RE: Gary Allen 33% Bücker Jungmeister    Gallery
Logged in as Guest
    Search This Thread
Printable Version
S&W 2-6S LCD Battery Capacity & Checker ***FREE SHIPPING US ONLY*****
Seller:  swgiantscalemodels
Details:   $19.89   |  4/2/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: Gary Allen 33% Bücker Jungmeister
Page: <<   < prev  22 23 [24] 25 26 27 28 29 30 31   next >   >>
Login
RE: Gary Allen 33% Bücker Jungmeister - 4/1/2008 5:32 AM
CharlieK
Score: 100
Last Login: 1/11/2012
Status: offline
Hi Ken,
Finally made it back to the Jungmeister. Have the lower center section mounted on the fuselage, and finished the upper center section tonight. I have a question - when you moved the wing pins from the center to the wings how did you reinforce the pin mounting? With the plywood strip running down the rib on the outer panel it will not have much to grab to. I am thinking about just adding a 1/4 balsa rib against the first rib so the pins have some support. Also I am considering using 1/2 in. streamlined tubing over the cabane struts - might beat the heck out of building them up from balsa and should weigh less. Something else, did you make the center section flying wires functional - they are not shown on the plans - I am doing so and starting to work on how to mount them.
Have Fun
Charliek
Hide Signatures
(in reply to Big_Bird)
       Post #: 576
RE: Gary Allen 33% Bücker Jungmeister - 4/1/2008 7:48 PM
Big_Bird
Score: 105
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: CharlieK
Hi Ken,
Have Fun
Charliek
Hi CharlieK. I don't remember how I reinforced the dowel pin hole but it should be real easy with a small piece of 1/8" plywood. I used the K&S streamlined aluminum for the inter plane struts. The center section flying wires are not functional. The wire that goes into the fuselage just floats. Here is a photo.
This doesn't have a lot of relevance here but I would like to show you how I made the struts for my Waco YMF-5. These use Glenn Torrence Models #2001 strut material. http://www.rcuniverse.com/forum/m_3938241/mpage_22/key_/tm.htm
Click to see fullsize image.
Click for fullsize
< Message edited by Big_Bird -- 4/1/2008 7:57 PM >
_____________________________
Ken
WACO Brotherhood #70, Arlington TX home of the Dallas Cowboys, SupBowl45, Texas Rangers, World Series 2010, 2011
Hide Signatures
(in reply to CharlieK)
       Post #: 577
RE: Gary Allen 33% Bücker Jungmeister - 4/4/2008 7:08 PM
rabacon
Score: 100
Last Login: 9/21/2011
Status: offline
CharileK, I ended up making my center section support wires functional because at the time the aluminum struts seemed weak side-to-side. Ken's appears plenty strong as it is a proven flier so I probably didnt need to do so. Here is a link that shows mine at that stage if you are still looking to do so. Good luck on your build. I am still waiting for the weather to warm so I can paint mine. 40degree and rain is what we got here
http://www.chainolakeseagles.com/modules.php?name=Forums&file=viewtopic&t=65
"slow is smooth and smooth is fast"
Hide Signatures
       Post #: 578
RE: Gary Allen 33% Bücker Jungmeister - 4/4/2008 10:53 PM
CharlieK
Score: 100
Status: offline
Hi,
Thanks for the info, that should work very well to stiffen it up. I am going to finish the wings and rig the center section with them installed (somehow). I know from previous experience that if the top wing is not perfectly square with the bottom at the tips the stall characteristics are interesting to say the least. On my Pica airplane we ran a rigging check before every flight to eliminate the problem. Should be fun rigging the airplane with the wings installed but I hope it will come out better. I also have another question - I am planning on installing an FPE 4.2 and am trying to figure out if I can remove the velocity stack without changing the engine run characteristics. If it looses a little power on the top end it will be ok, but I am concerned about it quitting in the air (prairie dog holes and sagebrush are not good places to land ? Actually I am thinking of taking it to colorado for the first flights to eliminate the problem. You are much warmer than us, we are still getting down to 5-15 at night, and you probably heard about springtime in the rockies in the news. I80 and I70 were both closed for at least a day at the same time. Trucks parked all over the place, what a mess. What are you going to paint yours with? I haven't decided on a color scheme for sure yet, but doubt it will be yellow. At the rate I am progressing won't have to worry about it for a year or so anyway.
Charliek
Hide Signatures
(in reply to rabacon)
       Post #: 579
RE: Gary Allen 33% Bücker Jungmeister - 4/4/2008 11:14 PM
rabacon
Score: 100
Status: offline
When you cut your ribs the ply root ribs are cut in pairs and drilled for locating pins in pairs. Keep these pairs together during the process and there is no need to rig the center section with the wings attached. If the incidence and alignment of the upper and lower center sections are properly set the wings will follow automaticly. Besides, where the wings attach to the center sections there is no strength at all without all of the wires and struts, basicly one big house of cards, and I cannot imagine trying to fit the center section with the panels flopping around unsupported. This sucker gets big fast when those panels get bolted on. Gary Allens mag article construction steps work well. Your call. I am painting with Krylon as I dont need a custom color. Will shoot a clear satin topcoat when all is done. Here is my scheme, pretty simple and clean.
http://wp.scn.ru/en/ww15/o/141/2/0/5
Not an engine guru, I have stacks on some, none on others. All run fine. They do keep the fuel from blowing down the side of the fuse though.
