RE: TF Spitfire build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: TF Spitfire build
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: TF Spitfire build - 1/13/2004 2:34:51 AM
tubig
Status: offline
navy18,
i was at whiting in '86-'87 and got winged in kingsville in june '88 so i think you were a little earlier than me. as far as engines, i'd like to use either a pumped O.S.91FS or a RCV90. regarding pictures, i just use the "upload images" link at the botttom of the posting page.
doug d., your spit looks great! did you take any pictures during your build or post to a website? i'd like to see some if you did.
mark, what i'm actually trying to do is make the joiner a little larger diameter and blend it into the elevator halves so that it looks more like the real one. maybe you can see what i'm talking about in the photo.
Click to see fullsize image.
Click for fullsize
(in reply to Navy18)
       Post #: 26
RE: TF Spitfire build - 1/13/2004 4:25:13 AM
Doug D.
Status: offline
Well Navy18 It's not a handfull until the speed bleeds off. Even then landings are pretty striaght forward. Mine come out heaver than I had hoped for. About 11lbs. If I'd a known that it would have turned out this heavy I'd paid more attention to the tail assembly. And probably monokoted it. But the Laser 1.00 pulls it with authority. (Stock muffler)
Century Jet retracts with a robart control valve(left over from another effort). There was no real hard part to the build, and no I'm sorry to say I didn't take any assembly photo's. But I've built several TF kits and have a couple more that I'd like to get to in the future. The only substitutions of parts that was made, was a fiberglass cowl and some wing sheeting that was way to soft.
If you've never built any of the other TF kits this may seem harder than it really is. Just take your time and follow the intructions and it should turn out okay. Just pay attention to the weight in the tail.
< Message edited by Doug D. -- 1/13/2004 4:28:30 AM >
       Post #: 27
RE: TF Spitfire build - 1/13/2004 11:32:39 AM
tubig
Status: offline
doug d., i'm also using the CJ retracts. did you have to modify the wing to accept the CJ's since the kit is built around the robarts?
< Message edited by tubig -- 1/13/2004 7:40:07 PM >
(in reply to Doug D.)
       Post #: 28
RE: TF Spitfire build - 1/13/2004 11:44:53 AM
tubig
Status: offline
quote:
ORIGINAL: phread59
I gotta suggestion on the dowel. How about you glue the dowel in. And get a very small dowell, I think a 1/16th or so. The metal one needs a hole drilled into the stab any way. Why not just drill a hole in the dowel and glue in the small dowel as the metal joiner would? I did this on 2 of the kits I did to eliminate the metal one. Worked well for me. Hope this works.
Mark Shuman
mark, at first i didn't follow your post. but after sleeping on it i think i realize what you meant. basically, make a "U" out of dowels instead of using the metal "U" supplied....yes? i think that's a good idea since it gives the support needed for the elevators. thanks!
(in reply to phread59)
       Post #: 29
RE: TF Spitfire build - 1/13/2004 2:22:16 PM
Doug D.
Status: offline
tubig
The CJ's are pretty much the same.A little more carving and a different width on the mounts. Take your time and you'll get it.
< Message edited by Doug D. -- 1/13/2004 2:20:16 PM >
(in reply to tubig)
       Post #: 30
RE: TF Spitfire build - 1/13/2004 3:00:54 PM
Navy18
Status: offline
Thanks for all the info guys; I am not building a TF SPit yet so I will just keep an eye on this thread and plan ahead.... as much info as possible on the retracts, including pics, would be great. I'll try sending a pic to see if it goes through..... love those Spits. Do most builders use Monookote to save weight? That takes away from scale details you can add but the flinal weight is more important.
Click for fullsize
Click for fullsize
       Post #: 31
RE: TF Spitfire build - 1/14/2004 1:18:53 AM
tubig
Status: offline
i think most modelers who want a realistic finish go with glassing and painting. that's my plan. there have been many threads on how to glass and paint lightly. practice on another model before you do a heavy-prone plane like the TF. i did my first practice on an OK models P51 and it came out just 2 ounces heavier than published range. you'll get lighter as you build more.
       Post #: 32
RE: TF Spitfire build - 1/14/2004 2:19:31 PM
Navy18
Status: offline
I need to research how to "glass" a plane made totallfrom balsa..... do you have a good tread for me to clue in on?
Click for fullsize
(in reply to tubig)
       Post #: 33
RE: TF Spitfire build - 1/14/2004 7:02:27 PM
Jimmbbo
Status: offline
quote:
ORIGINAL: Navy18
I have a TF Spit waiting a turn at the building table. It was not designed to be glassed for strength, and is structurally sound without it, so glassing would be for smoothness. IME, glass is messy, expensive, hard to work and can be pretty heavy. IMO, in the event of a crash, it will not save the airframe, and is difficult to repair. From posts I have read on the TF Spit, weight is not our friend, so I intend to use the following old trick:
I use clear butyrate dope and silkspan, filled and sanded with a dope/talcum powder sanding sealer and primer/sand to the smoothness desired.....
