RE: RE: RE: RE: Official Mini-T Thread
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Mini-T
  • 4 Active Classified Ad(s)
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> RE: RE: RE: RE: Official Mini-T Thread
    Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
    Login
    RE: RE: RE: RE: Official Mini-T Thread - 2/22/2004 6:32:30 PM
    snowborder69
    Status: offline
    whats the difference between fm and am??
    (in reply to Tigger N. Bennie)
           Post #: 126
    RE: RE: RE: RE: Official Mini-T Thread - 2/22/2004 6:40:19 PM
    ronbeck
    Status: offline
    quote:
    ORIGINAL: snowborder69
    next time your in the car, switch from am to fm on your radio. fm is just stronger more reliable. am is prone to glitching when many channels ar ebeing used(like at a race).
    (in reply to snowborder69)
           Post #: 127
    Official Mini-T Thread - 2/22/2004 7:24:59 PM
    Tigger N. Bennie
    Status: offline
    Snowboarder69,
    Then there is that little matter of the 4-wire stock servo, which I changed out with an airplane servo and a little Dremel action when I converted my Mini-T to FM.
    (in reply to ronbeck)
           Post #: 128
    RE: Official Mini-T Thread - 2/22/2004 11:10:41 PM
    snowborder69
    Status: offline
    i was wondering if the mamba bl motor setup was out yet? if they are out how fast will they make my mini-t go?? and where could i find one?
    (in reply to brainleak)
           Post #: 129
    RE: RE: RE: RE: Official Mini-T Thread - 2/23/2004 1:55:39 AM
    Tigger N. Bennie
    Status: offline
    If it were, I might have bought one. Instead I purchased a different brand yesterday.
           Post #: 130
    RE: RE: RE: RE: Official Mini-T Thread - 2/23/2004 2:44:44 PM
    bbentley40
    Status: offline
    If you are switching to FM you could always use a HS-55 servo and not have to deal with the dremel action (needed for HS-81 servos). I use the 55 on my T and it is a huge improvement over the stock POS servo.
    _____________________________
    Bentley
           Post #: 131
    Official Mini-T Thread - 2/23/2004 6:06:42 PM
    Tigger N. Bennie
    Status: offline
    I didn't use either one of those servos. I went with a metal geared HiTec HS-5125MG.
    (in reply to bbentley40)
           Post #: 132
    RE: RE: RE: Official Mini-T Thread - 2/24/2004 4:46:08 AM
    kevrut
    Status: offline
    What is a good, inexpensive electronic speed controler with reverse? I don't race much, even then it is with friends, nothing serious.
    Losi Mini-T (to chase the cat ;)
    XTM Mammoth (to eat the cat!)
    (in reply to garynjr)
           Post #: 133
    Official Mini-T Thread - 2/24/2004 7:29:16 PM
    Tigger N. Bennie
    Status: offline
    You can always check out the Novak Spy.
    http://www.teamnovak.com/products/ESC_Specs/revers_spec/reverse_index.htm
    (in reply to kevrut)
           Post #: 134
    RE: Official Mini-T Thread - 2/24/2004 7:34:29 PM
    kevrut
    Status: offline
    Ouch, that's almost as must as the car...
           Post #: 135
    Official Mini-T Thread - 2/24/2004 7:39:26 PM
    Tigger N. Bennie
    Status: offline
    What can I say, I have the GT7 in mine and it doesn't even have reverse. That's why I use to Overland to chase the cat instead of the Mini-T.
    Edit: By the way, the "Street" price was lower than the "list" price when I purchased my GT7, so the Spy may be lower.
    < Message edited by Tigger N. Bennie -- 2/24/2004 2:41:19 PM >
           Post #: 136
    RE: Official Mini-T Thread - 2/24/2004 7:58:17 PM
    kevrut
    Status: offline
    Thanks! I found some in the low $60 range.
           Post #: 137
    RE: Official Mini-T Thread - 2/24/2004 10:27:24 PM
    paintdogg67
    Status: offline
    I just got my mini t the other day and I love this little thing. I bought it used and it has the bearings and the speed 300 motor with a 7 cell blindbatts battery-IT FLIES!! Here is my tip- I bought the green/white body for it and I couldn't get the spoiler to stay on with the two sided tape so I used ca glue on it. If you do this be sure to remove the paint off the spoiler before you glue it on. Just mark the part that goes to the body and scratch the paint off! I hope this helps.
           Post #: 138
    RE: Official Mini-T Thread - 2/24/2004 11:01:19 PM
    madblunted
    Status: offline
    I just used some servo tape, it holds pretty good.
    (in reply to paintdogg67)
           Post #: 139
    Official Mini-T Thread - 2/25/2004 12:42:42 AM
    Tigger N. Bennie
    Status: offline
    I bolted it on--2 small holes is all it took.
    (in reply to madblunted)
           Post #: 140
    RE: Official Mini-T Thread - 4/28/2004 11:04:40 PM
