GWS Slow Stick Survey
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Park Flyers & Backyard Flyers >> GWS Slow Stick Survey
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
GWS Slow Stick Survey - 1/3/2004 11:22 PM
Billiam411
Score: 100
Last Login: 8/17/2007
Status: offline
I just built the Slow Stick kit and I'm looking for a good setup. I've flown before.
What's your setup:
Number of cells: ________ What brand/mAh: ________
ESC model: ________
Servos: ________
Transmitter/Receiver: ________
Motor (stock or...): ________
Modifications: ________
Comments on flight characteristics: _________
- "I failed the quiz!"
Good luck!
_____________________________
bout time to git the old dusty trail....
*walks backward slowly*
Hide Signatures
       Post #: 1
RE: GWS Slow Stick Survey - 1/4/2004 1:14 AM
jkind
Score: 100
Last Login: 4/10/2009
Status: offline
Number of cells: _8_______ What brand/mAh: 730mah AAA nimh GWS
ESC model: Plantraco rx/10 amp esc combo DSC-4SP
Servos: HItec hs-81
Transmitter/Receiver: Hitec Laser 4 Plantraco rx/esc combo
Motor (stock or...): stock
Modifications: Changed thrust angle
Comments on flight characteristics: Flies very well, unlimited consecutive loops. First motor lasted 50 flights on this setup. Have flown in winds up to 15mph with good results.
Jim
< Message edited by jkind -- 1/4/2004 4:26:18 AM >
Hide Signatures
(in reply to Billiam411)
       Post #: 2
RE: GWS Slow Stick Survey - 1/4/2004 1:45 AM
darrell_f
Score: 100
Last Login: 1/16/2008
Status: offline
Number of cells: _started with 7, very quickly went to 8_______ What brand/mAh: __All e RC 800 AAA and 650 2/3 AA
ESC model: _Castle Pixie 20_______
Servos: _Hitec 81_______
Transmitter/Receiver: _Hitec Flash 5, Hitec 555
Motor (stock or...): __started with stock 300, very quickly went to 350______
Modifications: Good ones: down-right thrust mod, brass rod tube, extra wire on landing gear, hi-strength tape on wing edges, raised trailing edge 1/4", prop saver. Not so good ones: balsa in fuselage, too much tape on tail (both caused too much weight on tail)
Comments on flight characteristics: probably too heavy, getting about 7 minutes fly time per charge.
Advice to new SS builders: Use the lightest components that you can and don't even think about flying in wind. I've spend as much on replacing props and shafts as the SS cost.
Hide Signatures
(in reply to jkind)
       Post #: 3
RE: GWS Slow Stick Survey - 1/4/2004 3:26 AM
john 8750
Score: 100
Last Login: 5/31/2009
Status: offline
quote:
ORIGINAL: Billiam411
What's your setup:
Number of cells: ___2_____ What brand/mAh: __1200 e-tech______
ESC model: ___100_____
Servos: __standard______
Transmitter/Receiver: _Hi teck_______
Motor (stock or...): ___stock_____
Modifications: ___none_____
Comments on flight characteristics: _great________
Good luck!
Keep the fun in it!
Hide Signatures
       Post #: 4
RE: GWS Slow Stick Survey - 1/4/2004 4:52 PM
Hypter
Score: 100
Last Login: 6/22/2009
Status: offline
GWS 6Cell 400mAh pack
ICS100 5Amp ESC
Mini GWS Servos
Futaba 6X / Standard HiTec RX
No mods
10 minute flights on a new pack
< Message edited by Hypter -- 1/4/2004 11:54:09 AM >
Hide Signatures
(in reply to john 8750)
       Post #: 5
RE: GWS Slow Stick Survey - 1/4/2004 4:57 PM
bigdrawz
Score: 100
Last Login: 2/4/2007
Status: offline
I am needing some answers on electric questions.I fly glow planes however,I am wanting to order a slow stick for flying at schoolyards,will a slowstick work with an artronics 4 channel radio with standard reciever and servos or will this be to much weight. im trying to get into it cheap and only want to buy an ESC and battery pack.I have seen slow sticks carrying cameras so i was thinking that I could get by with standard reciever and servos. any help from some of you slowstick flyers would help. E-mail bigdrawzlinder@aol.com Thanks very much.
Hide Signatures
       Post #: 6
RE: GWS Slow Stick Survey - 1/4/2004 5:04 PM
Hypter
Score: 100
Status: offline
Im sure you will be fine, GWS says it will fly with standard equiptment, im using a standard RX and the mini GWS servos I have are not much smaller or lighter than my standard ones.
Hide Signatures
(in reply to bigdrawz)
       Post #: 7
RE: GWS Slow Stick Survey - 1/5/2004 3:03 AM
john 8750
Score: 100
Status: offline
My SS has standard gear and flies great. Everything is stock.
Keep the fun in it!
