4-stroke fuel--Does anyone really know?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> 4-stroke fuel--Does anyone really know?
Page: [1] 2   next >   >>
Login
4-stroke fuel--Does anyone really know? - 1/4/2004 9:05:40 PM
3d-aholic
Status: offline
I've read an enormous amount of information about 4 stroke fuel now. I've read articles that show scientific proof why less oil is better and different articles why 4 strokes need more oil. On the Wildcat website, they explain that 4-strokes need more oil than 2 strokes...but their 4 stroke fuel only has 15-16%. There is a fuel FAQ running around somewhere on the Internet that explains that 4 strokes need less oil....because the same oil is in the engine longer. My conclusion is that no one really knows. So I'm giving up on that question.
Now, my question is what is better in a 4-stroke. Castor or Synth.?
The Wildcat website says 100% synth.
YS must think Synth because they recommend the 20/20 which seems to be 100% synth.
My engine says a mixture of both are best.
How can there be so much disagreement? Does noone know the answer to this question either?
       Post #: 1
RE: 4-stroke fuel--Does anyone really know? - 1/5/2004 3:28:39 AM
RaceCity
Status: offline
There is no "real" answer to your question unfortunately.
The castor/synth debate has raised the blood pressure of many people on this, and other
forums related to r/c.
Castor has unparalleled performance at high temperatures. When synthetics have burned
away....castor is still there..lubricating.
But....castor will leave a residue that in time,will carbonize and need to be removed.
Synthethics run clean. There is little, if any residue left over and the lack of residue is
IMO sometimes interpreted as "better".
The fact that it "vanishes" without a trace should bother you.
Fuel manufacturers have a vested interest in convincing you that their "special" oil is better.
Truth is...if it's so "special"...why doesn't the whole world use it?
Dirty or not. Castor stays while the others burn away.
My philosophy is simple. It's cheaper to remove residue than it is to replace metal. Your 4C engine
represents a sizeable investment. Better to take care of it.
I'd suggest a fuel that contains at least SOME castor if you intend to keep your engine for
any length of time. Fuels such as Powermaster, Omega, etc...have ample oil/castor content
to keep your motor running well for a long time.
Hope this helps.
'Race
< Message edited by RaceCity -- 1/5/2004 3:54:06 AM >
(in reply to 3d-aholic)
       Post #: 2
RE: 4-stroke fuel--Does anyone really know? - 1/5/2004 3:46:09 AM
3d-aholic
Status: offline
Well the thing is I'm going to make my own fuel for my 4-stroke
But do I make a fuel like-
Wildcats: 18% oil, 100% synth
Wildcat recommends the lubrication package be totally synthetic. The use of synthetic oil is important in four stroke engines to prevent gumming and varnishing of the lifters and coking of the valves. Varnishing will occur on castor based fuels. This can lead to sticking valves, which will cause the valve set to get knocked out of time. Coking of the valves will cause improper seating of the valves causing a reduction in compression and incomplete combustion. Four stroke engines also have high exhaust gas temperatures and the use of synthetics greatly reduces carboning at the exhaust ports.
or like...
Omega: 17% oil, 50% synth, 50% castor
or like...
Powermasters YS 20/20: 20% Oil All-Synthetic
or more like....
Powermasters other 4-stroke fuel: 15% Oil Synthetic Castor Blend (most likely 70:30)
As you can see, you can get a 4 stroke fuel anywhere from 15 to 20% oil and anywhere from 0% to 50% castor. There are bigger differences in 4-stroke fuel than 2 stroke fuel.
(in reply to RaceCity)
       Post #: 3
RE: 4-stroke fuel--Does anyone really know? - 1/5/2004 3:12:00 PM
Hobbsy
Status: offline
Throw, I have never agreed with that idea, I ran my Enya .46MKII, Saito .80 and 150 for about three years on Fox 15% fuel with 20% castor with no ill effects at all.
_____________________________
Giant Saito, 73.2 Cu. In., 70.5HP @ 5,800 rpm, 79 ft. lbs torque @ 3,500 rpm, 57 mpg, 3.50 bore, 3.81 stroke. 563 lbs.
       Post #: 4
RE: 4-stroke fuel--Does anyone really know? - 1/5/2004 11:06:36 PM
Bax
Status: offline
Four-stroke engines tend to run a much lower temperatures than do the two-strokers. This means that you can use synthetic oil quite well. With rich running, synthetic oil will greatly reduce the varnish and carbon buildup you'd see in two-stroke engines.
Also because of the lower operating temperatures, you can get away with a bit less oil. With a few exceptions, all of the O.S. Max four-stroke engines can be run on fuels with the oil content as low as 16%. With hotter-running engines, the oil is used to help carry away the engine's heat. Synthetics will do this nicely until the engine gets too hot, where it vaporizes and, PRESTO!, no oil. Castor will start to turn to varnish, but will still protect the engine somewhat.
