famousdave
Joined: 9/16/2003 From: Bradenton , FL, USA Status: offline
I have flown JR exclusively for years. As my planes grew in size, so did the requirement for larger loading and more servos. The JR solution (with matchboxes, etx) is ludicrous. Way too much to go wrong. I tried one plane with this setup and found it to be a royal hassle and way too much money, not to mention all the weight added and wiring nightmare. No Thanks. I have since switched to Hitec. With the volume of servos I was going through there was no way I could overlook the price difference. People for whom I have built planes for agreed too, and so now unless someone wants JR, I use Hitecs. I have had no failures. I build to the way a person intends to fly. If they fly pure scale, I will use servos up to 75% of their rated load. If they fly IMAC or Pattern - 65%. 3D, I will never go more than 50% of rated load no matter what the a/c maker says. In some cases that means stronger servos or multiple servos on each surface. I did this with JR and I do it now with Hitech. In most cases, this does not add a lot more servos. Only occasionally do I have to add above what the plane is designed for. That said, nearly all failures are due to overloading, overheating, vibration or too high of an operating voltage (some Nimh packs run "hot" and over their voltage ratings). In all the years of flying, I have not once had a servo fail "just because". Each time I traced it back to a root cause that I could have controlled. The failure rate on modern high end-servos is in the 6-sigma range or 3 failures in 1 million.. or 3 PPM. Here is my failure log over the past 3 years JR 507 (Throttle) gears stripped, throttle jammed stalled servo - no crash JR 8411 (Rudder) hardover, installed too tightly in servo tray, vibration caused pot failure - no crash JR 8231 (Aileron) gear stripped, aileron surface impacted on ground during handling - no crash, caught on ground Hitec 645MG (Rudder) horn screw backed out, loss of rudder and resulting extreme flutter, tail came apart - crashed Hitec 5945MG (Rudder) poor centering, chatter at idle - cables strung too tight as airframe expanded in heat Hitech 5945MG (Aileron) quit. Improperly centered by operator, working against other servos on surface Root Cause of every failure - installation or handling. I will stand by Hitec, I think they make a great product. As far as transmitters and receivers.. I will never fly anything but JR! DP
