RE: Getting a smooth surface with fibreglass
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> RE: Getting a smooth surface with fibreglass
Page: <<   < prev  1 [2]
Login
RE: Getting a smooth surface with fibreglass - 1/12/2004 11:23:32 AM
grahamd1
Status: offline
English Electric, in the UK Z-poxy is available (imported by Macgregor Industries).
The most common UK types of epoxy are
Pacer Z-poxy finishing resin
Ripmax Epoxy resin
Chemi-techniques finishing resin
However my own prefference is with West Systems, this can be purchased from any Chandlers (boat builders/suppliers), its great stuff.
(in reply to hnesitd1)
       Post #: 26
RE: Getting a smooth surface with fibreglass - 1/12/2004 3:24:04 PM
English Electric
Status: offline
Thank you. I will try and source the resin.
(in reply to grahamd1)
       Post #: 27
RE: Getting a smooth surface with fibreglass - 1/12/2004 6:17:02 PM
grahamd1
Status: offline
This is the UK site where the UK products have been tested
http://www.rcmodelflyers.co.uk/4um/
(in reply to English Electric)
       Post #: 28
RE: Getting a smooth surface with fibreglass - 1/13/2004 1:52:02 AM
newbiepilot
Status: offline
Ok, so Spackle is just premixed resin and microballoons, right? Does it have any strength in it? Could you use it to join parts together?
Thanks for the info.
I really appreciate it.
       Post #: 29
RE: Getting a smooth surface with fibreglass - 1/13/2004 2:15:23 AM
davidfee
Status: offline
No, spackle is not resin and microballoons. Lightweight spackle is water-based... probably an acrylic latex base of some kind (don't have a container of it to look at). It does not have much strength at all, as it is only used to fill small holes and sanding scratches. It would not work as an adhesive.
-David
< Message edited by davidfee -- 1/13/2004 2:44:01 AM >
(in reply to newbiepilot)
       Post #: 30
RE: Getting a smooth surface with fibreglass - 1/13/2004 5:37:41 PM
FLYBOY
Status: offline
As stated, don't use spackle as glue. It has not strength. I use it for fillets, but when they dry and are shaped right, I go over them with CA. Also, I use micro balloons mixed with epoxy. It makes good fillets, but you need it right, they don't sand well. You end up sanding the balsa too much and the glue not enough. I lay in the mix, put alcohol on my finger and smooth it to perfect and let it set up.
Mixing micro balloons in wood glue doesn't work well. The balloons suck up the moisture and it makes a mess. I have never had any luck doing it. You can try, but I think you will find the same.
_____________________________
Fly it till the wings come off.
(in reply to davidfee)
       Post #: 31
RE: Getting a smooth surface with fibreglass - 1/14/2004 1:18:34 AM
newbiepilot
Status: offline
What did you mean by this then:
"Spackle is the putty you fill pinholes in your walls with (in your house) before painting. Lightweight spackle usually has microbaloons (tiny glass bubbles) in it and it is very light."
       Post #: 32
RE: Getting a smooth surface with fibreglass - 1/14/2004 1:23:10 AM
newbiepilot
Status: offline
"Lightweight spackle usually has microbaloons (tiny glass bubbles) in it and it is very light. "
       Post #: 33
RE: Getting a smooth surface with fibreglass - 1/14/2004 1:27:24 AM
newbiepilot
Status: offline
Woops, I posted the same question twice. Sorry about that. So can Microballoons be used for joining two parts together, for filling and for some repair.
       Post #: 34
RE: Getting a smooth surface with fibreglass - 1/14/2004 1:56:40 AM
davidfee
Status: offline
Microballoons are just a dry filler material... they can be added to virtually any substrate. You can add them to polyester, epoxy, paint, regular wood glue... anything you want. They serve to make the resin/paint/glue more "thick" so it will stay in place. They also fill the substrate with air... the microballoons are tiny glass bubbles... so the thickened material ends up lighter. Because they are glass bubbles filled with air, they also make the cured/dried substrate easier to sand.
Microballoons and epoxy can be used to fill gaps, make fillets, bond composite panels... etc.
Microballoons and some type of water-based latex makes "lightweight spackle."
