RE: L39/Wren 44 Pics and video
Tower Hobbies
Logged in as Guest
  Printable Version
Airworld BAe Hawk - RTF
Seller:  rambat1
Details:   $23,000.00   |  8/17/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: L39/Wren 44 Pics and video
Page: <<   < prev  152 153 154 155 156 157 158 159 [160] 161   next >   >>
Login
RE: L39/Wren 44 Pics and video - 4/18/2008 9:21:58 PM
GrayUK
Status: offline
Post the details on the FASST testing thread, i would love to see the model and details.
Paul
_____________________________
All the knowledge in the world, is of no use to fools.
(in reply to Yann)
       Post #: 3976
RE: L39/Wren 44 Pics and video - 5/3/2008 11:57:20 AM
David Gladwin
Status: offline
Another 4 flights on mine today in perfect Australian weather, (5 knots , clear blue sky, plus 20 c) . It just gets better with almost unlimited vertical (Wren 44 Gold Plus), immaculate starts now that I have turned the gas down a little and really excellent slow flight. The Spektrum, too, performed perfectly, one flight had less than 7 antenna fades on ALL receivers, just brilliant ! 9 minute flights all on less than 1 liter of fuel, impressed all who saw her !
Regards, David Gladwin.
(in reply to GrayUK)
       Post #: 3977
RE: L39/Wren 44 Pics and video - 5/3/2008 12:32:12 PM
GrayUK
Status: offline
David
Glad to hear all is well.
I have been flying mine over that last 3 weeks fitted out with FASST, great system in a great model.
Everytime i come back to it i am amazed at just HOW good this bird it!
Best value for money/ fun out there!
Paul
(in reply to David Gladwin)
       Post #: 3978
RE: L39/Wren 44 Pics and video - 5/13/2008 4:01:37 PM
bidrseed2
Status: offline
Anyone got a set of Jet A1 main legs that are now redundant??
After a recent arrival, I snapped the main leg pin, and cannot remove it. I then managed to knacker the leg trying to remove it.
So if youre in possession of a pair of mains you would like to sell, please let me know
And if you are using these legs, i think i saw a post earlier on this thread, suggesting using piano wire, or acquiring titanium rod to use instead. After a frustrating afternoon, id suggest heeding that advice.
If Digitech are reading this, Id appreciate if you can get in touch if you have spare upper parts of the mains available.
(in reply to Yann)
       Post #: 3979
RE: L39/Wren 44 Pics and video - 5/22/2008 9:11:47 AM
siclick33
Status: offline
I'm not sure if this has been posted already but pics of the wing tank and protective bags are now on the Savex site.
Looks good.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
It was all going really well, then I suddenly ran out of talent!
(in reply to bidrseed2)
       Post #: 3980
RE: L39/Wren 44 Pics and video - 5/22/2008 6:58:50 PM
swissflyer
Status: offline
the bags looks terrific...
just...how do you do with the landing gear??? there are cuts??
Alessio
MO13
(in reply to siclick33)
       Post #: 3981
RE: L39/Wren 44 Pics and video - 5/22/2008 7:07:17 PM
GrayUK
Status: offline
You lock the landing gear up.
Paul
(in reply to swissflyer)
       Post #: 3982
RE: L39/Wren 44 Pics and video - 5/22/2008 7:34:05 PM
swissflyer
Status: offline
quote:
ORIGINAL: GrayUK
Paul
i guess i''m the only one having difficulties then...
tape won't work..glue..well no..
only air can do it...
and is a little bit complicated..
i guess a cutter will work..with the bag..
Alessio
MO13
       Post #: 3983
RE: L39/Wren 44 Pics and video - 5/22/2008 7:48:20 PM
GrayUK
Status: offline
I retract the gear before i take the wing off.
A small wood wedge is used between the wheel tyre and the wheel well.
It locks them up.
The nose wheel is locked up with a thin piece of ply (3mm thick) placed across the opening, beween the body and the leg.
It holds them up till next time...
Paul
       Post #: 3984
RE: L39/Wren 44 Pics and video - 5/24/2008 6:24:44 AM
andrewjet
Status: offline
I'm hoping for a quick reply! I have the spring air retract valve that's but it leaks air from the top, is there a way to repair this? I've tried to adjust the valve at any position but only when the valve is pointed in the direction where the retracts are down does it not leak! It is in the correct position so that's out of the sugestion!
thanks
       Post #: 3985
RE: L39/Wren 44 Pics and video - 5/24/2008 6:34:20 AM
andrewjet
Status: offline
Another question or question 2!
I also have a single action jet valve but i can't figure out how to make it work with the retracts so i went back to the spring air retract. My second question, how does it work when there is an intake and pass on take but when i connect it like i connect the breaks the the switch is one direction it retracts but when i switch it in the other direction it releases the air momentary but it will not release the retracts until all the air is unloaded from the tank? If i can get answers to both question i would greatly appriciate it!!!
thanks a ton guys! I haven't been able to get it in the air yet!!! I can't tell you how i wished someone would have posted if you use the 7channel radio like the spektrum and if you are using springair retracts that it will take you several days and more to get the damn thing to work!!!!
(in reply to andrewjet)
       Post #: 3986
RE: L39/Wren 44 Pics and video - 5/24/2008 7:57:58 AM
GrayUK
Status: offline
quote:
ORIGINAL: andrewjet
Question 1
Need more info, but may be related to question 2.
Question 2
You have the valve connected backwards.
The valve has a position that puts air into the retracts, when it switches to ‘gear down’ it locks of the air from the tank, and vents the air from the retracts.
Try reversing the air lines to the valve.
I have reported in the thread, flying with FASST system, no problems, works perfectly.
Paul
       Post #: 3987
RE: L39/Wren 44 Pics and video - 6/5/2008 7:29:24 PM
rcdriver22
Status: offline
quote:
ORIGINAL: siclick33
Looks good.
This is my next MKIII L39 bought second hand but new in its box with all the protective bands. What carbon fibre reinforcing is used for the turbine, what sho
