RE: Official Mini-T Thread
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Mini-T
  • 4 Active Classified Ad(s)
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> RE: Official Mini-T Thread
    Page: <<   < prev  80 81 [82] 83 84 85 86 87 88 89   next >   >>
    Login
    RE: Official Mini-T Thread - 5/11/2008 1:20:29 AM
    Deftones123
    Status: offline
    lol no loss to me rocket, message boards will be message boards
    (in reply to Frozen72)
           Post #: 2026
    RE: Official Mini-T Thread - 5/11/2008 1:28:04 AM
    Frozen72
    Status: online
    http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTCK1&P=0
    I found my next charger it can do everything I need it mostly A123. Now it's time for my to get some of those drill packs for batteries.
    _____________________________
    "My friends don''t know I''m black"
    Rap - Lies = Hip-Hop
    (in reply to Deftones123)
           Post #: 2027
    RE: Official Mini-T Thread - 5/12/2008 2:55:32 AM
    Frozen72
    Status: online
    I'm going to the LHS tomorrow hopefully I'll be able to get what I need to get it running and either a ball diff or some Losi oil shocks.
    (in reply to thedr)
           Post #: 2028
    RE: Official Mini-T Thread - 5/13/2008 12:42:35 AM
    Frozen72
    Status: online
    This isn't my guide but I found in on a different forum and it was very helpful.
    The Ultimate Mini-T Guide
    Well the question has been asked many times, what upgrades should I get? So I thought that I would make one thread that answers this question and can turn your mini-t or mini Baja into a racing machine
    The first upgrade that I would recommend getting is a good battery pack and charger for a battery pack there are many options out there but the pack that I would recommend would be either an IB1400 pack or an Elite 1500 pack. You can find the IB 1400 pack at Tower Hobbies while the Elite packs are made from cheapbatterypacks.com. While you are upgrading the battery you should also upgrade the connectors from the stock HPI micro plugs to the Deans Ultra plug. Upgrading to the Deans Ultra plug will allow a better connection from the batteries to the ESC and creating less resistance. While you’re shopping for a battery you also want to look for a decent charger to give your packs a better performance. Some very good chargers are the Piranha AC/DC, the Prophet Plus, the DuraTrax IntelliPeak series. If you plan on upgrading to a lipo pack later on you may want to get a charger that can charge all types of batteries such as the Triton JR., Triton 2, Duratrax ICE, or the Dynamite Ultra AC/DC.
    –NOTE- If you get the Triton JR., Triton 2, Duratrax intellipeak, or Duratrax ICE you will need an optional power supply. These range in prices from $20 – over $150. A good $20 power will get the job done easily though.
    Battery Packs-
    IB1400 pack: http://www2.towerhobbies.com/cgi-bin...?&I=LXMUE5&P=7
    Elite 1500 pack: http://cheapbatterypacks.com/main.as...rer=3&model=20
    Chargers-
    Piranha AC/DC: http://www2.towerhobbies.com/cgi-bin...&I=LXCLD5&P=ML
    Prophet Plus: http://www.dynamiterc.com/Products/D...ProdID=DYN4036
    DuraTrax IntelliPeak: http://www2.towerhobbies.com/cgi-bin...?&I=LXHJB5&P=7
    Triton JR.: http://www2.towerhobbies.com/cgi-bin...&I=LXMAH9&P=ML
    Triton 2: http://www2.towerhobbies.com/cgi-bin...&I=LXMAJ0&P=ML
    Duratrax Ice: http://www2.towerhobbies.com/cgi-bin...?&I=LXHDJ1&P=7
    Power Supplies-
    Novak Black Box (5A): http://www2.towerhobbies.com/cgi-bin...?&I=LXDDD9&P=7
    Novak Black Box (9A): http://www2.towerhobbies.com/cgi-bin...?&I=LXKNY2&P=7
    Pyramid Power Supply: http://www.millionbuy.com/pyrps8k.html
    The Next Upgrade that should be purchased would be the BRP chassis brace and the RPM wide front bumper. These two parts can help protect the chassis in the event of a crash, and the RPM plastic is near indestructible. Both of these parts can be purchased from Tower Hobbies for a very affordable price. EVERY MINI-T/ BAJA should have those parts!! Weather you bash your truck or race it.
