davidfee
Joined: 6/21/2003 From: San Diego, CA, USA Status: offline
Z-Poxy is nothing more than a reasonably good low viscosity epoxy, similar to most laminating epoxy resins. It just happens to be sold to modellers in a convenient small package, unlike most good epoxies (which are sold by the gallon). As for the sanding and filling, what weight of fiberglass did you use? It should be a light glass with a fine weave, so there should not be much filling or sanding to do really. A lot of guys seem to like applying a wet coat of resin to fill the weave, but resin is fairly heavy and it's not particularly strong... so in my mind it's wasted weight. But whatever. If the glass is fine then my suggestion would be to sand it smooth and if there are any dry spots or deep wood grain, fill those with spot putty or lightweight wall spackle as needed. There should be no "Bondo" car body filler on your airplane (very heavy)! After the largest bumps have been sanded down, then spray on a high bulk "sandable" primer... and when dry, sand back down to the glass so the primer just fills the low spots remaining in the weave. Repeat until satisfied with surface, then paint as desired. One of the best tips anyone can give is to try any new technique or material on a piece of scrap... not on your pride and joy. Patience here will really pay off. -David
