Bill McW
Joined: 11/12/2003 From: Oklahoma City, OK, USA Status: offline
Alex. Good to hear you got the Laser. And, I agree that Ray is a super guy. When you get your boat I suggest you spend some time studying the Laser web site < http://sailrclaser.com > Go to the index and click on "Tips and Tricks". There you'll find all kinds of practical information on your Laser. I would suggest you do the following tasks before sailing it since its never been on the water. "Up Your Antenna" Drill your hatch turret and wind your antenna around the hatch as described under the "stealth antenna". Pick up an appropriate-sized bolt end protector cap at Ace Hardware to plug the stock antenna's deck mount. These are small rubber caps in various sizes. There will be an example on your stock antenna tube. The size you'll need is larger. While you are at the hardware store, pick up a roll of white electrical tape to wrap over your turret-mounted antenna. This will cost you less than $3. "Shoot the Juice to Me". This will be absolutely necessary due to your boat's storage life. I use Vasilene, a small syringe and a short section of aquarium air pump tubing to inject the stuff around the servo horn. Once you do the juice thing, you'll be dry below deck in any situation. I juice my boat after every 3rd sail because I sail in rough water. BTW, don't completely remove the sail winch drum from the servo spline. Just remove the mounting screw and raise it up just enough to inject the juice. "Angle of Dangle" describes how to properly set up your mainsheet. I suggest you set it up as "quartered" leaving a little more tightening in your trim control on the TX. You never bring the main close to the center axis of a Laser like you do with sloops. When your boom points directly at the spot where the gunnel meets the stern when you are sheeted in, you are perfect. And you always have a bit more left in the TX trim. Still, start a little further out in the "quartered" position for your first couple of sails. "Its so easy speed clips" Pick up a pack of fishing tackle clips at Bass Pro or any tackle store. It will cost less than $2 and really makes sail attachment/removal easier. Boat Stand. Get a wooden folding stool at Target, Wal Mart or elsewhere. These are the old fashioned, scissor-folding deals with canvas seats. Slit a hole in the canvas a little larger than the keel bulb and either stitch or reinforce the outline of the hole with an iron-on patch. This will cost less than $10. You end up with an excellent portable stand for display or tuning prior to launching. The bonus is you can sit on it while sailing. Lasers are a bit different than other RC sailboats in respect to set up and handling characteristics. But I'm certain you will love your boat the first time you bring it in from sailing it. Feel free to contact me anytime with questions or concerns. Bill