Materials (LHS should have all but talcum powder - unless you have a "different" LHS ): Medium weight silkspan, clear butyrate dope (2 qts should cover the Spit, may take another pint), dope thinner (1-2 qts), 1 bottle talcum powder (scent at your discretion ), large 2 inch brush, tack rag, sanding primer (spray can or airbrush), wet/dry sandpaper 240, 360, 400, (and 600 - 1200 if you're a masochist! )
Preparation: After balsa surface dings are filled and sanded smooth, brush components with two coats of clear dope - about an hour (dope dries FAST, and the balsa will suck it in like a sponge) When dry, lightly sand balsa fuzz off with 240 grit paper. Remove dust with barely damp rag.
Covering: Cut silkspan piece of a convenient size* - can do an entire .40 - .60 wing panel in one piece with a little practice - dip in water, lay on towel to absorb excess water, apply dope to the area to be covered with a large brush, lay damp (not dripping) silkspan on the model (If I think the silkspan is too wet, I'll lay another towel over the wet silkspan and press excess water out. The silkspan should be just damp to conform to the surface, definitely not wet), brush another coat of clear through the silkspan to attach it to the balsa. If the piece doesn't go on right, just remove it, reposition it, or trash it and cut another... Repeat till all components are covered - on the Spit, I expect covering to take about four hours. It goes pretty quickly once you get a rhythm going Note - when dry, any excess silkspan hanging over edges can be either cut or sanded off easily, and the next coat of dope will lay the edges down nicely
*I usually precut all the silkspan panels for the component I'm covering, dampen and apply, then set component aside and cut next set.
Filling: When the model is covered and silkspan is "overnight" dry, brush on a couple of coats of clear dope, sand lightly with 240 grit paper, then thoroughly mix about 25% talcum powder in a jar with clear dope, brush and sand till the silkspan weave is filled (3 - 5 coats), stirring up the talcum powder regularly. I keep the talcum/liquid percentage about 25%, but progressively thin the dope as more coats are applied, with the last coat being about 50/50 dope and thinner... Filling time depends on drying - may take a while in the winter... I would plan two building sessions of 3 - 4 hours
Finishing: When the silkspan weave is filled, sand with 360 grit and use a tack rag to remove all dust. Spray on two coats of sanding primer (spray can or airbrush) and dry or wet sand and reprime and sand to the finish you want. In a fit of passion a while back, I ended up wet sanding the primer with progressively finer paper, finishing with 600 grit... talk about smooootooooth Time depends on finish you want... I'm planning four hours, then another four or six for the camo scheme...
HTH
Jim
_____________________________
Have you flogged your crew today?
       Post #: 34
RE: TF Spitfire build - 1/14/2004 9:01:29 PM
Navy18
Status: offline
Jimbo, I am going to print your technique for future use.... sounds very involved but will attempt it on lesser projects and see what happens.... I researched the Robart gear and was discouraged at the price of the entire system.... makes the kit purchase seem secondary. Is there a better value in retracts that are dependable? Are we paying for the name?
Click for fullsize
(in reply to Jimmbbo)
       Post #: 35
RE: TF Spitfire build - 1/14/2004 9:04:41 PM
Navy18
Status: offline
Tubig; I am not familiar with the spitfire in your pic of the tail. Where did you see that desert colored spitfire?
       Post #: 36
RE: TF Spitfire build - 1/14/2004 9:14:14 PM
Doug D.
Status: offline
Hey Navy18!
The Century Jet system for the TF Spit listed at Tower is a complete sytem. Except for wheels of course. And a good value. Mine are holding up well!
Complete system is an air tank, valve, tubing, tubing fitting and connectors, and of course the mains. And CJ's aren't wire, there functional struts.
They may look expensive, but there not to bad really.
< Message edited by Doug D. -- 1/14/2004 9:16:01 PM >
       Post #: 37
RE: TF Spitfire build - 1/14/2004 9:15:30 PM
kram51
Status: offline
Yes and no on the retracts. They are what they are and price will be an issue but you have to realize that these are cottage industry efforts at best and they never sell that many sets that would drive the price down. I will add that Century Jet is a viable option and a bit cheaper as they include pretty much everything you need whereas the Robart gear has a better finished appearance and some would argue the overall quality is better. I've used both and have no gripes about either (EXCEPT for the Robart 615's but that's another story completely!). I've also used Springair with great success. These "stock" retracts are expensive only until you decide on a custom set of gear!