We have no problems with anyone using a fuel with all-synthetic oil in a four-stroke engine. The main thing to consider is that most fuels with synthetic oils do not provide the corrosion protection the lower-end of your engine needs. This means that you have to make sure you get a LOT of a good-quality after-run product into the lower-end of the engine at the end of the flying day. You'd be surprised to see how fast the bearings and crank can corrode if you don't.
For convenience, though, we'd suggest that you use the same 18% oil-content fuel in your four-stroke engines as you do in your two-strokes. If you use a synthetic-castor blend in your 2-strokes, then it won't hurt your four-strokes.
Good-quality fuel is the main requirement. If you use a good-quality fuel, you should have no engine problems caused by the fuel.
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
(in reply to Hobbsy)
       Post #: 5
RE: 4-stroke fuel--Does anyone really know? - 1/5/2004 11:17:21 PM
3d-aholic
Status: offline
quote:
ORIGINAL: Bax
Well my TT .91FS is choking up gobs of black tar/soot into the tank from the muffler on Powermaster. So something in the fuel is burning up besides the Methanol and creating soot. Supposedly that can't happen to castor (not hot enough)...so it has to be the synth.
[But thats a guess.....seems no-one knows for sure.]
< Message edited by 2MuchThrow -- 1/5/2004 6:22:00 PM >
(in reply to Bax)
       Post #: 6
RE: 4-stroke fuel--Does anyone really know? - 1/5/2004 11:28:48 PM
3d-aholic
Status: offline
quote:
ORIGINAL: Bax
This is what I mean by no-one agrees.
Granted what you say is true. But, according to Wildcat, the only way oil can get to the bearings/crankcase for instance is blow by....so you need more oil to compensate for the fact that there is no direct fuel/oil mix pumping to that region of the motor.
http://www.wildcatfuel.com/fuel_24cycle.html
"First - Four stroke engines require more lubrication than do 2-stroke engines. This is do to the number of moving parts. Unlike a 2-stroke, a 4-stroke does not have the benefit of raw fuel and oil pumping through its crankcase for lubrication. A 4-stroke draws it's fuel in from the top of the cylinder by the down stoke of the piston. Lubrication is accomplished by blow-by at the BDC (bottom dead center) and run-down of oil through the lifter tubes. This oil must migrate to the bearings as well, therefore, volume is essential. (See disassembled 4-stroke -vs- 2-stroke below for comparision). Yes, despite the nonsense that some would try to get you to believe it's that simple."
There is an incredible amount of disagreement in this area
(in reply to Bax)
       Post #: 7
RE: 4-stroke fuel--Does anyone really know? - 1/13/2004 2:12:53 AM
RCXPLANES
Status: offline
2MuchThrow,
I couldn't agree with you more. I can't even get past the "To Castor Or Not To Castor" question concerning four stroke motors let alone how much nitro or oil content. I was running CoolPower 15% in my Saito and then was told that 18% oil was not enough. Oh my goodness it is all synthetic as well. I know better than to overheat a 2 stroke so, for me synthetic was fine. Besides, Castor in a 2 stroke ringed motor just means you will gum it up and spend more time sooner fixing that.
I think we need a manufacturers rep from all of the four stroke companies to recomend at least a safe percentage of castor/synthetic/nitro blend without the wishy washy this is ok and that is ok and no real recomendation. To complicate things, some fuels are great about telling how much of what is in which products in their line. Others are not so good.
So what is the best fuel for our nitro swilling bump stickers? Is Blow-By a really good lubrication method for a crankshaft? With that much Blow-By, arn't we loosing some of the power potential? Seems to me that my four stroke is bordering on if not surpassing my 2 strokes in fuel inefficency when you compare how much raw fuel and oil are deposited on the Ultracoat.
Life is short. Fly hard and enjoy.
Bud Wilkinson, RC-Xplanes, www.rcxplanes.com
       Post #: 8
RE: 4-stroke fuel--Does anyone really know? - 1/13/2004 4:46:24 PM
3d-aholic
Status: offline
quote:
ORIGINAL: errolw98
And the most secret of all mixes are the 4 stroke combinations. Sig, Powermaster and many others completely secret on the 4 stroke mix question.
(in reply to RCXPLANES)
       Post #: 9
RE: 4-stroke fuel--Does anyone really know? - 1/13/2004 5:29:44 PM
RCXPLANES
Status: offline
Makes it easy dont it.
       Post #: 10
RE: 4-stroke fuel--Does anyone really know? - 1/13/2004 5:43:45 PM
3d-aholic
Status: offline
Its obvious to me no-one really knows.
I think everyone is just pretending like they know...
