated an installation BUT decided it was not dooable as you note the cans need to be very short. Together with the required header length to make the cans work right I dismissed the vialbility of the project...
What about the wing tube, this did not present a problem?
_____________________________
Michael Glavin
RCU Community Moderator
Hitec * Multiplex Field Representative
(in reply to aerobaticsdude)
       Post #: 3
RE: MODIFYING 40% CARDEN CAP FOR CANS - 1/2/2004 9:51:53 PM
BobPhx
Status: offline
I used the KS-94Vs cans on my 33% cap. Short and fat, intended for 80cc each. They might work, I get them from Amelung Modelbau.
Details:
http://www.goflyrc.com/projects/33Cap/CapCans.htm
< Message edited by BobPhx -- 1/2/2004 4:52:19 PM >
Up! No - the other up!
www.GoFlyRC.com
(in reply to mglavin)
       Post #: 4
RE: MODIFYING 40% CARDEN CAP FOR CANS - 1/2/2004 11:55:40 PM
aerobaticsdude
Status: offline
[/quote]
[/quote]
No, the cans and headers fit nicely. Ended right before the tube. The back wall of my box was right at the wing tube, had about a 1/4" clearance with the end of the one can and about 3/4 inch on the other. Had to bend the headers a bit to get the angles. You won't get any tuning effect with these cans, they just quiet. Got 6000 with 28x12 3blade. You may be able to shorten the headers a little to give you more clearance. I never tried that.
       Post #: 5
RE: MODIFYING 40% CARDEN CAP FOR CANS - 1/4/2004 1:34:22 AM
xtra 330
Status: offline
Thanks for the input guys,i know it can be done.......however,i heard that the header length has got to be a minimum of 9 -10 inches in length...otherwise the throttle transition will be affected?.I guess you could extend the headers down toward the bottom of the cowling ,then back up and route them back towards the cans to get the desired length.I will check on the short Pefas,as well as the KS cans.....do you think iwill be quite enough with stock mufflers and a 3 blade to compete in IMAC?
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.609RCU1