    RPM Wide Front Bumper: http://www2.towerhobbies.com/cgi-bin...?&I=LXHCD8&P=7
    BRP Chassis Brace: http://www2.towerhobbies.com/cgi-bin...?&I=LXGZK1&P=7
    Bearings, Bearings, Bearings (Mini Baja owners won’t have to worry about this part) Bearings will give your truck a smoother ride, help it run smoother, and give it a slightly higher top speed. Not only that but upgrading to bearings can also help lower the heat on your electronics.
    Bearing Set: http://www2.towerhobbies.com/cgi-bin...?&I=LXGGY4&P=7
    The Next stage is the Suspension Upgrades I will recommend that you get some oil filled shocks ASAP! These will greatly improve the handling of the truck making it not so bouncy. A very good set of shocks are the GPM shock set. These shocks are super smooth and allow for precision tuning do to them being threaded. I will have to steer you away from the Losi shocks because they tend to have leaking problems.
    Here is a link to the shocks: http://www.thetoyz.com/cart/thetoyz_...6624&cat_name=
    Finally to the motor a good upgraded motor to get while using the stock motor is the Orion Baja motor. This motor will give a noticeable increase in top speed and acceleration, overall giving it much better performance over the stock Motor. Another good motor to get is a Graupner Speed 300 6volt motor. This motor will also give a noticeably better acceleration and slightly better top speed but I would recommend the Orion Baja over this, but for a cheap replacement the Graupner will do just fine. While we are at this stage in upgrading the Mini-t I would strongly recommend getting a set of pinion gears. These cost about $4.00 but can help prevent you burning out your new motor. I would suggest getting gears that range from 10 teeth to 16 teeth.
    Orion Baja: http://www2.towerhobbies.com/cgi-bin...?&I=LXFWS4&P=7
    Graupner Speed 300: http://www.hobby-lobby.com/speed300.htm
    The next Stage in upgrading your Mini-t is to upgrade the drivetrain for your future upgrades. The parts that I recommend is the MIP CVD’s, Losi, or MIP ball Differential (they are both equally good) MIP dual disk slipper, and the MIP light weight top shaft all of those parts will pretty much make your drivetrain bulletproof, and now you won’t have to worry if you plan on racing, or upgrading to a brushless motor here are the links to those parts.
    Ball Diff.: http://www2.towerhobbies.com/cgi-bin...?&I=LXGZM2&P=7
    Top Gear for the slipper: http://www2.towerhobbies.com/cgi-bin...?&I=LXGZM3&P=7
    MIP CVD's: http://www.thetoyz.com/cart/thetoyz_...8037&cat_name=
    Dual Disk Slipper: http://www.losipartshouse.com/servle...er-cln-/Detail
    Now we are at the stage to upgrade the electronic system… for the Mini-t you will need to get a new ESC/Receiver/Servo, while the Baja only needs a new Servo. For the Mini-t I suggest getting a Novak XRS ESC, Quantum micro 2 ESC, or a Futaba MC230cr ESC (with those ESC’s you can use any motor for a mini R/C car regardless of the motor limit), A Team Associated receiver, and as for the servo there are quiet a few choices depending on if you want to modify the chassis to fit a larger servo. For drop in servos I would get the cheaper but still good hs-55 servo, or the more expensive, yet much stronger HS-65MG. the HS-65MG is much better then the stock or the HS-55 because of the metal gears that make up the mechanism of the servo, thus making it less prone to breaking. For servos that require chassis modification I would suggest getting the HS-85MG –NOTE- with the larger servos some battery packs may not fit!!! There is a great guide on fitting this servo in the chassis located here: http://www.beatyourtruck.com/project-MINIT-stage2.html
    Here are the links to the electronic upgrades:
    Novak XRS: http://www2.towerhobbies.com/cgi-bin...&I=LXGNG5&P=ML
    Futaba MC230cr: http://www2.towerhobbies.com/cgi-bin...&I=LXUY13&P=ML
    Quantum Micro 2: http://www2.towerhobbies.com/cgi-bin...?&I=LXLXS1&P=7
    Team Associated Receiver: http://www2.towerhobbies.com/cgi-bin...?&I=LXPCA2&P=7
    HS-55: http://www2.towerhobbies.com/cgi-bin...&I=LXTX42&P=ML
    HS-65MG: http://www.servocity.com/~servo/html...y_feather.html
    HS-85MG: http://www2.towerhobbies.com/cgi-bin...&I=LXN685&P=ML