See here for lightweight spackle.
-David
       Post #: 35
RE: RE: Getting a smooth surface with fibreglass - 1/25/2004 6:05:20 AM
mattsimonton
Status: offline
alrighty
What is the weight difference between convenional covering and fiberglass
I was contemplating on glassing my delta vortex
I plan on putting a .91 in it so I really don't know weight would factor as much
but what is the price difference
and finally
does the same skill apply to sanding and filling glass bodys for cars(full scale)
Matt
       Post #: 36
RE: RE: Getting a smooth surface with fibreglass - 1/25/2004 9:30:01 AM
Mike James
Status: offline
mateo,
I wrote to Top Flite and asked them what the weight of their applied coatings was. (without the backing material) and they said "1.8 oz./sq.yd." for the opaque colors... slightly less for transparent. You can glass a plane and match this. But... you still have to add primer and paint. (and if you're so inclined, a clear coat) A glass finish will be heavier, but obviously "better", in terms of stability, longevity, and, if you're good, realism.
The cost will be higher, for the same reason. If you buy resin by the gallon, (say, West Systems, at about $90/gal) and glass cloth in bulk, you can glass a plane for less money than Monokote. But again, you'll have to add primer, paint, and optional clear coat. Then it'll cost a little more. (But, if the price increases of these products keeps going the way it is now, it'll soon be cheaper to use composites than film covering!)
And about the finishing...
Fiberglass is fiberglass... So yes, the same skills will yield the same results. Many of us here depend on the local "body man" to do some of these tasks.
I like both methods. I wouldn't bother to glass and paint a "knock around" .40-size aerobat, but I glass ALL of my "serious" projects.
< Message edited by Mike James -- 1/25/2004 12:28:34 AM >
Mike James
RC Design and Building - www.nextcraft.com
(in reply to mattsimonton)
       Post #: 37
RE: Getting a smooth surface with fibreglass - 10/5/2007 6:16:14 PM
rglawhead
Status: offline
I 've just finished my first attempt at fiberglassing a model. It was a TF FW 190 D9. I used Zpoxy and .75 oz weave. It was really a lot of fun, but messy. My question concerns the amount of sanding required, ie. what is the endpoint. According to the Master (Dave Platt), you can't sand too much. I used a light finishing epoxy coat. After several swipes with a square of Nelson's 80 grit sandpaper, it appears that I have sanded away most of the fiberglass weave. I tried to sand off the bumps and gloss of the finish, thinking that it doesn't really matter if I remove most of the fiberglass. The glass is not there to provide strength, but merely to provide a smooth substrate for the paint. Right? If that is right, why don't we just seal the balsa wood and paint over it? Anyway, do I need to recoat the plane? I plan to use "Duplicolor" high build primer/filler, so I don't think I need to recoat the plane just for paint adherence. Help.
(in reply to KC-135)
       Post #: 38
RE: Getting a smooth surface with fibreglass - 10/6/2007 3:31:12 AM
kahn41
Status: offline
I beleive the glass is the strength, glass with the resin does not break very easy, just the resin does... What I use is minwax water base poly with glass. 6 coats took less time to apply than than 2 coats of resin. WB poly dries in about 10 min and a wing took me no time at all. The last thing you want to do is sand into the glass
(in reply to rglawhead)
       Post #: 39
RE: Getting a smooth surface with fibreglass - 10/6/2007 4:05:46 AM
saramos
Status: offline
rg, 80 grit is too coarse. I use west systems and Duplicolor high build primer for filling the weave. I lay the glass down, brush on the epoxy with a disposable brush, squeegee off excess with those fake credit cards you get in the mail and then blot with toilet paper.
Once cured, I spray a coat of high build primer and then wet sand with 360 grit back to the top of the epoxy (don't sand too much or you can sand through the epoxy). I repeat the prime/sand process until the surface is smooth. Be sure to let the primer fully dry between coats (and especially on the last coat) or the primer will continue to dry and shrink and the weave will show again. Now the surface is ready for surface detailing and/or for a final (non high build) primer coat before painting.
Scott
       Post #: 40
RE: Getting a smooth surface with fibreglass - 10/6/2007 1:21:17 PM
Campy
