bigdaddy
KS, USA Status: offline
Hello, Just seeking a little advice. Been lookin here for over a year. The pictures of your airplanes makes me drool. The wife said to either build one or she was gonna put a bib on me. I hate bibs. Have an idle G 62 and am starting to collect supplies to build this aircraft 1/3 scale. Have the 1/3 plans from Arizona Models ( a disappointment ) and 1/3 plans from MAN ( alot better). My R/C club built a scale static display Wright Flyer for a local museum ( Kansas Cosmosphere and Space Center) that was a Arizona Models Kit. Based upon this experience ( and the plans they supplied ), I would be reluctant to go with their short kit. How accurate is the laser cutting of this Arizona Models kit and what was your impression of the wood parts supplied? Would you use it again? What about wheels? 6" Sullivan, 6" inflatable Dubro, or the solid 6" Dubros. What are you using and how is it? Have read all 608 posts here and studied both sets of plans over the last week and using the photos and text here I am ready to take the plunge. Have spruce form Aircraft Spruce and Supply, 6061 T6 from onlinemetals.com.. Can get fiberglass parts from Precision Fiberglass products if decide not to get the Arizona kit. Noted are the comments about antirotation pins on outboard ribs, 5/32 tail gear wire, solder clevis on rigging wires( 0.093), target weight of 25 -28 lbs., 2degrees right and zero down on the engine. Have full scale experience with Stits, will cover with Stits light. Any words of wisdom would be greatly appreciated. Thanks, Jerry Hutchinson, Kansas