Hide Signatures
(in reply to Hypter)
       Post #: 8
RE: GWS Slow Stick Survey - 1/5/2004 4:50 AM
dive4life
Score: 100
Last Login: 6/13/2008
Status: offline
3D "NOT SO" SLOW STICK
Thunder Poly 3s 2100mah
phoenix 10
naro std servos w/ GWS TX/RX
Himax 2015-4100 w/ GWS D Gearbox 12x8 gws prop
Mild mods I can think of off hand are copper tube to replace the stock aluminum tubing, 3 strips of clear packing tape across underwing for support, carbon string rudder/elevator support.
Have had good results withthis setup 1hr 15min + flight times. Can hover, ROG and climbs out of sight in about 20 seconds, light aerobatics, outside loops without effort, inverted flight, current setup pushes this bird to it's limits but makes for one hell of a $30 kit.
Looking for a good camera now for aerial vid and pics.
Good Luck
What's your setup:
ESC model: ________
Servos: ________
Good luck!
Hide Signatures
       Post #: 9
RE: GWS Slow Stick Survey - 1/5/2004 5:30 AM
john 8750
Score: 100
Status: offline
What do you mean " 30 dollar kit " Mine cost 35.
AHHHHHHHHHHHSOME plane you built.
I like it!
Keep the fun in it!
Hide Signatures
(in reply to dive4life)
       Post #: 10
RE: GWS Slow Stick Survey - 1/5/2004 6:09 PM
BuzzBomber
Score: 100
Last Login: 7/4/2009
Status: offline
Number of cells: 2 What brand/mAh: Etec 1200
ESC model: GWS ICS100
Servos: HS55
Transmitter/Receiver: Hitec Eclipse/GWS R-8M
Motor (stock or...): stock--with 1260 prop
Modifications: added curtek light system
Comments on flight characteristics: It's great on calm days or days with a light steady wind, can do multiple loops, climbs out @ 60* WOT, slows to a crawl, and flies inverted as long as I can keep it from rolling over. It is great fun at night, because that big wing lets it fly slowly and is super easy to track with the lights on. On the downside, it could could use more rudder authority, as crosswind gusts routinely roll it inverted at inopportune times, and it will NOT spin or rudder roll, even with 45* deflection each side. All in all, a great plane for many uses (as long as its not too windy).
Matt Smith
If you re not having fun, you re missing the point.
Hide Signatures
       Post #: 11
RE: GWS Slow Stick Survey - 1/5/2004 7:42 PM
Mr Dipthong
Score: 100
Last Login: 4/24/2007
Status: offline
Number of cells: ____6____ What brand/mAh: ____900 mAh NIMH____
ESC model: ____Great Planes CS10____
Servos: ____Airtronic Standard Size____
Transmitter/Receiver: ___Airtronic VG4_FM - Standard Size____
Motor (stock or...): ____Stock 300____
Modifications: ____None____
Comments on flight characteristics: ____Will loop from level flight on a fresh charge. 12min duration at 3/4 throttle. Very stable. Handles wind well because of 20oz. flying weight. This plane easily handles the standard size radio gear - a great solution for those that don't wan't to by new radio equipment._____
Glen
Hide Signatures
       Post #: 12
RE: GWS Slow Stick Survey - 1/6/2004 1:49 PM
BJAZ
Score: 100
Last Login: 3/14/2006
Status: offline
Number of cells: 7 What brand/mAh: 1000mAh
ESC model: Castle Creations Pixie 7P
Servos: Hitec 55 servos
Transmitter/Receiver: Hitec Laser 4 ch. / Hitec single conversion Feather reciever
Motor (stock or...):Stock 300
Modifications: Used good tape, epoxied/taped fiberglass rods to LE and TE of wing, did not cut fuse, bolted motor to fuse, epoxied rudder and elevator to fuse, Dubro ultra lite wheels, cut the tips off one of my wings for stability in wind, home made floats for the snow, sturdy board tail feathers, more to come
Comments on flight characteristics: Flies great, cut wings work well in slight wind, floats are awsome
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by BJAZ -- 2/16/2004 3:57:51 PM >
Hide Signatures
(in reply to Mr Dipthong)
       Post #: 13
RE: GWS Slow Stick Survey - 1/7/2004 10:56 PM
Billiam411
Score: 100
Status: offline
All I need to buy are batteries and an ESC
If I run 8 cells, I'll want a 15-20A ESC - much like the ICS-480:
http://www.aeromicro.com/Catalog/gws_ics-480_esc_2870439.htm
8 cell NiMh pack:
Any suggestions?