    By now you are bound to have bent a linkage it happens to us all to correct this problem I suggest that you get a set of GPM Titanium turnbuckles and you should no longer break turnbuckles While you are also upgrading the turnbuckles you may also want to look at the steering assembly and you may notice some slop in it. To help fix this upgrade to an alloy assembly, and alloy knuckles all around. Also an upgrade that isn’t really a necessity is a c/f chassis. This will eliminate chassis flex, and it will also look nice  - NOTE- with most of the c/f chassis you can only fit 6 cells. Here are the links
    GPM turnbuckles: http://www.thetoyz.com/cart/thetoyz_...8230&cat_name=
    Steering assembly: http://www.thetoyz.com/cart/thetoyz_...6891&cat_name=
    Alloy front Knuckles: http://www.thetoyz.com/cart/thetoyz_...6546&cat_name=
    Alloy Rear knuckles: http://www.thetoyz.com/cart/thetoyz_...6893&cat_name=
    C/F chassis:
    Integy chassis: http://www2.towerhobbies.com/cgi-bin...?&I=LXKUD4&P=7
    Here we are the final stages of the upgrades here is were the brushless/lipos come in On to lipo batteries for these packs you will need a LIPO CHARGER!! if you charger with a charger for nimh charger you will cause the pack to vent and can possibly start a fire. Some good brands for lipos are thunder power and apogee. I suggest getting a two cell lipo to start out with and then getting a three cell later on. There are also lipo based packs that have a safer chemistry they are called limn packs. Limn packs weigh about 3% more then the traditional lipo packs, but they can be punctured without starting a fire. If you plan on using a lipo/limn pack without a brushless motor you will need a low voltage cutoff device. There are a few different ones depending on how many cells are in the pack. A good cutoff device is either the Novak low voltage cutoff, or the Apogee LOA. A common question when researching lipo/limn packs is what is a balancer, and will I really need one? A balancer is used to give each one of the cells in a lipo pack equal voltage a good balancer is the Equinox balancer from Great Planes. I use a balancer about once every two weeks just to keep my packs at an even voltage. It's not really necessary but I would recommend at least owning one to even the voltage every now and then.
           Post #: 2029
    RE: Official Mini-T Thread - 5/13/2008 12:49:32 AM
    Frozen72
    Status: online
    My LHS only has the Losi Ball Diff in stock would I be OK if I got that one. I'm going to get a Mamba 6800 and some A123 packs in the future? Is the DD Slipper worth it or is the stock one good enough?
           Post #: 2030
    RE: Official Mini-T Thread - 5/13/2008 1:06:25 AM
    Deftones123
    Status: offline
    dont get the losi ball diff, im running the mamba 6800kv and the losi ball diff just isnt good, the outdrives are soft and will wear fast, save yourself the time and money and get the mip ball diff
           Post #: 2031
    RE: Official Mini-T Thread - 5/13/2008 1:07:31 AM
    Deftones123
    Status: offline
    im using as well a 2 cell a123 pack, the losi ball diff wont hold up with
           Post #: 2032
    RE: Official Mini-T Thread - 5/13/2008 1:47:26 AM
    Frozen72
    Status: online
    OK Thanks for the answer I'll just get a spare stock diff and boil it and hope that it holds up to the stock motor for a week.
           Post #: 2033
    RE: Official Mini-T Thread - 5/13/2008 1:58:28 AM
    Deftones123
    Status: offline
    werid thing is, I have used the stock diffs with the mamba and they seem to last longer then the ball diff lol
           Post #: 2034
    RE: Official Mini-T Thread - 5/13/2008 2:01:35 AM
    Frozen72
    Status: online
    Really, my friend used to go though them all the time with his Orion Baja. But the got a Ball Diff and hasn't had a problem since. We both need to get CVD's though.
           Post #: 2035
    RE: Official Mini-T Thread - 5/13/2008 2:14:38 AM
    Frozen72
    Status: online
    I sent RPM a E-mail asking about any plans for some more RPM stuff and I got:
    "Dear Nicholas,
    I'm afraid there currently aren't any plans for Losi Mini-T a-arms and shock towers although that can change at any time. Please continue to be patient with us and hopefully we'll get a chance to build more Mini-T parts in the not too distant future.
    Take care and thank you for your interest and support of RPM products. If you have any other questions or comments, please feel free to send us another e-mail."
    Hopefully they make some Arms and shocks towers. A bulkhead would be the best though.
           Post #: 2036
    RE: Official Mini-T Thread - 5/13/2008 3:01:45 AM
    Deftones123
    Status: offline
    that would be sweet if they made arms, yeah I used a locked diff now made for a mini lst I bough from thetoyz on ebay