       Post #: 11
RE: 4-stroke fuel--Does anyone really know? - 1/13/2004 6:17:21 PM
Hobbsy
Status: offline
This fuel thing is just like the glow plug thing, some guys say the OSf is the only way to go, I have ten Saitos, three YSs and two Enya fourstrokes that say different. The Fox Miracle plug and the H9 SuperPlug work just as well except in my Saito .30 in which the H9 plug works best. I've used Wildcat fuel for several years now and have had zero problems, so I think I know. But some guy whose run a 12x4 on his Saito .72 is going to fry the bearings and blame the fuel or the bearings or both and he'll say that I don't know jack stuff. So where does that leave us? Simply put, run the fuel you like.
       Post #: 12
RE: 4-stroke fuel--Does anyone really know? - 1/13/2004 6:24:35 PM
3d-aholic
Status: offline
So TRUE....I hear what you are saying. I agree. I use the Fox Miracle plug too and have to listen to folks say it won't work...you have to be using a $9.00 OS plug or your engine will explode or it won't work. I just say "Yeh, your right and then tighten up my Miracle plug and go flew".
With the fuel thing, I was trying to make my own and so its a bit more complicated. I guess I will need to try and experiment with several blends and find out what works best for myself. I'm fairly sure that just about any kind of oil that is at least 12% or better is probably fine for a short decision making process anyways.
       Post #: 13
RE: 4-stroke fuel--Does anyone really know? - 1/14/2004 3:26:31 AM
RCXPLANES
Status: offline
2Much,
Are you going to mix all of the components, i.e. Methanol, Oil, Nitromethane and maybe something special? Where do you even get all the ingredients to blend?
I think you have the right idea though. Mix what you want to try. Try it and then decide or tweak it from there. I would be curious how that works for you and if you were able to produce something you were not only satisfied with but was cost effective as well. Most of us little guys probably can't buy most of the ingredients at the purity level of the fuel manufactures in the quantity that would make it feesable to put that kind of effort into it. Unless you come up with the magic blend that blows everything else away for you. Then again, who really knows if they are getting the purity levels they claim or think they are? I know they test the stuff but you can't test all of it.
       Post #: 14
RE: 4-stroke fuel--Does anyone really know? - 1/14/2004 2:33:46 PM
Red B.
Status: offline
IMHO, nobody really knows what the best 4-stroke fuel is. I do however take advice on fuels from the engine manufacturers seriously. After all, it is in the engine manufacturers own interest to provide the best advice possible.
SAITO recommends a mixture containing 20% oil and 10-15% nitro. As for the oil: "Use of fuels composed entirely of castor oil is not recommended. A mix of synthetic-castor is acceptable...". From that I presume that all-synthetic lubricants are O.K.
Indeed, tests in German model-aircraft magazines some years ago showed that there is significantly lower wear in engines run with all-synthetic lubricants, as compared to engines run with castor oil.
As for the fuel manufacturers: Oil is much more expensive than methanol and nitro. Therefore it is in their interest to use as little oil as possible in their fuels, whilst not generating too many complaints about worn out or damaged engines. Adding a couple of percents of castor oil helps them get away with this. The reason is that castor oil is an excellent lubricant at high temperatures. When an engine is run too lean or is overheating to the extent that the synthetic lubricants break-down or evaporate, the castor oil forms a resinous coating that protects the engine. This resinous coating is very hard to remove though...
As compared to castor oil synthetic lubricants exhibit the following advantages:
+ significantly lower engine wear
+ no carbon build up
+ easy to clean off aircraft
+ works very well in cold conditions (important for me at latitude 60 deg north)
but there are disadvantages as well:
- expensive
- little protection against damages due to lean runs and/or overheating
- less protection against corrosion damage (some synthetic lubricants contains additives to address this issue)
- possibly a lot less environmentally friendly (the manufacturers provide little or no information, shame on you!)
- the smell and taste is g.d. awful! (I don't drink the stuff but occasionally get it on my fingers)
In the end the choice is down to you:
If you are experienced enough to avoid lean runs and overheating my advice is to go 100% synthetic.
If you experience the odd lean run or overheating situation go for fuel with some castor-oil in it.
If you care about the environment and possibly your own health, don't mind about removing carbon deposits and don't care about the increased wear (not significant unless you fly hundred of hours each year) go for castor-oil (applies to 2-stroke engines only).
As for the percentage: Unless you know better follow the ENGINE manufacturer's recommendation.
For many years I used castor oil exclusively but have since switched to synthetic lubricants 100%.
For my SAITO engines I have reduced the oil content to 15%. Even though two of the engines have been run for a couple of hundred hours they still look and feel as new when dismantled.
And yes, I do mix my own fuel!
/Red B.
< Message edited by Red B. -- 1/14/2004 2:43:08 PM >
(in reply to
