digitech
Joined: 8/23/2004 From: klimmenlimburg, NETHERLANDS Status: offline
quote:
ORIGINAL: siclick33 My concern would be the seal of the Tygon on the pump. It may well be OK but it is not how I do it. I use a BVM UAT with the stiff 6mm tube supplied. I then use a Festo reducer and use smaller diameter line onto the pump. Some people don't like this idea as it puts the Festo in the suction side of the system but I have never had any problems. As to filter, I always use one between the pump and the engine. Wren can supply a filter that I have used before with good results. Festo specs are Vacuum or pressure -6 +8 BAR so dont worry i been doing this for years.
_____________________________
Sandor Kruise Dealers for:JetCat,Graupner,Futaba,Fei-Bao,Pro-Lynx,Airpower,Jets-munt,Xicoy,Jet-1A,Composite-ARF. "Home of the Pro-Lynx Gears"