Hide Signatures
(in reply to BJAZ)
       Post #: 14
RE: GWS Slow Stick Survey - 1/8/2004 1:14 AM
Kyle2Baseball
Score: 100
Last Login: 5/11/2007
Status: offline
Hs -81s i used hs 55s and they work great
I hate Florida Weather
I want to fly more
Hide Signatures
       Post #: 15
RE: GWS Slow Stick Survey - 1/8/2004 1:19 AM
Kyle2Baseball
Score: 100
Status: offline
I used HS 55s Gws 5 amp esc 11 x 8 prop not sure what brand but 8 cell 720 mah stock 300 motor works great brass tubing for wing tube connections cause the aluminum rod cut in half and almose folded the wing. I probably get a 15 to 20 min flight. it flys awsome
I want to fly more
Hide Signatures
(in reply to Kyle2Baseball)
       Post #: 16
RE: GWS Slow Stick Survey - 1/8/2004 6:29 AM
Craig c
Score: 100
Last Login: 12/29/2008
Status: offline
Number of cells: (3)________ What brand/mAh: Kokam 1500's ________
ESC model: Castle r/c sprite 25________
Servos: (2)GWS pico's(2)HS-55's________
Transmitter/Receiver: Futaba 6 EXA/ berg Dsp*5________
Motor (stock or...): GWS "D" gear Speed 400 gearbox/w_6 volt Permax 400 motor_______
Modifications: Assembled using foam CA and "3M Scotch cal thin decal tape, foam wheels Just added flaperons________
Comments on flight characteristics: _After switching to the speed 400 motor, I never looked back. It just does wonders for this plane. it is incredibly stable with the added weight of the batteries and bigger motor. Climb's just like the big boy's, pretty much straight up. Impressive speed for this draggy of a wing. I use a timer to keep runs under 14 mins. The flaperons add a whole new dimension to flying this plane, keeping my interest in it fresh.
Happy flying : )
Hide Signatures
       Post #: 17
RE: GWS Slow Stick Survey - 1/11/2004 2:16 PM
BJAZ
Score: 100
Status: offline
Nevermind
< Message edited by BJAZ -- 2/16/2004 4:30:04 PM >
Hide Signatures
(in reply to Craig c)
       Post #: 18
RE: GWS <span class= - 1/13/2004 3:40 AM
shades
Score: 100
Last Login: 4/10/2008
Status: offline
Number of cells: ______3__ What brand/mAh: __1500/kokam______
ESC model: __pixie 20p______
Servos: gws________
Transmitter/Receiver: ___gws or jr r700_____
Motor (stock or...): _stock/ astro a10_______
Modifications: ________glue front spars and and glue back spars and glue wing haves together, put foam reinforcment on rudder
Comments on flight characteristics: ___best flying plane ever!______
if you need tips on modifications i'am your man! i'am the slow stick master
< Message edited by shades -- 1/26/2004 3:23:42 PM >
Hide Signatures
(in reply to BJAZ)
       Post #: 19
RE: GWS Slow Stick Survey - 1/26/2004 12:48 PM
Kamikazi
Score: 100
Status: offline
Cells: 2s3p cell phone li-poly's 800mah each - 2400mah total - total pack weight 3.8 oz
ESC: pixie 20p
Servos: Micro 9's from allerc (these servos are a bit rough)
Xmtr: HiTec Laser 6 Rcvr: HiTec HFS-04MG
Motor: Stock EPS300C retimed for reverse rotation
Mods: Epoxied wing halves
AUW is 14.5 oz
Comments: Only flown twice so far. Need less wind and warmer temps. This thing flies *really* slow compared to my Sky Scooter. Definitely more sensitive to wind. Should work out great for my AP platform once the weather warms up. I expect flight times in excess of 45 minutes.
Climb rate is better than I expected.
< Message edited by Kamikazi -- 2/12/2004 1:42:37 AM >
Hide Signatures
       Post #: 20
RE: GWS Slow Stick Survey - 1/28/2004 4:18 PM
csisfun
Score: 100
Last Login: 1/10/2006
Status: offline
hmm SS must be a good plane...
I'll take it!
Looks dammm easy to build as compared to the 109 or the beaver or the TM...
Right?
Hide Signatures
(in reply to Kamikazi)
       Post #: 21
RE: GWS Slow Stick Survey - 1/30/2004 6:10 AM
mblueye
Score: 100
Last Login: 5/14/2004
Status: offline
two cell lith. 1500 MAH...can fly for 30 minute
ICS100 5Amp ESC
Mini GWS Servos
No mods
Hide Signatures
(in reply to csisfun)
       Post #: 22
RE: GWS Slow Stick Survey - 1/30/2004 6:38 AM
john 8750
Score: 100
Status: offline
quote:
ORIGINAL: csisfun
I'll take it!
Right?
Go for it. You wont be sorry, and can buy two for the same price of the war birds.
Let us know how she flies.
Keep the fun in it!
Hide Signatures
       Post #: 23
RE: GWS Slow Stick Survey - 1/30/2004 11:40 AM
csisfun
Score: 100
Status: offline
Arg. It ran outta stock. Must've been too popular.
Hide Signatures
       Post #: 24
RE: GWS Slow Stick Survey - 2/6/2004 6:12 AM
DanaWatson
Score: 100
Last Login: 12/31/2007
Status: offline
My current setup:
Number of cells: ___7_____ What brand/mAh: ___900_____
ESC model: _GWS ESC 480_____
Servos: ___Narvo STD_____
Transmitter/Receiver: __Flash 4__GWS R4P____
Motor (stock or...): __400C______
Modifications: __The norm______
Works well for me. I'm really just beginning.
Dana
There are three kinds of people in this world. Those who can count and those who can't.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.703RCU1
