RE: L39/Wren 44 Pics and video    Gallery
Logged in as Guest
    Search This Thread
Printable Version
F-16 1/8 Advanced - ARF
Seller:  AndyAndrews
Details:   $2,800.00   |  6/17/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: L39/Wren 44 Pics and video
Page: <<   < prev  159 160 161 162 163 164 165 166 [167] 168   next >   >>
Login
RE: L39/Wren 44 Pics and video - 11/23/2012 12:42 PM
Yann
Score: 100
Last Login: 6/19/2013
Status: offline
Yes they work as good but are of a different shape. I'd be interested if someone could source them. I'll see tonight if I can post a picture.
Hide Signatures
(in reply to pzv89h)
       Post #: 4151
RE: L39/Wren 44 Pics and video - 11/23/2012 12:49 PM
pzv89h
Score: 100
Last Login: 1/20/2013
Status: offline
Dera All
Take a look at post 3549 and 896,
3549 are the origional tanks which are no longer available from Netto, However I also have a box of bottles that can be used as tanks on the L39 I will post photos over the weekend
I also believe the Graupner 1 litre tank fits well plus a UAT or chainsaw clunk
Regards
Gordon
Hide Signatures
(in reply to Yann)
       Post #: 4152
RE: L39/Wren 44 Pics and video - 11/23/2012 1:19 PM
Yann
Score: 100
Status: offline
No, the netto bottles had a green cap and were no clear plastic.
They can be seen page 72 of this thread. That was back in 2005... my plane has changed a lot since then...
< Message edited by Yann -- 11/23/2012 7:38 PM >
Hide Signatures
       Post #: 4153
RE: L39/Wren 44 Pics and video - 11/23/2012 6:44 PM
J.F
Score: 100
Last Login: 6/16/2013
Status: offline
2005... Where has the time gone
Hide Signatures
(in reply to Yann)
       Post #: 4154
RE: L39/Wren 44 Pics and video - 11/23/2012 7:31 PM
H.Dale
Score: 100
Last Login: 6/13/2013
Status: offline
Well I decided to spend the money and go with Down & Locked electric conversion of my Spring Air 301 retracts. A little pricy but a really first class conversion. If you want really realistic looking operation and less hassle they are the only way to go.
Click to see fullsize image.
Click for fullsize
< Message edited by H.Dale -- 11/23/2012 9:52 PM >
Hide Signatures
(in reply to J.F)
       Post #: 4155
RE: L39/Wren 44 Pics and video - 11/23/2012 7:38 PM
Yann
Score: 100
Status: offline
HEYYYYYYYYYYYYY James, what have you been up to... since 2005?
Hide Signatures
(in reply to H.Dale)
       Post #: 4156
RE: L39/Wren 44 Pics and video - 11/23/2012 11:13 PM
H.Dale
Score: 100
Status: offline
Yann what is the distance between your turbine and the pipe? I am remounting my 44 and I want to make sure I have the proper distance.
Hide Signatures
(in reply to Yann)
       Post #: 4157
RE: L39/Wren 44 Pics and video - 11/24/2012 7:56 AM
ModellbauUK
Score: 101
Last Login: 6/18/2013
Status: offline
So the general consensus is turbine.  Guess the HobbyKing Hawk is a better choice if you want EDF of this size
< Message edited by ModellbauUK -- 11/24/2012 6:41 PM >
_____________________________
www.modellbauuk.com
The Aurora Project
The Kestrel Project
FCT Kevlar & Hopper Tanks
Hide Signatures
       Post #: 4158
RE: L39/Wren 44 Pics and video - 11/24/2012 10:37 AM
Yann
Score: 100
Status: offline
If you use a wren pipe, distance from pipe to turbine should be 10mm if regular wren44, and 30mm if wren44 gold.
Schematics post#1746 (page 70). If needed I can make you an engine mount post#1598 (page 64).
I Still have some parts lying around since 2005 and I just digged out the CAD files.
Hide Signatures
(in reply to ModellbauUK)
       Post #: 4159
RE: L39/Wren 44 Pics and video - 11/24/2012 11:27 AM
BaldEagel
Score: 118
Status: offline
quote:
ORIGINAL: ModellbauUK
Was my little survey for Turbine vs EDF removed from this thread?
Ian
Ian
Perhaps you ought to start a separate poll?
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
       Post #: 4160
RE: L39/Wren 44 Pics and video - 11/24/2012 11:36 AM
Yann
Score: 100
Status: offline
I think the activity on this thread after all these years, the number of posts and views say it all...
Hide Signatures
(in reply to BaldEagel)
       Post #: 4161
RE: L39/Wren 44 Pics and video - 11/24/2012 6:44 PM
ModellbauUK
Score: 101
Status: offline
quote:
ORIGINAL: BaldEagel
Ian
Ian
Mike
Realised there was a lot of posts after my last post so clearly still a great deal of intereste this little L39
www.modellbauuk.com
The Aurora Project
The Kestrel Project
Hide Signatures
       Post #: 4162
RE: L39/Wren 44 Pics and video - 11/24/2012 6:52 PM
hooker53
Score: 100
Status: offline
quote:
ORIGINAL: BaldEagel
Ian
Ian
Mike
You can bet on it. This is one of the best small turbine or first EDF's out there. I have a new one in the box but it won't be for long.
