gulfstreamI -> RE: Walmart Submarine = Cool ! (3/22/2004 7:54 PM)
quote:
ORIGINAL: analli To add to my confusion we've now modded the controller! [;)] Looks great though. Do you have a step-by-step on how you did this and where you picked up that super cool flex antenna? Thanks! [:D] 1) Just remove the four screws holding the back cover of the transmitter. 2)After removing the back cover be very careful with the green push buttons, they fall right off. As you can see this sub's transmitter is NOT WATERPROOF. [X(] It's just WATER RESISTANT. 3) Remove the old "wire antenna" by loosening the single screw that holds it. 4) The "flex antenna" or "rubber ducky antenna" as some call it, is from Radio shack. The N.P.A. (National Parts Authority) part # : A 90441 , part name: Transmitter Antenna 5) You have to "pull out " a least two coils & straighten it from the flex antenna bottom as it will not readily fit into the sub's transmitter housing. 6) Re-tighten the screw that will hold the new flex antenna in place. 7) Be careful when you put back the front cover of the transmitter, the push buttons for "surface" and "dive" has to be aligned properly or you may have a malfunction when you test the sub. 8) Use a rechargeable 9 Volt battery for this toy. I'm sure you'll drain an ordinary 9 Volt battery with this toy in no time at all. Tell me how's it going when you're done. gulfstreamI
