Scratch built, foam delta. Where should the CG be?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> Scratch built, foam delta. Where should the CG be? Page: [1]
Login
Scratch built, foam delta. Where should the CG be? - 5/23/2002 8:11:46 AM
rsieminski
Status: offline
I've built a scratch, foam delta. WS 42", root chord 23", total area ~693 in2. Where should the cg be? I think the mac is 15.5".
Rick
       Post #: 1
Delta CG - 5/23/2002 8:53:34 AM
matchlessaero
Status: offline
Rick, I would start with 20% of the main chord. (I have also heard suggestions of 11% of Mean Aerodynamic Chord, but I have not yet learned how to figurer the MAC)
Start with the CG forward. You may have to put more reflex (up) in the elevons to get it to fly, but it will fly. You can then slowly move the CG back slowly until the performance changes. As the CG moves back, you should need less reflex (which causes drag).
Put a pic up of your delta so we can see.
_____________________________
Go fast turn left-----3D is life-----Fly S.M.A.L.L. I'm having an RC identity crisis!!!!!!!!!
(in reply to rsieminski)
       Post #: 2
Scratch built, foam delta. Where should the CG be? - 5/23/2002 1:43:47 PM
Cactus.
Status: offline
my rule of thumb, never failed me yet
work out the CofG as per normal planes. all flying wings must be forward of this point. work out 5% of your root chord. move your CofG forwards by this amount. this is the MOST! you can go rearwards, in real terms i use 8% to be safe
how do i work out where the normal CofG should be?
i draw a line 1/3 of the tip to 1/3 of the root.
i then take a line 1/3 of that line and join that to 1/3 on the other side. 1/3rd meaning if you start from root and work down towards the tip.
it depends on how much taper i have wether i stick to this or move forwards a bit, but its always somewhere near the CofG if you where just dealing with the root, just behind it.
i cant be bothered to get out a calculator but i've never been far off the money so far
My half dead website www.philsrcworld.fsnet.co.uk new site coming soon.
Redruth & District model flying club www.rcflye
       Post #: 3
Scratch built, foam delta. Where should the CG be? - 5/23/2002 5:01:39 PM
DICKEYBIRD
Status: offline
Try this site guys: http://ourworld.compuserve.com/homepages/slope_scale/page17.html
       Post #: 4
Scratch built, foam delta. Where should the CG be? - 5/24/2002 2:57:55 AM
rsieminski
Status: offline
Thanks, I'll try it and post back as to how it flew/crashed.
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.328RCU1