Roy
Scratch it till it bleeds Convert it till it chokes
Hide Signatures
       Post #: 4163
RE: L39/Wren 44 Pics and video - 11/24/2012 6:56 PM
ModellbauUK
Score: 101
Status: offline
 Think the new baby Jets Munt turbine shown at Jetpower will be perfect for the L39.  4kg of thrust. 60mm diameter casing. Got to be worth considering as it should  be a whole lot lighter than the Wren44.
www.modellbauuk.com
The Aurora Project
The Kestrel Project
Hide Signatures
       Post #: 4164
RE: L39/Wren 44 Pics and video - 11/24/2012 7:00 PM
hooker53
Score: 100
Status: offline
A few are putting the first Man start 44 in them. Where as you leave most of your WT on the ground it fits right well. Turbine turned back of coarse. Ha.
Hide Signatures
       Post #: 4165
RE: L39/Wren 44 Pics and video - 11/24/2012 7:01 PM
ModellbauUK
Score: 101
Status: offline
 Just a thought, might be worth making a bespoke Kevlar  tank for the L39, I'll look into this if there's interest. A bit of bling and a whole lot more cost than a shampoo bottle but worth a look I feel. fibreglass tank may be a better option as a whole cheaper to produce.
www.modellbauuk.com
The Aurora Project
The Kestrel Project
Hide Signatures
       Post #: 4166
RE: L39/Wren 44 Pics and video - 11/24/2012 7:08 PM
ModellbauUK
Score: 101
Status: offline
 One of mine has the original wand type start wren44 with a hinged hatch cut out in fuzz to start the turbine.
www.modellbauuk.com
The Aurora Project
The Kestrel Project
Hide Signatures
(in reply to hooker53)
       Post #: 4167
RE: L39/Wren 44 Pics and video - 11/24/2012 7:33 PM
hooker53
Score: 100
Status: offline
You have it. That's the way Boomerang showed me how to set mine up. I will watch with interest the makings of the fuel tank. I will fly mine with the EDF set-up but know the 44 will wind up in it!! Lol. If I keep the 44.
Hide Signatures
       Post #: 4168
RE: L39/Wren 44 Pics and video - 11/24/2012 7:45 PM
Yann
Score: 100
Status: offline
If you guys make a kevlar tank, I want to be on the waiting list. A two 0.5l tank setup is perfect as you don't really need a UAT.
Hide Signatures
       Post #: 4169
RE: L39/Wren 44 Pics and video - 11/24/2012 8:07 PM
hooker53
Score: 100
Status: offline
Yann. This will be good for a 44 set-up. I will also need a pipe but I can make that myself.
Hide Signatures
(in reply to Yann)
       Post #: 4170
RE: L39/Wren 44 Pics and video - 11/24/2012 8:16 PM
Yann
Score: 100
Status: offline
You can get a pipe for the Wren44 from Wren...
Talking about Wren and memories back from 2005, I liked talking to Sara at Wren. She was nice and very helpful...
Too bad she is no longer part of the Wren team...
Hide Signatures
       Post #: 4171
RE: L39/Wren 44 Pics and video - 11/24/2012 8:28 PM
hooker53
Score: 100
Status: offline
Yes. We all miss Sara. Making a pipe is no problem. Have the equipment and have worked with SS and Aircraft Alum all my life. One this short would be a cinch but if a used one came up on RCU .............. Ha.
Hide Signatures
(in reply to Yann)
       Post #: 4172
RE: L39/Wren 44 Pics and video - 11/24/2012 8:37 PM
H.Dale
Score: 100
Status: offline
Two of the best ladies in jets. Sara at Wren and Patricia at Boomerang Jets. Is is a coincidence they are both from "jolly ole England"?
Hide Signatures
(in reply to Yann)
       Post #: 4173
RE: L39/Wren 44 Pics and video - 11/24/2012 8:41 PM
Gary Arthur
Score: 105
Status: online
Hey...Does anyone have a spare L-39 airframe for turbine use that they want to part with. A friend of mine had a mishap this past week and needs a new one. Just the airframe for turbine use that accepts flaps, rudder and retracts.
Hide Signatures
       Post #: 4174
RE: L39/Wren 44 Pics and video - 11/24/2012 11:14 PM
BaldEagel
Score: 118
Status: offline
If your looking for an L39 for a small turbine, have a look at the Jet Teng airframes, build here: http://www.rcuniverse.com/forum/m_10434227/mpage_1/key_/tm.htm and link to the site on post two.
Mike
Hide Signatures
(in reply to Gary Arthur)
       Post #: 4175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.656RCU1
