analli -> RE: Walmart Submarine = Cool ! (3/24/2004 11:33 PM)
quote:
Don't forget to add styrofoam material IF you plan to mod the stock prop. You will need it when you mod the antenna. I don't mean to keep buggin' ya, but yoo certainly da man! I can see why you'd add styrofoam with the prop mod with the change in the center of gravity (or something), but why add foam for the antenna mod? Would that not make the rear of the sub too buoyant? Oh, FYI, the reason I want to stick with the stock prop is that I see subs as slow moving, so tossing this baby in my pool I don't want to see it zipping around. That's why I didn't get a one of those boats. As long as the stock prop propells the sub reasonably. I think I'll be happy. (I just got the subs two days ago and haven't even seen them in action yet). Does my rationale seem reasonable or is the prop mod a must-do?
