RE: 4-stroke fuel--Does anyone really know?
Tower Hobbies
Logged in as Guest
  Printable Version
Area 51cc Gas Engine - RTF
Seller:  Milton
Details:   $399.95   |  6/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> RE: 4-stroke fuel--Does anyone really know?
Page: <<   < prev  1 [2]
Login
RE: 4-stroke fuel--Does anyone really know? - 1/30/2004 8:40:54 PM
Dart373
Status: offline
Thats the way I have run my 4 stroke airplane engines for ever. one of my 61 Magnums has almost 500 hours on it...... still strong.
< Message edited by hobbsy -- 1/30/2004 10:59:31 PM >
_____________________________
Where there is confusion, there is profit.
AMA # 403098
(in reply to 3d-aholic)
       Post #: 26
RE: 4-stroke fuel--Does anyone really know? - 1/30/2004 10:54:05 PM
RCXPLANES
Status: offline
Post removed by moderator, not RC related.
< Message edited by hobbsy -- 1/30/2004 10:58:41 PM >
Life is short. Fly hard and enjoy.
Bud Wilkinson, RC-Xplanes, www.rcxplanes.com
(in reply to Dart373)
       Post #: 27
RE: 4-stroke fuel--Does anyone really know? - 1/30/2004 11:08:13 PM
Dart373
Status: offline
Post removed by Moderator, not RC related.
< Message edited by hobbsy -- 1/30/2004 11:02:10 PM >
AMA # 403098
(in reply to RCXPLANES)
       Post #: 28
RE: 4-stroke fuel--Does anyone really know? - 1/30/2004 11:43:59 PM
RCXPLANES
Status: offline
< Message edited by hobbsy -- 1/30/2004 11:01:32 PM >
       Post #: 29
RE: 4-stroke fuel--Does anyone really know? - 2/2/2004 10:47:15 PM
Bax
Status: offline
quote:
ORIGINAL: errolw98
What part of the rod fails on a two stroke before piston siezure? The small end at the wrist pin?
From what we've seen, when the lubrication breaks down, the lower-end of the connecting rod tends to seize to the crankpin and gets twisted off. This will scatter metal shreds throughout the engine. Sometimes the heat from the friction is high enough to actually weld pieces of the rod's bushing onto the crank.
When the rod seizes to the crankpin, you can literally see the blackening on the crankpin from the heat.
We've rarely seen problems with the upper end of the rod. What we have see, though, is congealed/cooked fuel residue that just fills the clearances and makes the rod move stiffly on the wrist pin. Sometimes it's so bad that the rod's not turning on the wrist pin, but the rod/pin assembly's turnin in the piston!
< Message edited by Bax -- 2/2/2004 10:52:45 PM >
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
       Post #: 30
RE: 4-stroke fuel--Does anyone really know? - 4/13/2004 11:34:37 PM
norbe
Status: offline
I was looking over this post and I find it very intresting since everyone has his own opinion on a issue that should have no opinions since it's mechanical, and as we know mechanics are like math there is no second opinions just a solution.
Now My question is this, I have had only 4 stroke and Gasoline engines, because I like the way they sound, now I happend to have bought a TT 120Pro 2 Stroke and I would like to know if I can use the same fuel on both a 4 stroke and a 2 stroke or not. I use Omega 5 stroke fuel, and on the bottle it says nothing about oils. I know it is 15% (nitro?), could some one tell me if I risk the funcionality of the TT using 4 stroke fuel?
(in reply to Bax)
       Post #: 31
RE: 4-stroke fuel--Does anyone really know? - 4/14/2004 1:12:00 AM
Hobbsy
Status: offline
As long as there are different brands, different blends, different percentages within those blends and brands there are going to be many differing opinions as to which is best. I use Fox 5% nitro with 20%-50/50 lube in all my two strokes and WildCat 10% Premium and WildCat 15% Premium Extra in my Saitos and Enyas depending on the compression and WildCat ProMix 20% nitro in my YS's, the ProMix has a couple of percentage points of castor in it. These are my choices because they work very well. I do not use any fuel without castor. A couple of my Saitos and one of my Enya's are 13 years old.
Giant Saito, 73.2 Cu. In., 70.5HP @ 5,800 rpm, 79 ft. lbs torque @ 3,500 rpm, 57 mpg, 3.50 bore, 3.81 stroke. 563 lbs.
(in reply to norbe)
       Post #: 32
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU1