Hide Signatures
       Post #: 580
RE: Gary Allen 33% Bücker Jungmeister - 4/5/2008 5:16 AM
CharlieK
Score: 100
Status: offline
I looked at the Waco web site Ken, beautiful looking airplane. I would be leery of using aluminum for the strut pins if you are going to fly aerobatics, it is very weak in shear loading and would really load up the rest of the structure to take up the slack. That why we use all those rivets on full scale. I got an answer back from FPE, the engine should run fine with no stack. I may still use Gary's method of putting the wings on, it will be a make it up as I go thing. I am still thinking about jigging the whole thing up and doing it all together. I have enough weights ( bricks) to keep it all aligned I think. It worked for the Extra I built but it only had two wings to deal with. I am planning on using dope on mine, kind of hung up on airplane stuff for airplanes. My wife will make me paint it outside though, can you imagine how high you could get painting this thing in the house . Would also kill your liver if I've still got one after working on airplanes for 55 years.
Charlie k
Hide Signatures
       Post #: 581
RE: Gary Allen 33% Bücker Jungmeister - 4/6/2008 4:59 AM
Big_Bird
Score: 105
Status: offline
Dope is good. Just don't inhale.
I wanted to let you guys know what a great time I had today flying the Jungie. I have never gotten board with it. What a wonderful design.
Ken
Hide Signatures
       Post #: 582
RE: Gary Allen 33% Bücker Jungmeister - 4/7/2008 6:32 AM
Jennyboy
Score: 100
Last Login: 11/8/2011
Status: offline
Hi Ken. Could you tell me where you got those 'Y' fuel fittings in your Jungie.I've looked everywhere and can only find the 'T ' fittings.Dobro makes something that looks like them but one of the ports is a plug.Jennyboy
Hide Signatures
       Post #: 583
RE: Gary Allen 33% Bücker Jungmeister - 4/7/2008 6:48 AM
Big_Bird
Score: 105
Status: offline
quote:
ORIGINAL: Jennyboy
I really don't remember. Probably an auto supply.
Ken
Hide Signatures
(in reply to Jennyboy)
       Post #: 584
RE: Gary Allen 33% Bücker Jungmeister - 4/10/2008 10:34 PM
CharlieK
Score: 100
Status: offline
hi guys,
someone had asked about the man plans being available. I just found a site called aerofred.com on google which has the plans listed as available for free. might be a good place to check out.
charlie
Hide Signatures
       Post #: 585
RE: Gary Allen 33% Bücker Jungmeister - 4/10/2008 10:48 PM
Big_Bird
Score: 105
Status: offline
Cute Jungie.
Ken
Hide Signatures
       Post #: 586
RE: Gary Allen 33% Bücker Jungmeister - 4/20/2008 12:14 AM
skylarkmk1
Score: 210
Last Login: 5/19/2013
Status: offline
Guys,
For those of you who don't get or haven't seen it, the British magazine "Flying Scale Models" in the March 08 issue (volume 10, No. 100) has 3 articles on the Bucker Bu 133 Jungmeister. Article 1 is a general history, Article 2 is 2 pages of three views with cross sections and Article 3 is a series of closeup pictures covering details of the plane. Web site is www.flyingscalemodels.com
John F Howard (aka skylarkmk1)
AMA 10955, WACO Brotherhood #26, AWC, NWC
Hide Signatures
       Post #: 587
RE: Gary Allen 33% Bücker Jungmeister - 4/20/2008 12:18 AM
Big_Bird
Score: 105
Status: offline
Thanks John.
Ken
Hide Signatures
(in reply to skylarkmk1)
       Post #: 588
RE: Gary Allen 33% Bücker Jungmeister - 4/29/2008 1:40 AM
Twin Bridge RC
Score: 100
Last Login: 12/22/2009
Status: offline
Hi All,
I just bought a Bucker Bu-133 Jungmeister from a guy that gave up on it.
It's the big bird that you guys are talking about here with the 86" WS.
It's a little over 1/2 done but will need a lot of TLC.
The problem is he cut up the plans to make the parts.
There is more of the plans missing then there is here.
I tried calling the RCSTORE.Com where he had bought the plans from & they don't have them any more.
The people answering the phones are new & I don't believe they know much about planes.
They have the FSP0300C with the 43" WS & the FSP0300B with the 65" WS but not the one I need Which is the FSP0300A with the 86" WS.
Any one out there know where I can get a set of plans?
Thanks, Mark
signman08@czo.net
Hide Signatures
       Post #: 589
RE: Gary Allen 33% Bücker Jungmeister - 4/29/2008 5:29 PM
rabacon
Score: 100
Status: offline
pm me and I will try to set you up.
Hide Signatures
(in reply to Twin Bridge RC)
       Post #: 590
RE: Gary Allen 33% Bücker Jungmeister - 4/29/2008 7:56 PM
Big_Bird
Score: 105
Status: offline
Mark, hopefully rabacon (Roger) can help you out.
Recently I received a PM from a person in Spain requesting the same thing. I passed this on to Gary Allen. He contacted Gerry Yarrish <gerryy@airage.com> with Model Airplane News. It seems that there were some changes in the MAN store and that they misplaced the 1/3 scale Bucker Jungmeister plans. The suggestion was to have the Spanish individual contact Gerry Yarrish directly (e-mail) and request that they make an effort to find the plans. That is my suggestion also Mark and let us know what you find out. I may want to order a spare set.
http://www.arizonamodels.com/ sells the redrawn set of plans. From what I have heard they are lacking in some of the details that were on Gary's original set but may work fine for what you need. We can always supply the details.
Good luck Mark with the Jungie project. I'm crazy about mine.
< Message edited by Big_Bird -- 4/29/2008 10:55 PM >
Ken
Hide Signatures
       Post #: 591
RE: Gary Allen 33% Bücker Jungmeister - 4/29/2008 8:24 PM
rabacon
Score: 100
Status: offline
It snowed, sleeted, and rained again yesterday here.........I just want a week or two of dry warmish weather so I can paint my Jungie and get it finished. Is that too much to ask???? I need someone to do a sunshine dance to improve this miserable midwest weather. Spring in the heartland, what ya gonna do?
Hide Signatures
       Post #: 592
RE: Gary Allen 33% Bücker Jungmeister - 4/29/2008 9:01 PM
Big_Bird
Score: 105
Status: offline
That doesn't sound like global warming to me.
Ken
Hide Signatures
       Post #: 593
RE: Gary Allen 33% Bücker Jungmeister - 4/29/2008 10:26 PM
rabacon
Score: 100
Status: offline
I will be on the lookout for wooly mamoths and mastadons while turkey hunting next week!
Hide Signatures
       Post #: 594
RE: Gary Allen 33% Bücker Jungmeister - 4/30/2008 7:55 AM
Twin Bridge RC
Score: 100
Status: offline
Hi Big Bird.
I found a site selling the plans.
The thing is it don't say who's design it is.
http://www.arizonamodels.com/product_info.php/products_id/120
what do you think?
Mark
Hide Signatures
       Post #: 595
RE: Gary Allen 33% Bücker Jungmeister - 4/30/2008 6:12 PM
Big_Bird
Score: 105
Status: offline
Mark, did you read my post #591 above? These are the redrawn Gary Allen plans.
Ken
Hide Signatures
       Post #: 596
RE: Gary Allen 33% Bücker Jungmeister - 4/30/2008 6:56 PM
Twin Bridge RC
Score: 100
Status: offline
Oh,
So this is the place that makes copys.
How is it there isn't any of the originals out there some where?
If I could get the plans in CAD I could make my own drawings.
I own a sign Co. & have the equipment to draw designs on 24" paper or cut moast any design in vinyl.
Mark
Hide Signatures
       Post #: 597
RE: Gary Allen 33% Bücker Jungmeister - 4/30/2008 8:23 PM
Big_Bird
Score: 105
Status: offline
http://www.arizonamodels.com/ is more known for producing high quality scale RC kits than copies of plans. I bought a short kit from them that I used to build my second 1/3 scale Jungmeister. It was a high quality laser cut kit. I don't know why they chose to redraw the plans rather than sell copies of the original plans. Several people have commented that they are lacking in detail that the original had. I have built 2 Jungies from my set of original plans and as you can imagine, they are getting pretty ragged.
I don't know how much you have left to do but for $30 the Arizona plans should do fine.
Again, you might e-mail Gerry Yarrish <gerryy@airage.com> with Model Airplane News and see if he can locate the 1/3 scale plans. It's worth a try and won't take much effort on your part.
Ken
Hide Signatures
       Post #: 598
RE: Gary Allen 33% Bücker Jungmeister - 5/11/2008 4:48 AM
Jeff Foley
Score: 100
Status: offline
As a radial engine biplane lover (I own a full scale Stearman)......I find this photo extremely disturbing!! What a waste of good Jungmeister. I am enjoying seeing the models on this thread though.
Jeff
Click for fullsize
Jeff Foley
Team Horizon
Hide Signatures
       Post #: 599
RE: Gary Allen 33% Bücker Jungmeister - 5/11/2008 4:56 AM
Big_Bird
Score: 105
Status: offline
Jeff, that is major ugly. I assume it is turbine powered. Thanks for dropping in.
Ken
Hide Signatures
(in reply to Jeff Foley)
       Post #: 600
Jump to:
Google
SITE MAP!   : :   FORUM RULES
7.703RCU1
